CCFL 2.0 - Crazy Cricket Fantasy League season 2
CCFL 2.0 "The Ashes"
Australia @ Englandβ
Hi all crazy CEans across the world! Australia @ Englandβ
Welcome to another fantastic & crazy season of * Crazy Cricket Fantasy League - CCFL 2.0*
This league will be played for The Ashes tour only. The both teams will play 5 test matches series.
The tour fixture is as follows:
1st test : 8-12 July
2nd test : 16-20 July
3rd test : 30 July-3 Aug
4th test : 7-11 Aug
5th test : 20-24 Augβ
All matches will start from 10:00 GMT.1st test : 8-12 July
4th test : 7-11 Aug
So what you have to do is just simple, make your own team from the players of the both team. They score run or take wicket or even they take the stunning catch, you will get points for each. At the end of the series, the CEan with highest points will be the winner. The winners will get a special CD on Environment Awareness. The CD will be shipped only in India.
PS : Image courtesy godfather.
RajdeepCEYou have to follow simple rules to take part in Fantasy League.
Code of Conducts
1. You have to select total of 12 players from the list given in next post.
2. You have to select 6 player from England & 6 from Australia.
3. You have to select 5 Batsman, 4 Bowler, 1 Wicketkeeper, 2 All Raounder from the list given in next post.
4. You have to select one player as your *Crazy Player* and one as your *Duffer Player*. The points of Crazy Player will be DOUBLED & points of Duffer Player will be HALFED.
5. After you have created your team,Post it here or PM me,So be careful & read rules properly.
6. After end of each test match, * The Transfer Window * will be open. Here You can change any of your 3 players only. To use transfer window you have to PM me or post in the format given below in next post. and yes again be careful you have to change your players according to the rules. You can also change your Crazy & Duffer player. The transfer window will be closed on the match day at 5:30 GMT.
7.The last date for submitting your main team is 8 July, 5:30 GMT.
8. You can Change your team by unlimited times before deadline. π i.e you can post your team now and no problem you can change it any time before deadline..π but if you edit your post(team) or reply after deadline...team will be Discarded..
9. The final decision will be of The Admin, The Mods & CCFL organizing team.
10.Final Scorecard will be of Cricinfo.
Rules for scoring points
1. Points scored by runs:
1 run = 1 point.
Bonus points :
- for 50,100,150,... runs in an Innings, 5,15,25,... points respectively.
- for 100,200,... runs in a Match, 10,20,... points respectively.
e.g:
Ponting Scores..
60 Runs in First Inning: 60+5
100 Runs in Second Inning: 100+5
So total run in match is 160 so Final Points: 60+5+100+5+10=180 points he Scored
2. Points scored by wickets:
for each wicket, 25 points.
Bonus points:
- for 5 or more wicket in an Innings, 50 points.
- for 5 or more,10 or more,... wickets in a Match, 25, 50,... points respectively.
e.g
J Anderson Takes...
5 Wickets in First inning : 125+50
5 Wicket in Second inning : 125+50
Total 10 Wicket in a Match..total Score 125+50+125+50+50=400 points he scored
3. Points scored by other
- 1 catch = 5 pts.
- 1 stumping = 5 pts
4. Extra points:
If your Players Get.
- Man of the Match = 50 pts
- Man of the Series = 100 pts
For any queries contact CCFL organizing team:
#-Link-Snipped-#,#-Link-Snipped-#,#-Link-Snipped-#
, #-Link-Snipped-#. -
RajdeepCEPlayers list:
Batsmen
Australia - MEK Hussey, MJ Clarke, MS North, PJ Hughes, RT Ponting, SM Katich.
England - AJ Strauss, AN Cook, IR Bell, KP Pietersen, PD Collingwond, RP Bopara.
Bowler
Australia - B Lee, BW Hilffenhaus, MG Johnson, NM Hauritz, PM Siddle, SR Clark
England - Harmison, G Onions, JM Anderson, MS Panesar, R Sidebottom, SCJ Broad.
Wicket keeper
Australia - B Haddin, GA Manou
England - MJ Prior
All Rounder
Australia-AB McDonald, SR Watson.
England-A Flintoff, GP Swann
Sample Team(also remember the format for submitting your team)
Batsmen : MEK Hussey, MJ Clarke,RT Ponting, KP Pietersen, PD Collingwond
This is just a sample team. Make your own team by reading rules carefully.
Bowler :BW Hilffenhaus, MG Johnson, JM Anderson, MS Panesar
Wicketkeeper : MJ Prior
AllRounder:GP Swann, AB McDonald.
Crazy Player : MJ Clarke
Duffer Player : GP Swann
Sample for using transfer window
MJ Prior = B Haddin
You have to follow rule 2 & 3 while using the transfer window.
MG Johnson= B Lee
MS Panesar = AU Rashid -
RajdeepCETeam of the Ceans:
RajdeepCE :--->> Reckless
Hussey =
146
Clarke =
( 138 X 2 )=276
Ponting=
94
Strauss=
255
Collingwood=
48
Johnson=
111
Hillfenhaus=
110
Onions=
Broad=341
Watson=
84
Flintoff=59
MJ Prior=
( 32 / 2 )=16
Crazy - Clarke, Duffer - MJ Prior
Total=
1540
godfather :--->> United XI
Troat=190
Ponting=
94
Clarke=
( 138 X 2 )=276
Strauss=255
Collingwood=
48
Johnson=
111
Hillfenhaus=
110
Andersen=
15
Broad=341
Watson=
84
Flintoff=59
Haddin=
( 55 / 2 )=27.5
Crazy - Clarke, Duffer - Haddin
Total=
1610.5
priyank_180 :--->>Shockers XI
Ponting=94
North=
123
Katich=
108
Bell=
81
Collingwood=
48
Johnson=
( 111 X 2 )=222
Hilfenhaus=
110
Andersen=
15
Broad=341
SR Watson=84
Flintoff=
59
MJ Prior=
( 32 / 2 )=16
Crazy - Johnson, Duffer - MJ Prior
Total=
1301
milan25 :--->> Magneto XI
Katich=
108
Ponting=
94
Clarke=
(138 X 2) = 276
Strauss=
255
Collingwood=48
Onions=
Johnson=
111
Andersen=
15
Hillfenhaus=
110
Watson=
84
Swann=
311
Prior=
( 32/2 )=16
Crazy - Clarke, Duffer - Prior.
