Check cholesterol using iPhone with smartCARD accessory
If you're concerned about sinusoidal HDL & LDL cholesterol levels in your bloodstream, you need not visit your pathologist frequently. All you need is an iPhone and a new attachment called smartCARD - smartphone Cholesterol Application for Rapid Diagnosis). A special app installed in the phone will perform all the analysis and inform you about the cholesterol levels in about a minute. We need not say that the device will save you a lot of money in the longer run.
DIY cholesterol testing devices have existed for quite some time now; but this is the first time that a small iPhone accessory will do all the complex job. Thanks to the amazing engineering work done by scientists at the Cornell University who've developed smartCARD. The technology this device uses is even more interesting.
The device needs your blood, a tiny drop of it, to be placed on a special strip that changes its color depending on the biomarkers present in the drop of blood. This stip is then fed to the smartCARD attached to your iPhone. iPhone's built-in flash will illuminate the strip momentarily so that iPhone's camera can capture the image. A special app designed to perform image analysis will determine the levels of cholesterol and provide you with an exact reading. It takes only about a minute to do all of that.
The team of scientists behind smartCARD says that the accessory is ready for commercial launch in its current form. Note that the app won't yet tell you the good and bad cholesterol information just yet; but be informed that the team's already working on it.
Do check out the details on the source link below. Do you think the end of pathology labs is nearing?
Kanagasundaram KuppusamyNice application for apple phone user.special application cost is more or less?
If any android device relevant appliction is there in google market?
A team of researchers at MIT (Massachusetts Institute of Technology) has developed a new device called WiTrack, that is a 3D motion tracking system which functions even through walls. It...
How does a wired connection connect to radio wave communication and vice-verse?
Nokia had launched the Nokia Asha 502 smartphone back in October along with Nokia Asha 500 and Asha 503 at the Nokia World event in Abu Dhabi. Available in the...
Realise a simple channel coding scheme for FEC using RS coding and draw its SNR curve. If any one know reply me....
A lot of people want to use their Java and general programming skills to develop apps for Android platform. Therefore, you see a lot of Android app development training institutes...
