Final year project topic for chemical engineering
Here are some topic i came across while i was searching topic for myself.
i still have to choose one. any suggestions for me?
1. Utilization Of Sludge Gas
2. Extraction Of Silica From Burnt Paddy Husk
3. Detergent Powder From Paddy Husk
4. Refining Of Used Lube Oils
5. Nicotinic Acid From Tobacco Waste
6. Paper Pulp From Groundnut Shell
7. Caffeine From Waste Tea And Coffee
8. Solar Pump
9. Extraction Of Furfural From Bagasse
10. Manufacture Of Nicotine Sulphate From Tabacco Waste
11. Cashewnut Sheel Liquid And Its Resin As Sand Core Binder
12. Chitin And Protein From Prawnshell Waste
13. Studies On Paddy Drier
14. Low Cost Viscometer
15. Cementitious Material From Rice Husk And Sea Shells
16. Glucose Syrup From Tapioca Starch
17. Cementitious Material From Rice-Husk, Sea-Shells And Clay
18. Citric Acid From Molasses
19. Rayon Grade Pulp From Banana Fibres
20. Pulp For Handboards From Arecanut Husk
21. Oxalic Acid From Molasses
22. Alcohol From Potatoes And Agriculture Waste
23. Ethyl Cellulose From Bagasse
24. Utilisation Of Banana Fibre For Making Wrapping Paper
25. Studies On Pulverisation Of Rice Husk
26. Engineering Studies On Tile And Brick Industry In And Around Dakshina Kannada District
27. Citric Acid From Molasses
28. Handmade Paper From Bagasse
29. Utilisation Of Flyash From Raichur Thermal Station
30. Cementitous Material From Agro-Waste And Sea Shells
31. Design Of Dryer For Earthenware Products
32. Design Of Crystallizer
33. Paperboard From Arecanut Husk
34. Ground Water Expolaration In An Industrial Estate Near Near Baikapady
35. Expoloration Studeis For Ground Water In Bala Area
36. Tartic Acid From Tamarind Leaves
37. Ferrous Sulhate From Scrap Iron
38. Heat Pumps For Energy Conservation In Drying
39. Good Quality Paper From Waste Paper
40. Studies On Techniques Of Traditional Chalk Making
41. Manufacture Of Iodised Salt
42. Extraction Of Oils And Jellose From Tamarind Seeds
43. Recovery Of Nickel From Spent Catalyst
44. Recovery Of Silver From Waste Photographic Fixing Solution
45. Vitamin B12 From Molasses Fermentation
46. Recovery Of Silver From Waste X Ray Solution
47. Recovery Of Nickel From Spent Catalyst
48. Production Of Vitamin B12 From Molasses
49. A Study On Electrochemical Reactions
50. Study Of Mixing Process In Stirred Vessel Reactors
51. Manufacture Of Fiber Board From Areca Spathe And Husk
52. Studies On Drying Of Freshly Pressed Bricks
53. Sonication - A Method Of Cell - Analysis
54. Preparation Of Zsm-05 Zeolites For Kinetic Studies
55. Determination Of Thermal Conductivity Of Pure Liquids And Binary Mixtures
56. Preparation Of Coconut Honey From Matured Coconut Water
57. Biosorption - Optimisation Of Parameters For Lead Removal Using Asperigillus Niger
58. Study Of Mixing Process In Baffled Reactor Vessels
59. Investigation On Pool Boiling Regimes
60. Formulation Of Theoretical Model For Viscosity Prediction Of Binaries With Experimental Verification
61. Determination Of Thermal Conductivity Of Pure Liquids And Binary Mixtures
62. Investigation On Filimwise And Dropwise Condensation
63. Investigation On Heat Pipe
64. Investigation On Burning Velocities Using Shadow Photography Techniques
65. Production Of Card Board From Rice Husk
66. Anaerobic Digestion Of Partenium To Produce Biogas
67. Detection Of Adulteration In Edible Oils And Generation Of A Portable Domestic Kit
68. Investigation On Particle Board From Waste Wood Powders
69. Preparation And Comparative Evaluation Of Activated Carbon
70. Investigation On A Natural Draft Cooling Tower
71. To Study The Rheological Behaviour Of Newtonian And Non-Newtonian Fluids In Capillaries And To Establish Shear Stress At Elevated Pressure
72. Treatment Of Industrial Waste Water Containing Heavy Metal Ions By Non-Conventional Methods
73. Pyrolysis Of Agro Waste And Production Of Charchol Clay Briquettes For Environmental Friendly Cooking In Rural Areas
74. Enrgey Exhgange Effectivness Enhancement Evaution In Domestic L P G Burners
75. Design And Fabrication Of Variable Weight Rotometer
76. Dehydration Of Egg Shells
77. Energy Exchange Effectiveness Enhancement Evaluation In Domestic Lpg Burners
78. Solar Distillation
79. Studies On Reduction Precipitation Methods For Chromium Removal From Effluents
80. Custard Apple Seed Oil As Pesticide
81. Dynamics Of Sparging
82. Anodisistion Of Aluminium For Corrsion Protection
83. Color Removal By Microbial Means
84. Determination Of Thermal Conductivity Of Binary Liquids