Total=
1428
English-scared :---> Scary XI
Hussey=
146
Ponting=
94
Clarke=
138
Strauss=
255
Collingwood=
48
Hillfenhaus=
110
Johnson=
111
Andersen=
15
Hauritz=
Flintoff=
( 59 X 2 )=118
Swann=
311
MJ Prior=
( 32/2 )=16
Crazy - Flintoff, Duffer - Prior.
Total=
1362
crazyboy :--->> Crazy Team
Clarke=
(138 X 2)=276
Troat=190
Strauss=
255
Collingwood=48
North=
123
Johnson=
111
Hilffenhaus=
110
Andersen=
15
Onions=0
Swaan=311
Watson=
84
Haddin=
( 59/2 )=27.5
Crazy - Clarke, Duffer - Haddin.
Total=
1550.5
Cranky :--->> Lazy XI
Hussey=
(146 X 2)=292
Clarke=
138
Ponting=
94
Collingwood=48
Katich=
108
Johnson=
111
Andersen=
15
Sidebottom=
Broad=
341
Flintoff=
(59/2)=29.5
Swann=311
Haddin=
55
Crazy - Hussey, Duffer - Flintoff
Total=
1542.5
CrazyGirl :--->> Chasers XI
Bell=81
Clarke=
138
Ponting=
94
Trott=
190
Strauss=
255
Johnson=
(111 X 2)=222
Hillfenhaus=
110
Siddle=
136
Broad=
341
watson=
84
Swann=
311
Haddin=
(55/2)=27.5
Crazy - Johnson, Duffer - Haddin
Total=
1989.5
Cowboy - Cowboy XI
Strauss
=255
Katich
=108
Clarke
=138
Ponting=
94
Collingwood=(48/2)=24
Johnson
=111
Andersen
=( 15 X 2 ) = 30
Lee
=0
Sidebottom=0
Watson
=84
Swann=
311
Prior
=32
Crazy - Anderson , Duffer - Collingwood
Total=1187
RajdeepCEPlayer Point Table
Strauss - 255
Cook - 39
Bell - 81
Collingwood - 48
Trott - 190
Prior - 32
Flintoff - 59
Broad - 341
Swann - 311
Andersen - 15
Harmison - 87
Watson - 84
Katich - 108
Ponting -
94
Hussey -
146
Clarke -
138
North - 123
Haddin - 55
Johnson - 111
Siddle - 136
SR Clarke - 6
Hilfenhaus - 110 -
RajdeepCELeaderboard
Final Match:
Chasers XI = 1989.5
United XI = 1610.5
Crazy XI = 1550.5
Lazy XI = 1542.5
Reckless XI = 1540
Magneto XI = 1428
Scary XI = 1362
Shocker XI = 1301
Cowboy XI = 1187
The Ashes Leaderboard
United XI--->6416
Crazy XI--->6146.5
Reckless XI--->6102.5
Magneto XI--->5976.5
Chasers XI--->5700
Lazy XI--->5577.5
Shockers XI--->5378
Scary XI--->5322
Cowboy XI--->2973.5 -
RajdeepCESo what are you waiting for?
Create your own fantasy team now!!
Be careful & read rules before creating and posting the team.
All the best luck to all CEans and also to me cause I am also preparing my own fantasy team.
ππ -
Anil JainGood start Rajdeep & GF. Looking forward for a successful CCFL 2.0. As discussed I am all game to give my best suggestions to help you out in making this a big success. Here are a few suggestions / questions from my side.
- for 50,100,150,... runs in an inning, 5,15,25,... points respectively.
For 100 runs its 15 points or 10 points ?? π
- for 100,200,... runs in an inning, 10,20,... points respectively.
You have to select 6 batsman, 5 bowler, 1 wicketkeeper from the list given in next post
What about all-rounder category???
5. Once team submitted can not be edited. So be careful & read rules propely.
What if the player of my team get injured in between th series... Hey wait wait !! does you mean to say team is final for for one match only, not for series??
- for more than 5 wicket in an innings, 50 points.
If a player takes 5-5 wickets in both innings how many bonus points he will get..??
- for more than 5,10,... wickets in a match, 25, 50,... points respectively.
Would it be 50+50+50 = 150 + (25*10)
- 1 runout = 10 pts
What if two players are involve in run-out?? both will get the points.
Anyparticular rational behind this boundation??
3. You have to select 6 batsman, 5 bowler, 1 wicketkeeper from the list given in next post.
-CB -
RajdeepCEThanks crazyboy for your support.
Here is answer to all your queries:1. I just misspelled there. I will edit it. There should be " 100,200,... in a match ".
2. I wanted to put allrounder category, but then I merged it with other category cause I wanted to make team selection easily. I merged it with batsmen.
3. Its your luck buddy. I want to reduce workload on organizing team. So 12 players for the whole series. I will later updated the rules regarding about your this concern. Nice suggestionπ
4. Yes thats it!
5. The scoreboard will be official for runout.
6. I just wanted that everyones fantasy team is balanced with the player of both teams. Regarding your second query I mentioned that earlier that I want to make team selection easy.
Any other queries? -
Anil Jain
Ha Ha Ha...
So for me, once I select my team before 8th of July, this thread is just a waste thread for me. :evil: Nothing to do right after one time selection and then cribbing??
Are you starting this thread for orgnizing team??? π
Broad / Lee / Johnson / Swann are bowling allrounder. They do cool batting as well...
Watson / Flintoff / Pitersonn / Bopara / Collingwood are purely alrounders. How can you consider freddi as a batsman only? He is truly the best bowler of English team. Man create a alrounder segmant.
Suggestion:
4 Batsman / 4 Bowler / 1 keeper - compulsory.
3 - player of your choice.
Another suggestion to make it more interesting.
Give ranking / points to all the players (with organisers concern). Give some initial XXXX points to all CE members and then ask them to select players from those XXXX points. So that team would be mix n match of good and normal players.
That was just an suggestion!!! way to go.
-Cheers !!
-CB -
RajdeepCEThats fine crazyboy. You got nice points. I am implementing your suggestion no 1 immediatley.
Suggestion 2 is also good but to make team selection easily, we will leave this. For suggestion 3, its good initiative, but we need to calculate points of all players carefully and according to the total points we have to give starting fund. So we will implement these two suggestions in future.
So CEans, rules are finalized now. Go ahead & create your fantasy team now. -
Anil JainThanks for considering my points
:rolling eyes: why are we in such a hurry π
-CB -
Anil Jain
RajdeepCENo problem CB, take your time but dont forget the deadline.
