Complicated Xilinx FPGA problem
Good morning,
My name is Moraali. I am currently doing a project, but I have a problem on the cable communication issue for more than 6 months.
FPGA is a Xilinx chip... You can get the info from #-Link-Snipped-#
I am using Virtex4 ML401 (LX type)
The data sheet is on (look on the top left at sheet 12 )
Description
So by using DMM, I found out that the PC and the Modem port is not loopback. Only the FPGA is loopback (pin 1,4and 6 is connected).
PC => Male Port
Modem => Female Port
FPGA => Male Port
I tested the cables (NOT the PC , NOT the MODEM , NOT the FPGA .... ONLY FROM THE CABLES USED) for three times and the result is below (for 9 Pin D Type ) :-
1) Presently what cable you are using in between PC and Modem? For your info, the flow control is none
WORK FINE
PC Modem
2 => 2
3 => 3
5 => 5
2) And also what cable in between FPGA and PC?
WORK FINE
PC FPGA
2 => 3
3 => 2
5 => 5
3) I just tested between FPGA and Modem
DOES NOT WORK FINE
FPGA Modem
2 => 2
3 => 3
5 => 5
I am not from engineering background. So, I am not so sure about labeling the Tx and Rx. I just assume that from the PC the 2 is Rx and the 3 is Tx. And 5 is definitely Gnd
a)Whether using any Hardware handshaking in between PC and Modem? - On both the 9 Pin D Type Connector check out the Pins
1- DCD
4 - DTR
6 - DSR
7 - RTS
8 - CTS
PC (Female) Modem (Male)
1 => 1
4 => 4
6 => 6
7 => 7
8 => 8
I only have you as my tutor. Please guide me. From the description ,
1)How can I rectify this problem?
2)Should I buy a cable?
3)what type of cable should I purchase for the FPGA-Modem?
Please reply to me as soon as possible.
My contact:-
Thank you
Description
PC => Male Port
FPGA => Male Port
WORK FINE
PC Modem
2 => 2
3 => 3
5 => 5
WORK FINE
PC FPGA
2 => 3
3 => 2
5 => 5
DOES NOT WORK FINE
FPGA Modem
2 => 2
3 => 3
5 => 5
1- DCD
4 - DTR
6 - DSR
7 - RTS
8 - CTS
1 => 1
4 => 4
6 => 6
7 => 7
8 => 8
My contact:-
Thank you
Kaustubh KatdareRemoving email as we want all the discussions to remain on CE so that larger audience can benefit from them.
sauravgoswamihi Moraali,from your post it seems the cables are fine,please explain in details about your problems??? what is the real issues which is hampering your desire result????
moraaliGood morning,
Before I start, I would like to thank you for replying. My problem is simple, but (because I am not from enginnering background) I am not sure how to rectify this problem.
This is my problem:-
1) When I connect my FPGA to the PC , I can perceive they communicate perfecly via hyperterminal.
2) When I connect my Modem to the PC, I can perceive they communicate perfecly via hyperterminal.
3) But when I connect my FPGA to the Modem , I found out they are not communicating.
I can not see what is the problem because they are connected to the PC (hyperterminal is not use).
If you want to more , this below link (I posted to Xilinx forum , but they did not reply me until now) will explain to you the details of my project.
Try to go through it carefully. If you want anything please reply to me as soon as possible.
Thank you. -
debu@moraali: The problem can lie in two places:
- The baud rate configuration is incorrect. Many modern modems rely on handshaking signals (RTS & CTS) to determine the auto-baud. There is a possibility that you are not generating these correctly on your FPGA.
- The Rx and Tx lines are not crossed. Possibly, the cable which you are using for your modem is meant for connecting the modem to your PC. And so is the D9 port on your virtex board.
This is probably the configuration of the cable:
PC Serial Port------------------Modem D9 Port | Modem Internals
Rx -------------------------------Tx-------------\/---Rx
Tx -------------------------------Rx-------------/\---Tx
The same cable, if used with the Virtex board will cause the Rx to connect with Rx, and Tx to connect with Tx, as shown below.
Modem D9 Port ----------------Virtex Board D9 Port
Tx--------------------------------------Tx
Rx--------------------------------------Rx
Now, this won't work.
This is the Configuration that you require:
Tx----------------\/--------------------Tx
Rx----------------/\--------------------Rx
Regards,
Debu ๐ -
moraaliGood evening,
Thank you for replying. I am not from engineering background.
1) May I know what should I do to solve the first question?
2) And for the 2nd question, should the cable(you proposed) be null modem?
Thank you very much. -
debu@moraali: If the first problem exists, then you will need to implement the handshaking signals in your verilog/vhdl code. Refer to the #-Link-Snipped-# for more information.