85. Development Of Defluoridizing Filter Candle Potable Water
86. Determination Of Thermal Conductivity Of Pure Liquids And Binary Liquids
87. Micromeritics Of Three Phase Fluidization
88. Determination Of Viscosity Of Liquids And Liquid Mixture
89. A Study On The Feasablity Of U Conventional Thickness Used As Thicking Agent For Silk Printing
90. Micron Rating Of Wire Meshes Using Buble Point Techinque
91. Photocatalyic Oxidation Of Arganic Effluents
92. Briquetted Fuel From Recylce Refuse
93. Design And Fabrication Of Spring Loaded Variable Load Rotameter
94. Efficiency Enhancement Of Solar Heater
95. Effect Of Heavy Metal Ions On Prodction
96. Pesticide Paint
97. Evaluation On Iodine Adsorption By Synthetic Resin For Water Purification Use
98. Bioleaching Of Copper From Chalcopyrites Using Bacteria
99. Toxicity Studies Of Heavy Metals On Cirrhinus Mrigala
100. Process Optimastion Of Diethyl Sulfate
101. Low Cost D Fluridatio Using Bricks
102. Preliminary Studies On Reageneration Of Ferric Chloride From The Spent Etching Solution
103. Experimental Studies On Thermal Input Flow Meter
104. Rotating Basket Reactor
105. Utilization Of Plastic Waste To Overcome Environment Pollution
106. Activated Carbon -From Coconut Shell Using A Fluidised Bed Reactor
107. Extraction Of (-) Hydroxycitric Acid, Garcinol And Anthocyanin Pigments From Garcinica And Process Design
108. Study Of Composting Using The Liquids Effluent And Solid Waste Materials Of Sugar Industry
109. Extraction Of Vineblastine Sulphate From Vinca-Rosea Plant Leaves
110. Effluent Treatment In Petroleum Refinery
111. Treatment Techniques For Production Of Mineral Water
112. Extraction Of Pectin From Orange Peels
113. A Product On Manufacture Of Activated Carbon From Paddy Husk
114. Production Of Activted Carbon From Coconut Shell
115. Energy Drinks From Coconut
116. Screening Of Waste Water From Sugar Industry
117. Extraction Of Oil From Rosemary Leaves
118. Foam Fractionation Of Protien From Voluminous Lean Solution
119. Investigation To Conserve Potable Water
120. Development Of A Novel Instrument For Diffusivity Measurment
121. Extraction Of Natural Dyes
122. Energy Exchange Effectiveness Enhancement Evalution In A Kerosene Stove
123. Bio-Diesel From Wvo
124. Investigation Of Desulfurization Of Diesel By Liquid-Liquid Extraction Technique For Environmental Protection
125. Extraction Of Mint Oil From Mint
126. Extraction Of Garcinia Lipids
127. Investigation On Use Of Jatropha Curcas Oil As Bio-Diesel
128. A Case Study Of Back-Up System In Praxair India Pvt. Ltd.
129. Analysis Of Moringa Oleifera Seeds According To Environmental And Commercial Views
130. An Experimental Study On Perfumery Oil From Lemon Grass
131. An Experimental Study Of Yeast Enzymes By Immobilization
132. Effect Of Acrylonitrile Content On The Properties Of Nitrile Rubber
133. Preparation Of Heptaldehyde And Undecylenic Acid From Castor Oil
134. Hull Cell - An Invaluable Analytical Tool In Elctroplating
135. Effect Of Fluoride Ion Concentration In Water ,Surface Soil And Vegetation Of Three Fluoride Affected Villages In Harihar Taluk Of Davangere District
136. Extraction Of Antibacterial Studies Of Pharmaceutically Important Compounds Present In Turmeric, A Natural Product
137. Extraction Of Oil From Oil Seeds Using Percolation Technique
138. Spirulina
139. Assaying Of Biodetergent
140. Multiple Spouted Bed Reactor Investigations
141. Production Of Activated Carbon From Waste Rubber Tyres
142. Design And Development Of Solar Powered Micro Gas Brazing Unit
143. Removal Of Heavy Metal Ions - Lead Using Bagasse As Adsorbent
144. Textile Wastewater Treatment And Color Removal Using Sugarcane Bagasse
145. Natural Pesticide From Custard Apple Seeds
146. Purification Of Gaseous Pollutants Using Biofiltration Technique
147. Investigation On Effect Of Papain And Ascorbic Acid On E-Coli
148. Rotocell Extraction Of Pongamia Oil And Conversion Engineering
149. Composites Of Commercial Value From Solid Waste Recycled Materrial
150. Investigations On Catalytic Production Of Biogas From Rice Straw For Power Generation
151. Power Alchohol From Agricultural Wastes
152. Development Of Smoke Evaluation Instrument For Environmental Investigation
153. Systematic Evaluation Of Drilling Mud
154. Effective Utilization Of Waste Plastics In Asphalting Of Roads
155. Optimization Of Additive Sodium Sulphide To Obtain Surface Finish Within 4 Microns By Chemical Milling For Aa2219 Alloy