Anil JainI forgot... for sure. Sorry !!!
-CB -
Harshad ItaliyaNice initiative RajdeepCE.
@CB:- Thanks for making Rule interesting π
I will post my dream eleven soon.
let me go through Rules once again.. -
Harshad ItaliyaI had PMed My Team.
priyank_180i have post my team rajdeep.. check it out..
priyank_180realy, ti's tough job to select a team, mean select a good team.
Harshad Italiya@ Priyank...you also need to be lucky other than selecting good team. π
Milan25"I had submitted my team"
Magneto12
Batsmen
Australia - MEK Hussey, MJ Clarke,SM Katich,RT Ponting
England - AN Cook
Bowler
Australia - B Lee,MG Johnson
England - JM Anderson,MS Panesar
Wicket keeper
England - MJ Prior
All Rounder
Crazy Player : A Flintoff
Duffer Player :GP Swann -
Anil JainNice and interesting rules... Hope that it will be a big success.... Can we add one point for clearance..
The Transfer Window will be closed during a test.. It will be open only after the test and will close before the freezing date
I have submitted my team via PM π
-CB -
Harshad Italiya@CB yes you are right Transfer window open only between Test matches and it got freeze before match the transfer that done after starting match will be discarded..
@Rajdeep you can copy the same line from CB to Rules.. edit the rules... -
RajdeepCEYes CB, transfer windows will be opened only during gapes between test matches. I will simplify the rule so CEans can take advantage of it.
crankyGreat post..
one more suggestion..why not penalise too..like extra runs,then some negative points..
similarly for
duck out
missed catches
less than 10 runs in two innings by an openerπ -
Harshad ItaliyaMissed catches.... how can we know about this?
for that we have to watch from start to end... 5 days π π
Good Suggestions we will surly implement these in next Series of india..
have you created your team!? π
come on don't miss this time cranky π -
RajdeepCEIt is a really good suggestion & looks like it is close to the real cricketing. But it will increase workload on CCFL organizing team, thats why we are not implementing negative pointing system. Though you will enjoy here. Waiting for your team, cranky!
cranky
ah..i didn't think that way..workload will be more..godfatherMissed catches.... how can we know about this?
my team..coming soon π
is team name necessary -
priyank_180@godfather... you are right, i know, it's depends on my luck...
Harshad Italiya
if you come with your name then it should be cool πcrankyah..i didn't think that way..workload will be more..
@Priyank,Milan,CB thanks for your entry. -
RajdeepCEIts depend upon your wish whether you want to keep it or not. But it is not compulsary.
My personal suggestion is yes, you should give a name like crackers or anything better you find. It will be fun!!
crankyoh k...sure..will come up
we could have also had on wimbeldon -
Saandeep Sreerambatla
PS: We need 2 members for organizing team. I prefer ES and another active CEan to be with us.
Dude i can help you for sure π
So can i participate or not? -
RajdeepCEWhy not ES, you are in!!!
I am just waiting for you to reply here.
Saandeep Sreerambatlaoh! You are Online , i didnt see!!!
I will post my team tonight π
Let me know how can i help you? π -
RajdeepCESure ES!!
Will let you know soon. -
Harshad Italiya
Ya Cranky we can do that also we need some Tennis lover members and one who is going to manage all this things.crankyoh k...sure..will come up
RajdeepCECEans, only 48 hours remaining so choose your fantasy team as soon as possible.
Saandeep SreerambatlaThis is my team if you still have time π
Batsman:
MEK Hussey, MJ Clarke,RT Ponting,KP Pietersen ,P Collingwood
Bowler:
B Lee,MG Johnson,MS Panesar, R Sidebottom
WC:
MJ Prior
All Rounder:
A Flintoff ,SR Watson
Crazy Player: KP Pietersen
Duffer Player: R Sidebottom -
crankyMy teamππ
Batsmen:Hussey,Clarke,Cook,Collingwood,Katich
Bowler:Lee, Anderson,Sidebottom,Broad
Wicket-keeper:Haddin
All-rounder:Flintoff,Watson
Crazy-player:Watson
Duffer player:Haddin -
RajdeepCECEans only 13 hours left in deadline for submitting teams.
Harshad Italiya@ ES and Cranky... are you people not going to give your team? if you do so it would be great π
Saandeep Sreerambatla@GF : I have submitted my team, please check.!!
Harshad Italiya
i am asking about Team Title :Team Name:English-Scared@GF : I have submitted my team, please check.!! -
Saandeep SreerambatlaMy team name
Scary -12 -
crankyLazy12π
Harshad ItaliyaEnglish-ScaredMy team name
Scary -12
Cool Name πcrankyLazy12π -
RajdeepCECEans, teams are updated so check it soon.
PS : Deadline is extended to 8:30 GMT( 14:00 IST ), so hurry up & be with us.
Anil JainMy team is not appearing correctly on the first page(as I sent you)... please check the PM and correct the same....
Thanks,
-CB -
RajdeepCEI have updated your team CB, please check it.
Anil JainNow it looks fine to me...
Peterson is N.O. on 50...
-CB -
Harshad ItaliyaGood going Rajdeep.
RajdeepCEWell, I have updated the point table & leaderboard, so check it first.
Feel free to pointing out the errors in calculations or any other. -
Harshad ItaliyaGood Work there Rajdeep π
Here is player Point in image file for better look
RajdeepCEThanks godfather for this crazy good image, I have updated index page with this image.
Harshad ItaliyaThanks Rajdeep i am doing my Best!
priyank_180i have check it.
Let us see, who get the title..
Best of Luck.. to all CEen -
RajdeepCECEans, I have updated the thread with the scores of 2nd day. Please check your points & also dont forgot to cross check the points.
priyank_180unbelievable... π
:dance::dance::dance:
i m on top, today is mine, lets see whats happens in future... -
Harshad ItaliyaRajdeep there is correction in points. wait i am posting the new image of point updates.
Harshad ItaliyaHere is the Latest Points after the End of Day-2
Harshad ItaliyaLeader Board after Day2:
RajdeepCEPlease cross check the points calculated by godfather and let me know if there is any change.