Yes, if the second problem exists, a null modem cable should fix it.
Regards,
Debu ๐ -
Based on above, I like to show the cable connection. I am not sure whether it should be null modem or not. If it should , please let me know.
Basically
1) Modem Port = No Loopback
2) FPGA Port = Loopback (pin 1,4 and 6 are connected together)
So..... should I buy this type of cable?
๐
FPGA ==> Modem
(Female) ==> (Male)
1 ==> 1
2 ==> 3
3 ==> 2
4 ==> 4
5 ==> 5
6 ==> 6
7 ==> 7
8 ==> 8
9 ==> 9
If I am getting it wrong , please correct me. Please reply to me as soon as possible.
Thank you . -
debu@moraali: Yes, the cable you have shown is a null modem cable, that is what you need.
Regards,
Debu ๐ -
Thank you very much for your reply. Really appreciate it. I want to send you some pictures. How can I send to you, becasue I can not find any attachment link in this forum?
Thank you -
Kaustubh KatdareMoraali , in order to post the pictures in posts, please first upload them to imageshack and then post the complete URL (ending in file extension) in the alert box that pops up when you click button in the post editor box.
๐ -
moraaliGood morning Mr Debu,
Thank you for your reply. Really appreciate your guide.I am not from engineering , so if my question is annoying , please forgive me. I am just a learner
Based on the Xilinx ML401, I know that the board only support ONE serial port RS232 Db9 (the link is below).
Xilinx ML401 [Microblaze Linux/Qemu/U-Boot wiki]
I am planning to create another serial port by using the Expansion Header (if I am wrong please notify me) as shown in the diagram below
1)
I connected the
Power = 5V (not sure, as the above diagram show 3V. Am I correct?)
Ground = Gnd
Tx = J4 (Check the link below)
Rx = J2
Then I did the MAX2323 as shown as the diagram below. Please check, I am not sure whether it is correct or not.
3) Based on the diagram below, I am planning to connect the cable to the PC.
What type of cable should I use as there is no loopback when I try to connect through Expansion Header as show as diagram ?
I am planning to use a male cable port when connecting to MAX2323 for easy shouldering. Would it be a good idea?
PC = Female Port Cable
ExpandionHeader_MAx2323= Male Port Cable
So sorry for to much questions. Please reply to me as soon as possible. The data sheet is in the below link.
Thank you. -
debu@moraali: Your FPGA doesn't seem to be generating any handshaking signals (atleast according to the schematic, the handshaking signals are looped). Your modem will require these for calcuating the auto-baud. Implement the handshaking signals in your code, and then connect the RI, DCD, RTS and CTS lines, via your MAX232, to the modem.
Hope this helps,
Regards,
Debu ๐ -
Ashraf HZSorry to be off topic, but.. debu, you have a great blog!
Thank you for your previous reply.
I am not sure what this mean clearly
I am not from engineering background. Could you explain how to do it step by step?
For your info:-
1) For FPGA-Modem via serial port , use this cable
FPGA ==> Modem
(Female) ==> (Male)
1 ==> 1
2 ==> 3
3 ==> 2
4 ==> 4
5 ==> 5
6 ==> 6
7 ==> 7
8 ==> 8
9 ==> 9
2) For FPGA-PC via Expansion Header, use this cable
FPGA ==> PC
(Male) ==> (Female)
1 ==> 1
2 ==> 2
3 ==> 3
4 ==> 4
5 ==> 5
6 ==> 6
7 ==> 7
8 ==> 8
9 ==> 9
Thank you. -
I am a bit confuse
1)
"Your FPGA doesn't seem to be generating any handshaking signals (atleast according to the schematic, the handshaking signals are looped). "
That means I not need to buy the proposed cable for FPGA-Modem connection?
2)
How can I do this? Should I change the VHDL code?
