How to play .mkv files in media player
i am unable to play .mkv video files in any media player
please suggest me solution to play this kind of files....
greatcoder
Why are u wasting your time and using Windows Media Player.bohari am unable to play .mkv video files in any media player
There are much better free and open source products available:
1) VLC Player: The best in class player. Plays anything that exists on this earth.๐
2) GOM Player: Another good option u can go for.
3) Media Player Classic: Can play large no of formats as well.
Windows Media Player Sucks. But if u still want to play mkv file then u need to download special third party plugin for media player to support mkv files.
Regards
GC ๐ -
bohar
i have try vlc player but it does not play this file...greatcoderWhy are u wasting your time and using Windows Media Player.
Regards
GC ๐ -
greatcoder
I am using VLC player since a long time. It is able to play mkv files. U can also try GOM, but i think if this does not work, There is a problem in the ecncoding of the file u want to play!!bohari have try vlc player but it does not play this file... -
Neeraj SharmaCommon VLC can play anything. I have played rm,mkv,flv etc. VLC is one of the best players available..
whiz.kid.aniket#-Link-Snipped-# update your vlc player
Anoop KumarMy suggestion:
just install K-lite kodec mega pack. it will enable you to play all your formats in windows media player.
while installing select option to associate file formats to media player.
and have VLC in case of any trouble. -
coolboy.napsterDownload realplayer. .For free. .
And when it shows it can't play .Mkv file it automatically searches the missing plugin. .And plays it
Njoy! -
bohari have four files but vlc play only first file remaining one does not played by vlc ..all of same .mkv file type
boharplease suggest me solution ....first file of name ab.mkv but file type .001 and second file of name ab1.mkv ,file type .002 and so on.....vlc play first file only....i have tried all solution suggest by friend
Anoop Kumar#-Link-Snipped-# you need to join these files . these are splited files of one MKV file.
you need this : HJ Split
and put all.mkv.00* files in single folder and got to join tab and then select the 1st file to start joining.After that you will able to play that mkv file.
One thing is also that latest VLC media player able to play those file without joining.If joined file still not playing then those files are currupted and you need to download again. -
gandhi vishrutmy friend ur file is surely corrupted or it isn't copied/downloaded well i think
coz the same thing happened with me too..i had an external HD from which i copied a movie with the same .mkv.001 format the first one played but the second part .mkv.002 wont ...but still it played from the harddisk...u can edit the format...by simply renaming...but as ur file may b corrupted try to get a new copy -
K!r@nS!ngu
Well said gandhi.gandhi vishrutmy friend ur file is surely corrupted or it isn't copied/downloaded well i think
gandhi vishrutthnx #-Link-Snipped-#
boharokey i have to download these files again....thanks
gandhi vishrutr the new files working ?
r they of the same format ? -
K!r@nS!ngu
Ha Ha .... ๐ that was a wrong tag. Mine is #-Link-Snipped-#gandhi vishrutthnx #-Link-Snipped-# -
pollostarYou can try VLC media player for this file because VLC is very able to play any kind of files that who can not play in another player it can play .mkv files and provides good Technical Support .
_________
#-Link-Snipped-# -
karan20minstall media player codecs to paly .mkv files in your wmp..
karan20mwmp is the best player ever..
chiruVLC will play all the files or Total video player will do it but if you wanna pley these in WMP then #-Link-Snipped-# or #-Link-Snipped-# might help you to find your codec.
deepu11111111Vlc players version 4 or more will play those file try it
if you don't have that i will provide the link -
deepu11111111
you are right but you have to update the version of wmpkaran20mwmp is the best player ever.. -
rahul69These files seem like a continuation of single video, i.e. these are parts of a single video.Try VLC latest version, if it doesn't play then the file must be corrupted or encoded by rarely used codecs, then u need to download these codecs. Hope it helps.
awanish1981
awanish1981
Mahesh Dahale
Boharboharplease suggest me solution ....first file of name ab.mkv but file type .001 and second file of name ab1.mkv ,file type .002 and so on.....vlc play first file only....i have tried all solution suggest by friend
I think you have downloaded Part Files, first you need to Join that parts.
arrange all files in one folder and by using below S/W join them and enjoy your video ๐
#-Link-Snipped-# (location 2)
#-Link-Snipped-# (location 3)
How can we integrate some .c or .cpp file in UI made using VB.
for example i made an identical UI using VB of 'minesweeper' the in-famous game!
now i...
All the Adobe employees will now have a reason to make their friends not working in Adobe jealous of them. The company says that it wants to abolish the age...
ELECTRONICS ENGINEERS: I NEED A PASSIVE ELECTRO-MAGNETOTELLURIC DETECTION (EMT) PLATFORM
You must be an electronics engineer to work on my project. You must understand all theories and principles about this...
Can someone help me with ideas on design and fabrication of an Automated sheet metal rolling machine that can sense the length of a sheet metal.
Hi everybody, I would need some help on that one.
A magneto-meter is connected via a serial port to matlab and actually everything works fine, EXCEPT that, if the data...