Harshad ItaliyaCongrates Priyank your Katich and Ponting made a day for you.π
priyank_180
Thanks!!!! God father.godfatherCongrates Priyank your Katich and Ponting made a day for you.π -
crankyagain bottom of table!he heππ
RajdeepCENo problem cranky, I am coming to compete with youππ
I have updated the point table & leaderboard, so CEans check it out & also cross check the points in case of errors. -
Harshad ItaliyaPlayer Point After Day-3
Harshad ItaliyaLeader Board after day-3:
Harshad Italiya
Cranky Next Time be careful when choosing players πcrankyagain bottom of table!he heππ
Congrates Milan25 -
priyank_180hey MILAN congratesππ
priyank_180oh God , my Crazy Act like a Lazy..
π:shock::shock::shock::shock::shock: -
Harshad ItaliyaPlayer Points After Day-2
Harshad ItaliyaLeader Board After Day4
Harshad ItaliyaCongratulation to Me π
priyank_180Congrates GF....
πππππππ -
priyank_180hey... GF ... where is rajdeep....????
cranky
my lazy will come backpriyank_180oh God , my Crazy Act like a Lazy..
Harshad Italiya
Tips: Remove your 3 Lazy players in Next Match and Select Crazy player as your Crazy so you got more points. πcrankymy lazy will come back -
cranky
yeah..should have selected more carefully.Did in a haphazard way πgodfatherTips: Remove your 3 Lazy players in Next Match and Select Crazy player as your Crazy so you got more points. π -
Saandeep SreerambatlaMy score was average , i selected Watson and Lee both are not playing the first test π
Harshad Italiya
Lee was injured... i think you haven't Read the news. although you manage the total of 801 πEnglish-ScaredMy score was average , i selected Watson and Lee both are not playing the first test π -
RajdeepCEGuys, I will update the points after end of the match. So stay in touch with CE.
Meanwhile, thanks GF, for updating leaderboard. -
Yes i didnt read πgodfatherLee was injured... i think you haven't Read the news. although you manage the total of 801 π
No problem i will read the news and will select for 2nd test. -
Anil JainPoor me... Lee / Watson / Clark / Bell - 4 players didn't play.
RajdeepCESo, the first test match of the Ashes is over now. England have pull the match drawn in a fightful match.
I have updated the point tables & leaderboard, so check it.
Congrats GF, for securing 1st place after end of 1st match.
CEans, transfer window is open now, & will be opened till 16 July 5:30 GMT. -
Anil JainCongrates leaders... π not winners.
I am still in competition, done with the transfer window...
-CB -
Harshad ItaliyaHere is the My Calculation:
please cross Check your Points RajdeepCE i had added Match total bonus Points and MOM bonus Points.
Player Points After Test 1
Harshad ItaliyaLeader Board:
Harshad Italiya
I think Bell is suits in Test match i think they will replace Bopara with Bell.crazyboyPoor me... Lee / Watson / Clark / Bell - 4 players didn't play.
Thanks RajdeepCE πRajdeepCESo, the first test match of the Ashes is over now. England have pull the match drawn in a fightful match.
Thanks CB πcrazyboyCongrates leaders... π not winners.
-CB
All Of you Thanks for the participation this is really an Interesting one :dance: -
priyank_180@ GF!
Congrates ones again...
You are always No1..
πππππ -
Saandeep SreerambatlaCongrats GF π
Am 3 short of 1000 π -
priyank_180hey... i m on 2nd position...
nice game by Ponting,katich,john,and colli...
but my crazy and SR Clarke is not in my support..
in short ... i need some change in my team..ππ -
Anil JainCan We change Crazy and Duffer player???
I guess we can not???
Please confirm.
-CB -
RajdeepCE
Now, you should be clear CB.RajdeepCE6. After end of each test match, * The Transfer Window * will be open. Here You can change any of your 3 players only. To use transfer window you have to PM me or post in the format given below in next post. and yes again be careful you have to change your players according to the rules. You can also change your Crazy & Duffer player. The transfer window will be closed on the match day at 5:30 GMT.
@godfather, thanks for pointiout my errors.π -
Harshad Italiya
:clap:priyank_180@ GF!
πEnglish-ScaredCongrats GF π
Am 3 short of 1000
Yeah do it πpriyank_180hey... i m on 2nd position...
We can Change it CB πcrazyboyCan We change Crazy and Duffer player???
Please confirm.
-CB
:clap: For your job. πRajdeepCENow, you should be clear CB.
@godfather, thanks for pointiout my errors. -
Saandeep SreerambatlaGF talking only with smileys these days π
RajdeepCEES, you crossed 1000 points. You checked it?π
Smileys are always good, sweet & simple still effective. -
Saandeep SreerambatlaRajdeepCEES, you crossed 1000 points. You checked it?π
Yes Just checked π thanks π -
Harshad Italiya@ES:
I need some more Smiley to share emotions π
@RajdeepCE:
I think The First page point and point shown in my Calculation are still Different π -
RajdeepCEI think you miscounted the points of Haddin. Have you checked it?
Harshad ItaliyaWell The Points for Hussey is 18 not 26. wait i will recalculate everything.
Harshad ItaliyaI think you forgot to add Bonus Point for Bowlers.
priyank_180hey... is there any change in points..??
Harshad Italiya
Yes that will be Updates Soon.priyank_180hey... is there any change in points..??
After First Test
United XI = 1250
Shocker XI = 1123
Magneto XI = 1117
Scary XI = 1072
Reckless XI = 967
Crazy XI = 866
Lazy XI = 788 -
RajdeepCECheck out The First page Its Updated.. Harmison is call back into Team.
Anil JainMy team is not appearing in the 4th post (Team of the Ceans)
RajdeepCE
Fixed.crazyboyMy team is not appearing in the 4th post (Team of the Ceans)
i will update first page with modified team. guys please submit your new players under *transfer window* rule. -
Anil JainHey, you have not updated my players (I sent you a PM with players (Transfer window players)
Sorry to bugging again and again π -
RajdeepCE
You are most welcome Done!crazyboyHey, you have not updated my players (I sent you a PM with players (Transfer window players)
Harshad Italiyai had selected the New Players π
Anil JainLooks perfect !!
Have you updated others team as well... ??/
-CB -
Harshad ItaliyaMine Updated.. thanks... i will give you mine one player soon π
Harshad Italiya@CB:
You Replace Bell good one π -
priyank_180
I have Pm you... plz check it...RajdeepCEFixed.
RajdeepCEPriyank, your team is updated.
Check it. -
Saandeep SreerambatlaI submitted my team π
priyank_180
thanks Rajdeep!!!!RajdeepCEPriyank, your team is updated.