This is the FPGA RS232 VHDL generated code
-- rs232_uart_wrapper.vhd
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
library UNISIM;
use UNISIM.VCOMPONENTS.ALL;
library xps_uartlite_v1_00_a;
use xps_uartlite_v1_00_a.all;
entity rs232_uart_wrapper is
port (
SPLB_Clk : in std_logic;
SPLB_Rst : in std_logic;
PLB_ABus : in std_logic_vector(0 to 31);
PLB_PAValid : in std_logic;
PLB_masterID : in std_logic_vector(0 to 0);
PLB_RNW : in std_logic;
PLB_BE : in std_logic_vector(0 to 3);
PLB_size : in std_logic_vector(0 to 3);
PLB_type : in std_logic_vector(0 to 2);
PLB_wrDBus : in std_logic_vector(0 to 31);
PLB_UABus : in std_logic_vector(0 to 31);
PLB_SAValid : in std_logic;
PLB_rdPrim : in std_logic;
PLB_wrPrim : in std_logic;
PLB_abort : in std_logic;
PLB_busLock : in std_logic;
PLB_MSize : in std_logic_vector(0 to 1);
PLB_lockErr : in std_logic;
PLB_wrBurst : in std_logic;
PLB_rdBurst : in std_logic;
PLB_wrPendReq : in std_logic;
PLB_rdPendReq : in std_logic;
PLB_wrPendPri : in std_logic_vector(0 to 1);
PLB_rdPendPri : in std_logic_vector(0 to 1);
PLB_reqPri : in std_logic_vector(0 to 1);
PLB_TAttribute : in std_logic_vector(0 to 15);
Sl_addrAck : out std_logic;
Sl_SSize : out std_logic_vector(0 to 1);
Sl_wait : out std_logic;
Sl_rearbitrate : out std_logic;
Sl_wrDAck : out std_logic;
Sl_wrComp : out std_logic;
Sl_rdDBus : out std_logic_vector(0 to 31);
Sl_rdDAck : out std_logic;
Sl_rdComp : out std_logic;
Sl_MBusy : out std_logic_vector(0 to 1);
Sl_MWrErr : out std_logic_vector(0 to 1);
Sl_MRdErr : out std_logic_vector(0 to 1);
Sl_wrBTerm : out std_logic;
Sl_rdWdAddr : out std_logic_vector(0 to 3);
Sl_rdBTerm : out std_logic;
Sl_MIRQ : out std_logic_vector(0 to 1);
RX : in std_logic;
TX : out std_logic;
Interrupt : out std_logic
attribute x_core_info : STRING;
attribute x_core_info of rs232_uart_wrapper : entity is "xps_uartlite_v1_00_a";
end rs232_uart_wrapper;
architecture STRUCTURE of rs232_uart_wrapper is
component xps_uartlite is
generic (
C_FAMILY : STRING;
C_SPLB_CLK_FREQ_HZ : INTEGER;
C_BASEADDR : std_logic_vector(0 to 31);
C_HIGHADDR : std_logic_vector(0 to 31);
C_SPLB_AWIDTH : INTEGER;
C_SPLB_DWIDTH : INTEGER;
C_SPLB_P2P : INTEGER;
C_SPLB_MID_WIDTH : INTEGER;
C_SPLB_NUM_MASTERS : INTEGER;
C_SPLB_SUPPORT_BURSTS : INTEGER;
C_SPLB_NATIVE_DWIDTH : INTEGER;
C_BAUDRATE : INTEGER;
C_DATA_BITS : INTEGER;
C_USE_PARITY : INTEGER;
C_ODD_PARITY : INTEGER
port (
PLB_masterID : in std_logic_vector(0 to (C_SPLB_MID_WIDTH-1));
PLB_BE : in std_logic_vector(0 to ((C_SPLB_DWIDTH/8)-1));
PLB_wrDBus : in std_logic_vector(0 to (C_SPLB_DWIDTH-1));
Sl_rdDBus : out std_logic_vector(0 to (C_SPLB_DWIDTH-1));
Sl_MBusy : out std_logic_vector(0 to (C_SPLB_NUM_MASTERS-1));
Sl_MWrErr : out std_logic_vector(0 to (C_SPLB_NUM_MASTERS-1));
Sl_MRdErr : out std_logic_vector(0 to (C_SPLB_NUM_MASTERS-1));
Sl_MIRQ : out std_logic_vector(0 to (C_SPLB_NUM_MASTERS-1));
RX : in std_logic;
TX : out std_logic;
end component;
begin
RS232_Uart : xps_uartlite
generic map (
C_FAMILY => "virtex4",
C_SPLB_CLK_FREQ_HZ => 100000000,
C_BASEADDR => X"84000000",
C_HIGHADDR => X"8400ffff",
C_SPLB_AWIDTH => 32,
C_SPLB_DWIDTH => 32,
C_SPLB_P2P => 0,
C_SPLB_MID_WIDTH => 1,
C_SPLB_NUM_MASTERS => 2,
C_SPLB_SUPPORT_BURSTS => 0,
C_SPLB_NATIVE_DWIDTH => 32,
C_BAUDRATE => 9600,
C_DATA_BITS => 8,
C_USE_PARITY => 0,
C_ODD_PARITY => 0
port map (
SPLB_Clk => SPLB_Clk,
SPLB_Rst => SPLB_Rst,
PLB_ABus => PLB_ABus,
PLB_PAValid => PLB_PAValid,
PLB_masterID => PLB_masterID,
PLB_RNW => PLB_RNW,
PLB_BE => PLB_BE,
PLB_size => PLB_size,