156. Experimental Study On Single Bubble Cap Type Distillation Column
157. Production Of High Quality Liquid Soap By Enzymatic Method
158. Adsorption Of Heavy Metals Using Sugarcane Bagasse
159. Analysis Of Water Melon Seeds As A Cost-Effective Water Purifier
160. Studies On Linas Distillation Column
161. Extraction Of Peroxidase Using Aqueous Two Phase Systems
162. Biosorption Of Chromium Using Hydrilla And Comparison With Yeast Biomass:Column Studies
163. Biosorption - A Novel Way For The Removal Of Heavy Metals
164. Corrosion Behaviour Of Electrodeposited Zinc - Nickel Alloy
165. Alpinia Leaf Extract : A Prospective Natural Food Preservative
166. Design And Fabrication Of Through Circulation Dryer For Drying Of Biomass
167. Evaluation Of Phosphorous Content In Indian Soyabean Varieties & Its Association With Oil Characteristics
168. Refinements And Optimization Of Smoke Evaluation Instrument For Environmental Investigations
169. Preparation Of Commercial Carbon Components From Solid Plastic Waste
170. Photo Biological Hydrogen Production
171. Extraction Of Biodiesel From Cotton Seed Oil
172. Manufacture Of Soaps Using Enzyme
173. Impact Of Illegal Waste Disposal On Man And Environment
174. Treatment Of Bio-Contaminated Aviation Fuel
175. Design,Fabrication And Testing Of Microbial Fuel Cell
176. Studies On Methods Of Breaking Azeotrope
177. Synthetic Studies On Triacontanol-A Plant Growth Regulator
178. Protein Extraction From Agro-Waste Bagasse
179. Investigation Of Growing Iysozyme Crystal By Sitting Drop And Hanging Drop Diffusion Method
180. Development Of An Innovative Low Cost Unit For Evaluation Of Noise Pollution
181. Utilization Of Waste Plastic And Rubber For Commercial Purpose
182. Extraction Of Super Sweet Steviol Gkycosides From Stevia Leaves
183. Cotton Supported Heterotrophic Denitrification Of Nitrate-Rich Water Using Pseudomonas Stutzeri
184. Biodiesel From The Byproduct Of Biopesticide From Custard Apple Seeds
185. Isolation And Identification Of Antidiabetic Agent From Garuga Pinnata Roxb
186. Microwave Assisted Transesterification Of Karanja Oil For The Production Of Biodiesel
187. Microwave Assisted Chemical Reactions
188. Manufacturing Of Synthetic Hydroxy Talcite
189. Slow Release Studies On Urea Briquettes
190. Mass Transfer And Kinetic Growth Studies In Denitrification Of Waste Water Using Pseudomonas Stutzeri
191. Production Of Biodiesel From Waste Oil
192. Extraction Of D-Limonene From Sweet Orange Peels
193. A Novel Approach For Quality Extraction Of Asparagus Racemosus-A Valuable Medicinal Extract
194. A Novel Approach For The Optimisation Of Parameters And Economic Evaluation For Effluent Treatment Of Dairy Plant
195. Biodiesel Production Using Hydrodynamic Cavitation Technique
196. Recovery Of Silver From Photographic Film Waste
197. Biosorption Of Chromium By Aspergillus Niger
198. Decolorisation Of Dye Waste Water By Adsorption On Alumina Adsorbent
199. Studies On Effect Of Seed Extract Of Annona Squamosa In Streptozotocin - Nicotinamide Induced Type Ii Diabetes Mellitus Rats
200. A Novel Approach For Management Of Domestic/Canteen Waste
201. Agglomeration Of Iron Ore Dust Fines Using Waste Calcia And Fly Ash Dust Fines
202. Removal Of Colour And Cod By Electrochemical And Electrocoagulation(Ec) Process From Distillary Spent Wash
203. Treatment And Reutilisation Of Medical Waste
204. Production Of Lactic Acid From Molasses
205. Removal Of Ni(Ii) Ions From Aqueous Solution Using Agricultural Waste: Adsorption On A Fixed-Bed Column
206. Dynamic Modeling And Simulation Of Fixed Bed Catalytic Reactor
8. Solar Pump
96. Pesticide Paint
138. Spirulina
hameeda asan
Can I get chemical engineering ideas based on food industry
I would like to know the construction & working(in detail) of magnetic door locks.
Few questions :
- The magnets in locks are temperory magnets or permanent ?
- If...
I have started from basics of RPi GPIO. With no hassle, Blinked LEDs. So, I know the basics.
But now I wanna dig down more & I couldn't find any...
Hai fnds.this s janaa frm madurai,tamil nadu.i m doing electrnics and communication engineering...i m so willing to do some innovations and i suppose to see ths site when i was...
My friend tried to stream live events from #Livestream.com. But the problem is that the video is buffering a lot. he is not able to stream at all. The video...
i jus want to clarify a doubt that in dc generator usually magnets are stable and the armature shaft is allowed to rotate.what ll happen if we do in reverse...