Check it. -
Saandeep SreerambatlaMy team is updated π
RajdeepCEGuys, I will be less online for two weeks due to my exams. So I cant update the point table daily, but I will try my best to update twice or thrice during a test match. So hope you all dont mind it.
All the best for the 2nd test match.
Saandeep SreerambatlaSure dude no problem π
We can help you out π -
Harshad Italiya@ES
you can easily calculate points with the excel file i had mailed you. You have to do some modification in team. Please try to modify it if you have time. -
Harshad Italiya@ES
crankySorry for the late reply.
Change of players
cook==ponting
watson==swann
lee==johnson
crazy==hussey
duffer==flintoffπ -
Rajni JainCan I participate now.. and can I post my team ???
I know one match is already gone... still I think I can chase .. π -
RajdeepCEIts nice, crazygirl.
Submit your team immediatley. -
Rajni JainSubmitted, Please check.
RajdeepCEBe active on CE.
Updating your team now. Check it after few minutes. -
Harshad ItaliyaLeaderBoard after day 1
crazy eleven 431.5
chasers eleven 369
united eleven 305
scary eleven 243
reckless eleven 236
shocker eleven 191
lazy eleven 110
magneto eleven 106
guys please cross check points and do the changes. -
Saandeep SreerambatlaDude i too calculated but i think there is some minor change in our counting π
Reckless 202
United XI 305
Shockers XI 158
Magneto Xi 198
Scary XI 210
Crazy Team 406.5
Lazy XI 110
Chasers XI 344
Let me know where i am missing such that i can calculate correctly next time π
Players :: Please be patient Rajdeep will update the final scores in the first page -
Harshad ItaliyaDude have you divide duffer player point? And you are using the excel file for the point calculation?
Thanks buddy for helping. -
Saandeep SreerambatlaI doubled the crazy player scores but didnt halved the differ players , will update it..
Anyways i find very high variation so lets wait for final updation by Rajdeep π -
Harshad ItaliyaFeeling too sleepy now will recalculate everything in morning.
Rajni JainNot a bad start from my selected team mambers π
Strauss, Johnson, Hilf everybody clicked. -
Harshad ItaliyaNicely played by crazyboy team.
Ya good start for you crazygirl. -
RajdeepCEGuys, I have update points. So check it. And also correct me if I am wrong.
ES & GF, thanks for your support. -
Harshad Italiya@english sacred. Yes i was wrong in calculation π
nice work Rajdeep
you please carry on with you exam. We will update whole point table at the end of match. If you don't mind guys.
England is in strong position will strauss complete his 200 runs? -
Saandeep SreerambatlaEngland - 425 All out.
Australia - 22/2 π -
Harshad ItaliyaPlayer Point Table
For 2nd match:
Hussey - 61
Clarke - 26
Hughes - 4
Ponting - 12
Katich - 48
Strauss - 191
Pietersen - 32
Collingwood - 16
Johnson - 79
Hillfenhaus - 100
Hauritz - 3
Andersen - 129
Broad - 71
Flintoff - 34
Swann - 4
Haddin - 33
Prior - 13 -
Harshad ItaliyaCrazy eleven 870.5
chasers eleven 634
united eleven 587
lazy eleven 557
shocker eleven 506
reckless eleven 450
magneto eleven 411.5
scary eleven 375 -
Saandeep SreerambatlaThis score is after the day -2 correct??
Harshad ItaliyaAfter day 3
Player Point Table
For 2nd match:
Hussey - 61
Clarke - 31
Hughes - 4
Ponting - 12
Katich - 53
Strauss - 228
Pietersen - 76
Collingwood - 80
Johnson - 79
Hillfenhaus - 106
Hauritz - 99
Andersen - 129
Broad - 71
Flintoff - 64
Swann - 4
Haddin - 43
Prior - 79
thanks Milan25 for helping in calculation of points. -
Harshad ItaliyaCrazy eleven 1002.5
united eleven 878
chasers eleven 857
reckless eleven 810
shocker eleven 691
magneto eleven 663
lazy eleven 656
scary eleven 604 -
Harshad ItaliyaAfter day 4
leader board
Crazy eleven 1353
united eleven 1258
chasers eleven 1188.5
reckless eleven 1130
lazy eleven 1084
magneto eleven 1004
scary eleven 874
shocker eleven 860 -
Harshad ItaliyaAnyone is going to crosscheck the points? Or we can do one more thing we will crosscheck after completion of all test matches π
crazyboy your teams is on way.
And superb start by chasers eleven. -
Saandeep SreerambatlaDude I am not last in the list π
I am last but one update it π -
Harshad ItaliyaDone sandy now you are not at last. π
Saandeep SreerambatlaYes π
Next match i will try to be in top 3 π -
Harshad ItaliyaYou have an advantage that you have good score in first match.
after 2nd match:
Hussey - 88
Clarke - 192
Hughes - 21
Ponting - 5
Katich - 59
Strauss - 243
Pietersen - 91
Collingwood - 90
Johnson - 147
Hillfenhaus - 110
Hauritz - 100
Andersen - 129
Broad - 84
Flintoff - 334
Swann - 104
Haddin - 135
Prior - 79 -
Harshad ItaliyaLeaderboard after 2nd test.
Crazy XI 1795.5
Chasers XI 1546.5
United XI 1535
Reckless XI 1391
Lazy XI 1333
Magneto XI 1309
Scary XI 1042
Shocker XI 997 -
Harshad ItaliyaFinal Leaderboard:
United XI 1250+1535=2785
Crazy XI 866+1795.5=2661.5
Magneto XI 1117+1309=2426
Reckless XI 967+1391=2358
Lazy XI 788+1333=2121
Shocker XI 1123+997=2120
Scary XI 1072+1042=2114
Chasers XI 1546.5 -
Harshad ItaliyaGuys please cross check points and please post you transfer window player as soon as possible so we can modify the team as we both are busy with exams anyone going to manage this thread till 31st july?
RajdeepCEI have updated the thread, so check it.
There is some difference in my calculations & godfather. But will check it soon. Meanwhile if you found any errors than feel free to correct it. -
Harshad ItaliyaOk Rajdeep i will update all points for second test match after exam please wait for sometime.
Wow this time there is really very tough game.
Specially nice team selection by CrazyBoy and CrazyGirl. You both collected a huge amount of points. -
Saandeep SreerambatlaStill iam last but one π
Anyways i will try well for next matches. -
Anil JainThanks Guyz, Congrates GF - still you are maintaining pole position.
