File attachment in gmail not working
I have been trying to attach a file in my gmail account but its not done. Infact the pop up window also does not open. I tried it from 3 other gmail accounts also but there also the file could not be attached.
Plz check ur gmail and try to attach a file, does the same problem prevail with you also?
If yes, then what could be the solution?
What is the size of your file? With Gmail, you can send and receive messages up to 25 megabytes (MB) in size. Please note that you may not be able to send larger attachments to contacts who use other email services with smaller attachment limits.sweet_honeyI have been trying to attach a file in my gmail account but its not done. Infact the pop up window also does not open. I tried it from 3 other gmail accounts also but there also the file could not be attached.
If yes, then what could be the solution? -
whiz.kid.aniket
I guess you are attaching .exe files. Gmail doesnt allow you to send .exe files.sweet_honeyI have been trying to attach a file in my gmail account but its not done. Infact the pop up window also does not open. I tried it from 3 other gmail accounts also but there also the file could not be attached.
Kaustubh KatdareThe problem doesn't seem to me with the type of attachment (of course .exe is not allowed); but maybe with the browser itself. Could you try opening your gmail from a different computer; or say a different browser on your computer?
sweet_honey#-Link-Snipped-# no my file is not exceeding the limit. Its 75 kb only.
#-Link-Snipped-# the same problem is with other browser also. -
Did you check with other computer. ?sweet_honey#-Link-Snipped-# no my file is not exceeding the limit. Its 75 kb only.
[Prototype]Clear your cache. I am sure it'll solve the problem.
Anoop Kumar
+[Prototype]Clear your cache. I am sure it'll solve the problem.
if you are running latest Firefox/Chrome , try drag n drop file on attach link.
It should work -
I thought that at first; but it seems that the problem is reoccurring even with other browsers. I think that solution is worth trying.[Prototype]Clear your cache. I am sure it'll solve the problem.
#-Link-Snipped-# : Try clearing your browser cache. If you can tell which browser you're using someone can provide you with the exact place where you can do so. -
sweet_honeyI didn't try at other computer. I was trying it in my laptop.
I am using chrome and let me try to clear the cache. -
Kaustubh KatdareClearing the cache should help. If you experience the same error then it's possible that there's something's incorrect with your Gmail account. But as far as I know, Gmail does not apply rules account by account.
If clearing cache works, please let us know so that we will know what was causing the error and what really fixed it. -
sweet_honeyIts still not working...๐
I've emptied the cache...
When I'm clicking on the option 'attach file' no window opens for attachment..!!! -
sweet_honey
Not only with my account. I checked it with 2 more accounts but its the same problem with that also.The_Big_Kit's possible that there's something's incorrect with your Gmail account. -
Did you do a complete wipeout of the cookies, cache and history? That might help. Could you describe the steps you are taking and at what step things don't work? Is there any error displayed in browser?sweet_honeyIts still not working...๐
sweet_honey
Yes I completely cleared the history from 'clear all browsing data'.The_Big_KDid you do a complete wipeout of the cookies, cache and history?
In gmail the 'attach file' option doesn't respond to the pop up window for file attachment. -
Then that'd be a JavaScript issue. Is JavaScript turned on for your browser(s)? You could check in Chrome Settings -> Content Settings -> JavaScript.sweet_honeyYes I completely cleared the history from 'clear all browsing data'.
Update: I just found out that this could be an issue related to flash. Check if Flash is installed on your computer: #-Link-Snipped-# -
sweet_honey
Flash player is installed on the computer. plz tel me from where can i get chrome settings, I am unable to find it.The_Big_KYou could check in Chrome Settings -> Content Settings -> JavaScript.
[Prototype]As biggie suggested, now it seems, its issue with the javascript. For the workaround, just use gmail in "basic HTML" mode and send the emails.
[Prototype]
Type about:settings in the address bar and press enter. Actually, chrome://settings/ but about:settings will work as well.sweet_honeyFlash player is installed on the computer. plz tel me from where can i get chrome settings, I am unable to find it.
Otherwise, there's an option at right top corner, click it and you'll see settings there. -
sweet_honey
I restored the default settings from there but still the problem prevails.[Prototype]Type about:settings in the address bar and press enter.
Please tell me what about the javascript!! I don't know anythng about it. -
sweet_honey
Yes it worked in basic HTML...๐[Prototype]just use gmail in "basic HTML" mode and send the emails.
Thnx a lot... My important work was getting affected because of the attachment..
But why is this so?๐ -
Kaustubh KatdareSo it turns out to be the JavaScript error. I'd recommend uninstalling Chrome / Firefox and reinstall the latest versions. That should fix the errors. I'm on Mac and not sure whether the settings page is on the same location.
sweet_honey
Thanx Big_K.The_Big_KI'd recommend uninstalling Chrome / Firefox and reinstall the latest versions.
It worked after reinstallation..
It is a machine that uses a wire to cut the metals. Gears are made through this machine.
I know only this much about it..
Do anyone know more about...
*Engineering Trade:Chemical
*Occupation: Working
Work Experience: Production ,R&D Education
*Hobbies & Interests: Traveling
*Aim in life: Social worker
*I joined CrazyEngineers because: To be...
Hi,
All friends ,
My name is hinesh gohel.
I have completed my Diploma (ECE) with 66%.
I have just finished my b.tech (ECE), final semester exams, and waiting for...
Until now, it was not officially possible for Indian Android developers to sell their paid apps in the Google Play store. However, with a recent announcement on their blog, Google...
i am doing my B.E. mechanical engineering .......
how should we learnt the basics ?
how it help to me duriing my work?
