Conversion related problem:
I am preparing for my campus and while i am solving old placement papers i stumbled upon a problem. If anyone knows the answer please post it.
QUESTION:If the earth diameter was halved then what would be the duration of 1 day?
Ramani AswathWhat has that to do with the price of fish?
Our moon's diameter is about 27% of Earth's. Its day is 29 of Earth days. Length of the day has to do with the rotation of the object on its axis and not its size. -
Sarathkumar Chandrasekaranthanks for explanation @#-Link-Snipped-#
Sindhu Chowdary
I just got a small doubt.If earth's diameter is halved,then the duration for which the sun light is exposed to a particular area on the earth also decreases,which makes the day seems to be shortened.A.V.RamaniWhat has that to do with the price of fish?
Or if the diameter is halved and if we assume that the mass of the earth also decreased,then he velocity with which the earth rotates automatically increases.This is because to escape the gravitational pull of the sun.In that way also the day is shortened.
I don't know if my analogy is right or wrong.Correct me if I am wrong.
@#-Link-Snipped-# -
Ramani Aswath
If the speed of rotation does not change and remains 24 hours, the length of day will continue to be the same whatever the diameter.Sindhu ChowdaryI just got a small doubt.If earth's diameter is halved,then the duration for which the sun light is exposed to a particular area on the earth also decreases,which makes the day seems to be shortened.
@#-Link-Snipped-#
Reduced mass has no effect on the speed of rotation. It alters the speed along the orbit around the sun thereby changing the length of the year. -
Shashank Moghe#-Link-Snipped-# , Sir, I believe this is as good as giving the example of the ballet dancer rotating on the feet. If she is rotating with her hands extended, her speed is 'x', but if she brings her hands closer to her body, the speed of rotation increases. It has to do with conservation of angular momentum.
I believe the speed of earth will increase shortening the days (assuming mass of the earth still remains the same, essentially meaning the density is increased) as angular momentum needs to be conserved. Earth was formed (like all other planets) from cosmic gas clouds whose momentum gave earth the momentum it has. That momentum needs to be conserved.
I believe the angular momentum is given as L = m.r^2.w (m = mass of earth, r = radius of gyration, w = angular velocity). So as r goes to r/2, w must increase 4 fold, to conserve momentum.
Thus, if the radius of the earth becomes half of what it is today, one day will only last 6 hours. And that means lesser sleep for all of us 😔
#-Link-Snipped-# hope this helps.
Hi CEans i am little confused on the following question so i am destined here to find the real answer for the following questions.
1)What would be the throttle position...
*Engineering Trade: Electrical
*Occupation: Working
Work Experience: +1 year
*Hobbies & Interests: Economics, Puzzles, Playing keyboard, Photography, Chess...
*Aim in life: To start own business
*I joined...
Under three phase balanced system, current in the neutral conductor is supposed to be zero. So if neutral is not carrying the current then how the circuits are completing of...
Hi i have doubt in thermostat. thermostat is only used for know temperature or also used for heating the water or some liquids or also used for cooling water ....
Hi all,
I'm trying to find some simulation software to help guide me in a project I'm using to teach kids about the stabilisation capabilities of (mechanical) gyroscopes. Essentially I...