I have sent a PM to you and rajdeep for next match transfer window. -
Rajni JainI am happy with my start... Still I am 1000+ points behind. My target is to reach among top 4,
I have sent my transfer window option to Rajdeep and GF. -
Harshad ItaliyaThank you guys.
CB i received your team. -
Harshad ItaliyaCG i haven't received your new players. Have you send me PM?
Rajni Jain@Gf - Sent you the visitor message. You have not allowed to receive PM from unknowns.
Please acknowledge. -
Harshad ItaliyaOk crazygirl now you can send. Its default setting that's why problem in sending message.
Saandeep SreerambatlaI updated my team , @GF : Please make the duffer as Collingwood
Harshad Italiya@Sandy.
Can you please post your three players only the message which you had send me in that there is 3 allrounder. -
Rajni Jain@ GF - have you received my team (Transfer window options)... ??
Harshad ItaliyaYes i got it. Will update it soon. Rajdeep will do that.
RajdeepCECEans, be patient!!!
I will update the thread on 29th July, so till than enjoy!!
Saandeep SreerambatlaI sent my updated team to GF π
Please acknowledge , errors if any please let me know π -
cowboyI want to take part in this game. Can i?
Milan25I want to change my crazy player@
Flintoff > M.Jonson -
Anil Jain
Although you are a bit π too late π late to win (compete) in this, still you can try your luck.cowboyI want to take part in this game. Can i?
Rajdeep / GF - please confirm. -
cowboyCrazy boy you are right i am late to win but i play for just ashes fever in my around,
if you allowe me than my team ' cowboy xii '
1>strauss
2>katich
3>m.Clark
4>ponting
5>collingwood
6>fillntof
7>prior
8>m.johnson(crazy)
9>j.Andresen
10>swann
11>siddle(duffer)
12>hauritz -
Harshad ItaliyaYour team will be added for the next match. Looking forward to see you active in other area also.
Saandeep SreerambatlaGF , can you give an update on my team .
Harshad ItaliyaI had forwarded your team to rajdeep.
@rajdeep:
please make
crazy player. Flintoff
duffer player. Pietersen
for scary eleven. -
Saandeep SreerambatlaThanks GF π Nice maintaining it dudeπ
Good Excel with lot of formula e involved good. -
cowboyThanks for allowing me to take part.
RajdeepCEWell, I have updated the teams of all the players, so check it.
@cowboy, I have added your team. And I am looking forward to see you active on CE.
Saandeep SreerambatlaGood to see you back Rajdeep!!!
Harshad ItaliyaNice work rajdeep i'll check out the teams again.
Harshad ItaliyaBuddy please check out the crazy player of scary eleven..
Anil JainIts raining very heavily at the 3rd Edgbaston Test Venue for ashes. Lets see if match will start. π
Saandeep SreerambatlaDude Rajdeep ,
You havent changed my Crazy to Flintoff and duffer to Pieterson.
Please change it . -
RajdeepCEOk.
I did it.π
Anything else, change or correction? -
Saandeep SreerambatlaOnly 30 overs on day -1
Aus 126/1 -
Rajni JainLets see if England can do some miracle otherwise test is heading towards a draw...
priyank_180MJ North is gone at 96... MJ Clarke is in game @ 96(179).... Aus 366/5
Harshad ItaliyaPlayer Points After 3rd Test Match:
Harshad ItaliyaLeader Board After 3rd Test:
Harshad ItaliyaFinal Leader Board:
Harshad ItaliyaCongratulations CrazyBoy!
:dance: -
Rajni JainCongratulations CB !!
Nice team selection. Now you are having top spot for twice in three matches.. Good going. -
Anil Jain@GF - I am not able to see the images.
could you please copy paste the contents of leader board and final leader board. That would be so nice of you.
By the way when Rajdeep will be back.
-CB -
Harshad ItaliyaCrazy XI = 1327
Shocker XI = 1219.5
Reckless XI = 1182.5
United XI = 1164
Magneto XI = 1105.5
Scary XI = 1096
Cowboy XI = 1070.5
Lazy XI = 992.5
Chasers XI = 919 -
Anil JainAnd whats the final Leader's board...
priyank_180Congratulations CB!!!!
Harshad ItaliyaFinal leader board:
Crazy XI = 3967
United XI = 3880.5
Reckless XI = 3531
Magneto XI = 3519
Shocker XI = 3329.5
Scary XI = 3190
Lazy XI = 3116
Chasers XI = 2345.5
Cowboy XI = 1070.5
Sorry for late Reply CB. -
Saandeep SreerambatlaGood Work guys.
Congrats CB. -
Harshad ItaliyaReally impressed by CB's selection. Hats off to you.
Milan25Good going CB
nice team selection
congratulation! -
Anil JainThanks Guyz. I have done nothing different then you guyz, its just luck that my players clicked. π. Hope that they will click in the next two tests as well... π
-CB -
Harshad ItaliyaThis thread crossed 200 posts.. :dance:
Harshad ItaliyaGuys Rajdeep is not available for tomorrow so i will try to update this thread please send me the changes in your player Please if possible then post it here.. that would be great..
Sorry for that. -
Anil JainHave you received my options for transfer window.. please confirm.
-CB -
priyank_180where is Rajdeep....??
is he busy with his exams... i think his exams are already over.. -
Harshad Italiya
Yep I Received it.crazyboyHave you received my options for transfer window.. please confirm.
-CB
His mobile is not working buddy. you please post your changed player here.priyank_180where is Rajdeep....??
Harshad ItaliyaChanged Players:
Milan:
M.Hussy=Katich
Collingwood=Bell
CG:
Hussy = Watson
Johnson = Lee
Flintoff = Bell
Crazy = Andersen
CB:
Clarke=Watson
Fkintoff=Bopara
Johnson=Lee
Crazy=Anderson
ES:
Pieterson=Strauss
Duffer - MJ Prior.
Friends let me know if there is anything wrong. and post your changed players soon. -
Saandeep SreerambatlaMy change
Change Pieterson to Strauss
Duffer - MJ Prior. -
cowboyOnce again cb rocks lead board.
cowboyI change hauritz=lee
Fillntof=wattson
Siddle=sidebottom
CrazyDuffer priyank_180dont change my team....
sorry for change.... but
just change my crazy with G Onions.....Harshad ItaliyaFor Rajdeep
Flintoff= Watson
Siddenl onions
Crazy HillfenhausHarshad ItaliyaMine
Flintoff Watson
Hussey Bell
Broad Onions
Crazy OnionsHarshad ItaliyaGuys i'm somewhat busy so cant come online i have to leave now but i'm sure i will change the team as soon as possible...
sorry for that... have a nice day...
