Does Dual-booting or Multiple boot affect system in any way?
Hey, if we dual boot or multiple boot our machine with different OS, then does it affect RAM or hard disk at system start up?
or effect the performance in any way..?
Nayan GoenkaNo it does not affect your system adversely. But it is valid till you run not more than 3 OS on same machine. But then again it depends on your HDD capacity. It should not be too much clustered with all this stuff. Generally 2 OS can healthily Co-Exist on same system. If you want more, you can use VMWare.
Jeffrey ArulrajHard disk gets partitioned and so the available memory space for a system gets reduced other than that not much significant changes is seen
Cyborg 009No..only increases startup times.
Its a myth that system slows down due to multi boot. -
Jeffrey Arulraj
The start up time is purely dependant on the the RAM speed is there any link between the RAM utilisationCyborg 009No..only increases startup times.
Or is it due to too much stuff loaded into the RAM at startup? -
Cyborg 009
boot sector has to load different os...then selection between them..ConquerorThe start up time is purely dependant on the the RAM speed is there any link between the RAM utilisation
single os starts quicker than this.. -
Nayan GoenkaIf you have both OS on same bootmanager, like both windows, or two versions of linux on same bootloader, then it will deliver equal speed. If the computer has to always switch on the boot managers, it will increase the boot time.
Sanyam KhuranaBut when system just starts up, doesn't boot manager gets overloaded, or I mean, not any strain on it..?
Doesn't it effects BIOS? -
Jeffrey ArulrajNot really your boot loader is not going to occupy the entire RAM just a Few KBs and files of these size don't destroy anything unless they are malwares
Kaustubh KatdareTypically, if your system has multiple operating systems, the active boot-loader will ask you to select the operating system you want to boot your machine into. That adds a few seconds of delay to the overall boot time. The second thing that gets affected is your overall storage available to each operating system. Now this could not always be the case based on how the system storage is configured. But in normal situations - yes, the overall volume available for data storage for any individual OS will be lesser.
Virtualization, as someone mentioned above, is a different story altogether. VMWare, one of the popular Virtualization software let's your create a 'virtual machine' on the top of the host machine. Now, this *DOES* affect the overall performance of the host machine and even the virtual machine you've created. But this does not fall into the 'multiple boot' system we're talking about. -
Sanyam Khurana
Yeah, I've tried out VMWare, and I'm sure about it, that both OS are affected in that case, but I'm still not getting, if in virtual OS, Other hardware is affected, then how does, no problem in multiple boot, (except for the increased boot time)Kaustubh KatdareTypically, if your system has multiple operating systems, the active boot-loader will ask you to select the operating system you want to boot your machine into. That adds a few seconds of delay to the overall boot time. The second thing that gets affected is your overall storage available to each operating system. Now this could not always be the case based on how the system storage is configured. But in normal situations - yes, the overall volume available for data storage for any individual OS will be lesser.
Nayan GoenkaSanyam KhuranaYeah, I've tried out VMWare, and I'm sure about it, that both OS are affected in that case, but I'm still not getting, if in virtual OS, Other hardware is affected, then how does, no problem in multiple boot, (except for the increased boot time)
Multiboot doesn't run both or multiple operating systems at the same time. It utilized complete resources for each operating system whenever and whichever it loads. So no matter which operating system you use, RAM gives complete dedication to that environment.
In Virtual, you are hosting two operating systems and at the same time, dividing up the resources between them. This obviously affects performance. -
Kaustubh KatdareWhat he ^ said.
Sarathkumar ChandrasekaranWhether it increases boot time or startup time or anything I like to enjoy the benefits of multiple os excluding the negatives of it.
*increases startup time,
*slows down pc. -
Jeffrey Arulraj
Go for a better RAM configuration in your system thenCSK AUTOWhether it increases boot time or startup time or anything I like to enjoy the benefits of multiple os excluding the negatives of it.
*slows down pc.
That will allow you to be better of with the system you use -
pradeep.pawarThere should not be any problem in multiple or dual boot, I have ubuntu and windows 7, only confirm that you don't run out of space or don't have any partition left for storage and have ram as required by OS.
Sanyam Khurana
Yeah !!Nayan GoenkaMultiboot doesn't run both or multiple operating systems at the same time. It utilized complete resources for each operating system whenever and whichever it loads. So no matter which operating system you use, RAM gives complete dedication to that environment.
Got it..
Thanks all.. 😀
The whole world is crazy about smart phones specially the young minds are so occupied in upgrading from one mobile to another. They are finding n number of combinations to...
crash test is one of the modern day analysis procedure used to find whether the the vehicle is safer for driving or not and find the tolerance of vehicle towards...
What exactly is the loading effect of capacitor? I found this as one of the main applications of the capacitor in electronic circuits.
The book pointed that the capacitor in...
These devices provide a very high degree of isolation between the primary windigns and the secondary windings of the core. They are really robust and offer very high electrical/ galvanic...
For those who missed the earlier parts, there are the links to them.
Prologue
Part 1
Part 2
Part 3
Part 4
Greetings Readers, as mentioned earlier this post I...
