Drupal installation : how to create database?
Hi i am new to drupal and was installing it now in my system windows 7 64bit, its asking for creating database in 3 choices in the step2 of installation the choices are,
1.web browser based control panel(cpanel/plesk)
2.phpMyAdmin
3.Creating database directly(advanced users)
So i concluded obviously 3rd cannot be my choice and which one should i choose from the 1st two choices??
Suggest me the good one
2.phpMyAdmin
Kaustubh KatdareI'm assuming you've installed XAMPP or WAMP in order to create the installation environment. If yes, you should choose option 2. You can of course create a database directly using command line.
kalaivani MThanks 😀
Project Abstract / Summary : LPG gas is supplied in pressurized steel cylinders. As this gas is
heavier than air, so when it leaks from a cylinder it flows along...
Senss Technologies have concocted a hardware solution for two way call recording called Bluewire. The Bluewire Bluetooth call recorder is not just a standalone Bluetooth headset but it also allows...
Greetings of the day to the brains who did/do/will be doing automation projects.
I want to ask, from where you but the tools required for your project work? Online or...
Hi There,
I have been in the industry for 6+ years as a .net developer. Somehow I always wanted change my career as I am not a programmer by heart....
Project Abstract / Summary : Abstract
Whenever a hot fluid, like steam flows through a pipe from the place of generation to the point of use , there will be...