Happy CCFL πpriyank_180change....
flintoff= harmisoncowboyIts not time to replace player. please make some rules to time to change player.in my opinion its time is 5 hours before starting the match.cowboyEngland in trouble help someone.priyank_180england is in trubble....
good start by Aus..
Watson @ 24and ponting @ 33.....
Australia @ 61/1
England needs wickets....cowboy
Where is godfather and rajdeep?cowboyIts not time to replace player. please make some rules to time to change player.in my opinion its time is 5 hours before starting the match.Harshad Italiya
you cant change your all rounder with bowler..priyank_180change....
flintoff= harmisonHarshad Italiyawell i was not able to access internet thats why its some what delay in team modification.Harshad ItaliyaTeam of the Ceans:
Hussey =
Clarke =
Ponting =
Strauss =
Collingwood =
Johnson =
Hillfenhaus =
Onions* =
Andersen =
Watson*=
GP Swann =
MJ Prior =
Crazy - Hiffenhaus, Duffer - MJ Prior
Total =
Bell* =
Ponting =
Clarke =
Strauss =
Collingwood =
Johnson =
Hillfenhaus* =
Andersen =
Onions* =
Watson*=
Swann =
Haddin =
Crazy - Onions, Duffer - Haddin
Total =
Ponting =
Hussey =
Katich =
Bell* =
Collingwood =
Johnson =
Hilfenhaus =
Andersen =
Onions* =
SR Watson =
Flintoff* =
MJ Prior =
Crazy - Onions, Duffer - MJ Prior
Total =
Katich* =
Ponting =
Clarke =
Strauss =
Bell* =
Hauritz =
Johnson =
Andersen =
Hillfenhaus* =
Flintoff =
Swann =
Prior =
Crazy - Johnson, Duffer - Prior.
Total =
Hussey =
Ponting =
Clarke =
Strauss* =
Collingwood =
Hillfenhaus =
Johnson =
Andersen* =
Hauritz* =
Flintoff* =
Swann =
MJ Prior =
Total =
Hussey =
Bopara* =
Strauss =
Collingwood =
North =
Lee* =
Hilffenhaus =
Andersen =
Onions* =
Swaan =
Watson*=
Haddin =
Crazy - Anderson, Duffer - Haddin.
Total =
Hussey =
Clarke =
Ponting =
Collingwood =
Katich =
Johnson =
Andersen =
Sidebottom =
Broad =
Flintoff =
Swann =
Haddin =
Total =
Bell*=
North =
Ponting =
Collingwood =
Strauss =
Johnson =
Hillfenhaus =
Siddle* =
Broad =
watson=
Swann =
Haddin =
Crazy - Anderson, Duffer - North
Total =
Cowboy - Cowboy XI
Strauss
Katich
Clarke
Ponting
Collingwood
Johnson
Andersen
Lee*
Sidebottom*
watson*
Swann
Prior
PS: Rajdeep Please update first page when you come back... and i am also requesting mod to do if possible.priyank_180hi.. gf..
which time is consider as a deadline for updating a team....?ππHarshad ItaliyaBefore match Starts. π you cant change once match started.priyank_180you mean before toss or before play starts... ?Harshad ItaliyaBefore Toss.Anil JainScores please... I know I would be the last in this test.. but want to see how much lead I need to cover in last match to become the winner... π
-CBAnil JainSeems like excellent team selection by CrazyGirl... every bowler of her team clicked...
Broad... 6 WKTS & 64 runs
Siddle... 6 WKTS
Johnson... 6 WKTS & 27 runs
Hilfenous... 5 WKTS
North... 100+
Watson... 50+
Ponting... 50+
Swann... 50+
Great selection... no other CEan had such a great luck in 4th test... By the way why did you choose crazy as ... andersen... if you would have choosen crazy in above mentioned players.. you would have been too too far from others...
Nice selection. let the result of 4th test publish.
-CBRajni Jainπ Ha ha ...
Just luck... Thank you.Harshad ItaliyaLeader Board after 4th Match:
Harshad ItaliyaSuperb Team selection by CrazyGirl... You are Lucky CG.
Guys Happy CCFLing πSaandeep SreerambatlaDude GF..
No Images please , Please post the scores as you did for third test πHarshad ItaliyaBuddy i am in Hurry!! although i spare 30 mins and calculated points.. ok Just a min.Harshad ItaliyaLeader Board after 4th Match:
Chasers XI = 1365
Reckless XI = 1031.5
Magneto XI = 1029.5
United XI = 925
Lazy XI = 919
Scary XI = 770.5
Shocker XI = 747.5
Cowboy XI = 716
Crazy XI = 629Harshad ItaliyaFinal LeaderBoard:
United XI--->4805.5
Reckless XI--->4562.5
Magneto XI--->4548.5
Shockers XI--->4077
Lazy XI--->4035
Crazy XI--->3967
Scary XI--->3960.5
Chasers XI--->3710.5
Cowboy XI--->1786.5Saandeep SreerambatlaExcellent!! Thanks for yuor time GF.
Excellent team CG πHarshad ItaliyaWelcome Sandy.. πAnil Jain
Howz thats possible, Till 3rd test I was around 100 points ahead from second ranker. Now I am almost 1000 points behind the first ranker... πgodfatherFinal LeaderBoard:
United XI--->4805.5
Shockers XI--->4077
Lazy XI--->4035
Crazy XI--->3967
Scary XI--->3960.5
Cowboy XI--->1786.5
something got messed up here... please correct that up.
-CBAnil JainHey, I am still on the second rank... π You forgot to add my points of fourth match in overall Leader's board
-CBpriyank_180
Hey GF....godfatherFinal LeaderBoard:
United XI--->4805.5
Shockers XI--->4077
Lazy XI--->4035
Crazy XI--->3967
Scary XI--->3960.5
Cowboy XI--->1786.5
Once again!!!!! You are on Top....
Congratulations...πpriyank_180
I think... She should change her name....crazyboySeems like excellent team selection by CrazyGirl... every bowler of her team clicked...
Siddle... 6 WKTS
Hilfenous... 5 WKTS
North... 100+
Watson... 50+
Ponting... 50+
Swann... 50+
-CB
Crazygirl----------->>>> Luckygirl
Congra... CGπRajdeepCEGood going guys!!!
