centrifugal pump
what will happen if a centrifugal pump is used for taking water into a level below its center line (certain flow rate is required). Usually performance curve is available only for positive differential heads. so how we will calculate discharge flow rate
Ramani AswathIf the suction level is below discharge level it is still a positive head. You have to add the frictional drop from intake to output to get the total operating head. If the discharge point is below the water level, why do you need a pump at all?
Shaheen MongamDischarge is below water level. Water will flow due to gravity. But I need a particular flow rate which is possible only with a pump( assume a case where gravity flow will be very less and hence I need something to boost)
Ramani AswathIt depends on the area available for flow. In a river the head available is very small but the area for flow is large. Hence flow is large.
As said above the pressure drop in the pipeline will also come into the picture. You can add a flow control valve on the delivery side to add as much resistance as you want.
For a project in Nilgiris we designed a gravity flow system to get process water from a stream nearby by tapping the stream a few meters above the factory. -
Shaheen MongamU didn't get my question. I need to transfer certain amount of water which is higher than what gravity can transfer( given- increasing the pipe size is not feasible). So providing a pump is the only option to increase its velocity. So a centrifugal pump is an option? How to get its characteristics then since the differential head will be negative
Ramani AswathPlease go through the reply. By putting a flow control valve on the outlet one can get any positive differential head one wants.
A centrifugal pump is eminently suitable.
Panasonic India has put up their new smartphone for sale in the country. The Panasonic P75 was first spotted on e-commerce website Snapdeal where it is currently retailing at Rs....
ASUS recently launched two new laptops A540LA and R558UR for Indian markets at the price tag of Rs.20990 and Rs.43990 respectively. Both the devices are equipped with USB Type-C port...
I love crazyengineers.com I believe this is the right place for me to be because I love learning a lot. I would like to learn about website designing, I love...
Hello CEans
Myself Jassem from Jaipur , I just completed graduation in btech(IT).
I am going to Bangalore in next month to make career and sharp my IT skills as...
Remember the LG X Series of smartphones that debuted at Mobile World Congress with the X Cam and X Screen smartphones? We don’t either because these smartphones did not manage...
