how to hack the admin
Hello friendstoday I am share a new Administrator password hacking and breakingtrick by hackingtrick.
Administrator password can be broken by replacing sam file in system32\config by the sam file in repair folder of windows. it can be easily done on a machine with dual operating systems, simply log on to os other then the one whoes password is to becracked the way is exactly same as written above but if there is a single os on a machine then there is only one way i.e to use ms dos start up disk or some other boot disk and replace the sam file in config folder with the one in repair folder
note:- this method works only if hard drive is FAT32 formatted because NTFS drive does’nt take boot from Ms DOSThis way you can remove the old administratOr password as if the windows is newly installed and the password was’nt set
I hope you like this post . pass your comments..
SKsinhaGood one, need to be tested.
Kishan GuptaGood one, I will test it.
Udaya BhaskarFail process ..! Din work ..!
zaveriwhy would you want to hack the admin in the first place ?
Udaya BhaskarTo know whether the above methods are workin in the first place ..!
Rahul JamgadeThe idea sounds good , but it hardly matters if you have single or multiple operating system running on the computer.there are ways to access the NTFS file system even with a single OS that was installed on the system and get access to the SAM database.
Raj Shresthaam not being able to make change in sam file
Ashraf HZI thought we are talking about hacking Biggie.. 😛
I've reset the admin password using a recovery CD once. Damn Dell PCs..
Go to Google Translate
Set the translator to translate from German
Copy + paste the following into the translate box:
pv zk bschk pv zk pv bschk zk pv zk...
The good old game Wolfenstein 3D turns 20 years old this month, and to celebrate the anniversary, a free browser version has been unleashed onto an unsuspecting web.
You can...
iam styding in mechatronics engineering i want to makedifferet projects inevery semester ineed help from a forum that unites all engineers i want to share ideas with them i hope...
This handy dandy graph will prove useful for you to keep a track.
Can you think of any more situations, and what their levels of importance will be? Do tell...
Dear all,
I have gone through all the post all are saying joining date yet to be come.My problem is also same I got selected in LnT info september 2011...
