Find the way to find inverse matrix urgent
a=
17 17 5
21 18 21
2 2 19
the ans is
4 9 15
15 17 6
24 0 17
i want to how this comes .
17 17 5
21 18 21
2 2 19
the ans is
4 9 15
15 17 6
24 0 17
Ashutosh_shuklaHey if you want the mathematics method that we had in course then refer to any textbook with a chapter on matrices.But for coding part if you are
๐ then
Check this thing out
Inverse = Adjoint divided by the determinant of matrix
Now how to find the adjoint again if you are ๐ then
Adjoint = Transpose of the matrix of cofactors.
Now how to find the cofactors again if you are ๐ then
cofactor of element is minor of the element multiplied by (-1) raised to (i+j)
Now how to find the minor again if you are ๐ then
minor is the value of the determinant formed by skipping the ith row and jth column then taking remaining rows and columns.
I guess i have clarified it enough.
The hard task is to find the determinant in generalized manner.
You have two loops one inside the another and then again two loops inside them to find the determinant of remaining rows and columns.Can you do this??????????????I have a big doubt Try it out even if you get the code working then also it would be of the complexity n^4 which is not advisable I think i posted quite a big suggestion sorry for that but i am really ๐ -
tveswaranthanx dude.... but i know the method wat u tld above... but i need to know how the inverse come for given matrix.......
i already tried ur method....but its not give the solution....... -
Ashutosh_shuklaI forgot to specify that this method works only for the matrices with non zero determinant
see if your input satisfies this criteria -
pradeep_agrawalBelow is my sample code to determine inverse of a matrix of order n.
#include "stdio.h" #define MAX_MATRIX_ORDER 10 void print_matrix(int matrix[MAX_MATRIX_ORDER][MAX_MATRIX_ORDER], int order) { int i = 0, j = 0; for(i = 0; i < order; i++) { for(j = 0; j < order; j++) { printf("%d ", matrix[i][j]); } printf("\n"); } } long calculate_determinant(int matrix[MAX_MATRIX_ORDER][MAX_MATRIX_ORDER], int order) { int submatrix[MAX_MATRIX_ORDER][MAX_MATRIX_ORDER] = { 0 }; int determinant = 0; int sign = 1; int i = 0, j = 0, k = 0; if(order == 1) { determinant = matrix[0][0]; } else { for(i = 0; i < order; i++) { for(j = 0; j < (order - 1); j++) { for(k = 0; k < (order - 1); k++) { if(k < i) { submatrix[j][k] = matrix[j + 1][k]; } else { submatrix[j][k] = matrix[j + 1][k + 1]; } } } determinant += sign*matrix[0][i]*calculate_determinant(submatrix, order -1); sign = -sign; } } return determinant; } void determine_cofactor_matrix(int matrix[MAX_MATRIX_ORDER][MAX_MATRIX_ORDER], int cofactor_matrix[MAX_MATRIX_ORDER][MAX_MATRIX_ORDER], int order) { int submatrix[MAX_MATRIX_ORDER][MAX_MATRIX_ORDER] = { 0 }; int sign_x = 1, sign_y = 1; int index_x = 0, index_y = 0; int i = 0, j = 0, k = 0, l = 0; if(order == 1) { cofactor_matrix[0][0] = matrix[0][0]; } else { for(i = 0; i < order; i++) { for(j = 0; j < order; j++) { index_x = 0; index_y = 0; for(k = 0; k < order; k++) { if(k != i) { for(l = 0; l < order; l++) { if(l != j) { submatrix[index_x][index_y] = matrix[k][l]; index_y++; } } index_x++; index_y = 0; } } cofactor_matrix[i][j] = sign_x*sign_y*calculate_determinant(submatrix, order -1); sign_y = -sign_y; } sign_x = -sign_x; sign_y = 1; } } } void determine_transpose_matrix(int matrix[MAX_MATRIX_ORDER][MAX_MATRIX_ORDER], int order) { int i = 0, j = 0, temp = 0; for(i = 0; i < order; i++) { for(j = 0; j <= i; j++) { temp = matrix[i][j]; matrix[i][j] = matrix[j][i]; matrix[j][i] = temp; } } } int main() { int matrix[MAX_MATRIX_ORDER][MAX_MATRIX_ORDER] = { 0 }; int order = 0; long determinant = 0; int inverse_matrix[MAX_MATRIX_ORDER][MAX_MATRIX_ORDER] = { 0 }; int i = 0, j = 0; scanf("%d", &order); if(order > MAX_MATRIX_ORDER) { printf("Matrix order too high\n"); return 0; } else if(order < 1) { printf("Invalid matrix order\n"); return 0; } for(i = 0; i < order; i++) { for(j = 0; j < order; j++) { scanf("%d", &matrix[i][j]); } } determinant = calculate_determinant(matrix, order); printf("Matrix:\n"); print_matrix(matrix, order); if(determinant == 0) { printf("Determinant of matrix is ), inverse can't be find."); } else { determine_cofactor_matrix(matrix, inverse_matrix, order); determine_transpose_matrix(inverse_matrix, order); } printf("Inverse matrix: [A]*(1/%d)\n[A] =\n", determinant); print_matrix(inverse_matrix, order); return 0; }
Compile the file with above code and run as:
a.exe < input.txt > output.txt [on windows]
a.out < input.txt > output.txt [on linux]
Here,
a.exe or a.out are the executables generated after compilation
input.txt is the file containing input, e.g., if the matrix of order 3 is:
1 2 3
0 4 5
1 0 6
Then input.txt will be
3
1 2 3
0 4 5
1 0 6
output.txt is the output file containing result, for given example output.txt will contain
Matrix:
1 2 3
0 4 5
1 0 6
Inverse matrix: [A]*(1/22)
[A] =
24 -12 -2
5 3 -5
-4 2 4
Please let me know if any clarification on the code is required.
-Pradeep -
Ashutosh_shuklaAwesome code Pradeep keep it up but i guess has he got his solution i dont know but your code is good i must say
Kaustubh KatdareIndeed ๐ Pradeep is one of the CS experts on CE. We are proud to have him on CE.
i need full Ubuntu source code....... tell me where to download .....
i know this is pen source.......
I wd like to know ,how one can hide the files in pen drive with a password.Do you need to down load any software for that?What is the PC compatibility...
How to convert mesh no to screen opening in mm? Have been looking for an answer for long time but with no success.
I've come across many websites that do not let you view the content or use the services unless you register. The registration, most of the times, is free.
What do...
the story is too good...
story starts with jamal(hero) being questioned by police for cheating in 'Who wants to be a millionaire'( indian version='kaun banega karordpati'), a slum boy who...
