HondaJet Speeds 425 KTAS (489 mph) at 30,000 ft
HondaJet has crossed the maximum speed of 425 KTAS (Knots True Air Speed) at altitude of 30,00 ft. With this test flight, HondaJet has kept its promise of delivering business jets with 40 KTAS speeds by 2012. HondaJet features unique over the wing engine mounting and natural-lumniar-flow airfoil & nose design which reduces wind-drag and ground noise. This design also improves the efficiency of the engine and also reduce emissions.
The HondaJet is powered by GE Honda HF 120 Turbofan engines with 1880lb of thrust individually. The HondaJet configuration is as below -
Maximum Cruise Speed @ FL300: 420KTAS
Service Ceiling: FL 430
Rate of Climb: 3990 ft/min
IFR Range: 1180 nm
Take-off Distance: 3120 ft
Landing Distance: 2500 ft
Engines: GE HONDA / HF120, output -1880 lb/each
Dimensions: Height 13.21 ft (4.03 m), Length 41.70 ft (12.71 m), Span 39.87 ft (12.15 m)
Cabin dimensions: Height 4.83 ft (1.47m), Width 5.00 ft (1.52 m), Length 17.80 ft (5.43 m)
Payload: 2 crew + 5 passengers, baggage 66 cubic feet
The plane boasts of 6-executive seats and two for the crew. It's interesting to note that HondaJet is Honda's first ever entry into the world of commercial jets.
Oh well, if you wish to own one, it comes at a price of only $4.5million.
Image Credit: #-Link-Snipped-#
IFR Range: 1180 nm
Whenever we talk about green house effect, the discussion, but naturally, tilt towards the irrational use of fossil fuels. Since the discovery of this Green House Effect, a lot of...
Green technology is slowly but steadily gaining momentum and people all around the globe are warming to the idea of using eco friendly gadgets and energy resources. As a result,...
The ChatBot is not a new concept for today’s world. Way back in the late 90’s, people figured out that they could set up a ChatBot on the instant messaging...
There may not be immediate applications of the transparent LCD displays, but electronics major Samsung has announced mass production of 22" transparent LCD panel displays. The transparent LCDs consume 90%...
Volkswagen is a very reputed company which gives out a car as required by a common man to a millionaire. It has a good quality of market segmentation. After flooding...