PLB_type => PLB_type,
PLB_wrDBus => PLB_wrDBus,
PLB_UABus => PLB_UABus,
PLB_SAValid => PLB_SAValid,
PLB_rdPrim => PLB_rdPrim,
PLB_wrPrim => PLB_wrPrim,
PLB_abort => PLB_abort,
PLB_busLock => PLB_busLock,
PLB_MSize => PLB_MSize,
PLB_lockErr => PLB_lockErr,
PLB_wrBurst => PLB_wrBurst,
PLB_rdBurst => PLB_rdBurst,
PLB_wrPendReq => PLB_wrPendReq,
PLB_rdPendReq => PLB_rdPendReq,
PLB_wrPendPri => PLB_wrPendPri,
PLB_rdPendPri => PLB_rdPendPri,
PLB_reqPri => PLB_reqPri,
PLB_TAttribute => PLB_TAttribute,
Sl_addrAck => Sl_addrAck,
Sl_SSize => Sl_SSize,
Sl_wait => Sl_wait,
Sl_rearbitrate => Sl_rearbitrate,
Sl_wrDAck => Sl_wrDAck,
Sl_wrComp => Sl_wrComp,
Sl_rdDBus => Sl_rdDBus,
Sl_rdDAck => Sl_rdDAck,
Sl_rdComp => Sl_rdComp,
Sl_MBusy => Sl_MBusy,
Sl_MWrErr => Sl_MWrErr,
Sl_MRdErr => Sl_MRdErr,
Sl_wrBTerm => Sl_wrBTerm,
Sl_rdWdAddr => Sl_rdWdAddr,
Sl_rdBTerm => Sl_rdBTerm,
Sl_MIRQ => Sl_MIRQ,
RX => RX,
TX => TX,
Interrupt => Interrupt
end architecture STRUCTURE;
This is the system stub
-- system_stub.vhd
library IEEE;
library UNISIM;
entity system_stub is
port (
fpga_0_RS232_Uart_RX_pin : in std_logic;
fpga_0_RS232_Uart_TX_pin : out std_logic;
fpga_0_LEDs_4Bit_GPIO_IO_pin : inout std_logic_vector(0 to 3);
sys_clk_pin : in std_logic;
sys_rst_pin : in std_logic
end system_stub;
architecture STRUCTURE of system_stub is
component system is
port (
end component;
begin
system_i : system
port map (
fpga_0_RS232_Uart_RX_pin => fpga_0_RS232_Uart_RX_pin,
fpga_0_RS232_Uart_TX_pin => fpga_0_RS232_Uart_TX_pin,
fpga_0_LEDs_4Bit_GPIO_IO_pin => fpga_0_LEDs_4Bit_GPIO_IO_pin,
sys_clk_pin => sys_clk_pin,
sys_rst_pin => sys_rst_pin
Below is the hdl folder
Which part of the VHDL coding should I alter or modify?
Thank you -
debu@moraali: You will need to write a module for auto-baud generation (as I stated before). Alternatively, you could use #-Link-Snipped-# for the same. And, yes, you will still need a null modem cable.
Best of luck for your project!
Regards,
Debu ๐ -
Thank you for replying .
Are you mentioning the commication through Expansion Header only ?
Overall , Do you mean this ?
For FPGA-Modem through Serial Port , I just use null modem cable that you proposed.
And the FPGA-Modem through Expansion Header , I also use the null modem that you proposed and have to change the code.
Thank you -
debu@moraali: In order to communicate with the modem, you need to use a null modem cable and have you FPGA generate the auto-baud signals.
Regards,
Debu ๐ -
Thank you sir for your reply. I will try.
But do you have any Auto_Baud in vhd? I am not expert in Verilog. Need to learn , and it might take time.
Thank you -
debu@moraali: No, I haven't implemented auto-baud an any FPGA. I posted a link a few posts back of a project which did. You can use that as your reference.
Regards,
Debu ๐
It's official!
CE get's its own official blog. Read the first post (announcement) ->
VoiCE
Do not forget to let us know your thoughts, ideas through your comments.
โ
I just saw the new landing page ... good show!
On winning and losing
"She was right, and I knew it. I apologized, and gave some thought to winning and losing, and how to handle each. When you win, you...
Hello Frnds...
My name is rishabh.I m pursuin my B.Tech frm NIT Allahabad(if u knw..lol)..
Well!!i m in 2nd year.I dont have many ideas abt discipline of engineering...bt yess watever...
Seems Microsoft gets new people for marketing, different & very nice advertisment for their Office 2010..the movie ๐
The technical preview seems nice but I'll keep sticking with OpenOffice.
Office...