Thanks godfather for handling this thread when I am not available.Harshad Italiya
Yep You are Right CB Sorry for that..crazyboyHey, I am still on the second rank... π You forgot to add my points of fourth match in overall Leader's board
-CB
Here is Final Leader Board after 4th Match:
Final LeaderBoard:
United XI--->4805.5
Crazy XI--->4596
Shockers XI--->4077
Lazy XI--->4035
Scary XI--->3960.5
Cowboy XI--->1786.5
@ RajdeepCE: Please Post this Score on the First page and Uopdate it..
Anil JainThanks for updation.
Chasers X1 played one match less then others, still chasing very fast....Harshad ItaliyaThere is good competition between 2,3,4 Position.. just 20-30 points gap.priyank_180Now just last test match is remaining....
Let us see who is that lucky person... Who win this CCFL 2.0 "The Ashes"......RajdeepCEI have updated the teams of crazyboy & crazygirl. So check it out & other CEans who wants to use transfer window, PM me as soon as possible.Rajni JainI choose Crazy to be Johnson and duffer to be Haddin.
Crazy: Johnson
Duffer: Haddin
Please correct the same.
CrazyGirlHarshad ItaliyaRajdeep is back nice to see you buddy.Harshad ItaliyaChange my Crazy to Hiffenhause
Will change two players soon.Harshad ItaliyaChange my Players:
Bell= Cook
Onions= Broad
Crazy to HiffenhauseParitosh222we need to give select the players by writing the namespriyank_180plz change my team with...
MEK Hussey= MS North..
crazy=Johnsonpriyank_180change it ....
Onions= BroadAnil JainPlease change my crazy player to M. Clarke
Crazy: M. ClarkeRajdeepCEHey CB, can you please recheck your team please, cause I was unable to find Clarke in your team.Anil JainOops .. could you please swap Ponting with Clarke and made Clarke as Crazy Player.
Apologies for the inconvience caused.
Clarke = Ponting
Crazy: Clarke
-CBAnil JainOverall Leader's board
Team Name Points
United XI 5056
Crazy XI 4826.5
Reckless XI 4778.5
Magneto XI 4733.5
Shockers XI 4355
Lazy XI 4183
Chasers XI 4175
Scary XI 4170.5
Cowboy XI 1954.5
Match#5 Leader's
Team Name Points
Chasers XI 464.5
Shockers XI 278
United XI 250.5
Crazy XI 230.5
Reckless XI 216
Scary XI 210
Magneto XI 185
Cowboy XI 168
Lazy XI 148
Crazygirl is going great gun... really acting like great chaser. Beside the fact, that she joined after one match still she has already chased one of the member...
Great going guyz.
-CBHarshad ItaliyaThanks CB for the Calculation of points..
Really CG is Blasting in this CCFL...Harshad ItaliyaLeader Board 5th match Day2:
Chasers XI -->1051
Shockers XI -->819.5
United XI--> 680
Reckless XI -->642.5
Lazy XI -->583
Crazy XI -->569
Scary XI -->533.5
Magneto--> XI 490.5
Cowboy -->XI 486.5
Overall Leaderboard day2:
United XI-->5485.5
RecklessXI--> 5205
Crazy XI-->5165
Magneto XI-->5039
Shockers XI-->4896.5
Chasers XI-->4761.5
Lazy XI-->4618
Scary XI-->4494
Cowboy XI-->2273
CG rocks again :cheers:Paritosh222confusseeeeeeddddddddddddddddddHarshad Italiya
where you got confused buddy?Paritosh222confusseeeeeeddddddddddddddddddHarshad ItaliyaLeader Board After Day3:
Chasers XI--->1403.5
Shockers XI--->1070.5
United XI--->1001.5
Crazy XI--->982.5
Reckless XI--->814.5
Lazy XI--->752
Scary XI--->745.5
Cowboy XI--->719.5
Magneto XI--->690.5
Final Leader Board:
United XI--->5807
Crazy XI--->5578.5
Reckless XI--->5377
Magneto XI--->5239
Shockers XI--->5147.5
Chasers XI--->5114
Lazy XI--->4787
Scary XI--->4706
Cowboy XI--->2506priyank_180England is the winer of Ashes2009... let us see who is CCFL winer....Anil JainEngland regain ASHES 2009.by a huge margin.
@GF, RajdeepCE - Now we have man of the series from both the side:
Aussies Man of the series is Clarke and English man of the series is Strauss. Are we going to share the points or points to both the players.
We are waiting for the announcement who are the top 3 of CCFL 2.0
-CBAnil JainWinner of the last match would be CrazyGirl. Lets wait for the announcement for the winner of CCFL 2.0
PS: CG won 2 (4th and 5th Test. Result of last match are yet to be officially announced), CB won 2 (2nd and 3rd Test,) GF won 1 (1st Test).
Consistent performance by GF.Harshad ItaliyaWell Rajdeep has calculated points you can see that on first page. Really superb team selection by CG. and nice competition between CB,MILAN AND RAJDEEP for last match.
Guys share your expereance for this CCFL. I hop you had enjoyed it well.
I want to say congratulation to Rajdeep for arranging such a wonderful series here on CE. And all of you who had supported this game.
Keep CE rocking.Saandeep SreerambatlaVery nicely organized guys !!!
Great work and congrats to the winners !!!
CG Excellent !!!
Moreover we will put few more rules for the next matches πpriyank_180First of all, congratulation to Rajdeep for organizing this rocking event...
and congrats to CG for wining this great events.....cowboyIts very good contest in ce.I think its continue with india,srilanka,newzland tri-series or england-aus one day series.And last thanks to godfather and rajdeep for great work,and also other ceans.Anil JainCongrates GF...
Excellent performance by CG....
-CBHarshad ItaliyaThanks Cowboy and CB.
I want to say Thanks Rajdeep for this great contest and also want to say thanks to all the participate.. guys Can we go ahead with the same game for upcoming series... we need some more active members..
Happy CCFLing. πcowboyWe ready for next addition of cfl.Hope in next addition more member join this time.priyank_180
YOu are right....cowboyWe ready for next addition of cfl.Hope in next addition more member join this time.
we are ready for next series...ntvinh986
_Good post. I appreciate it!RajdeepCEPlayers list:
Batsmen
Bowler
Wicket keeper
England - MJ Prior
All Rounder
_________________
Hi!
I'm on my last semester as a Mechanical Engineering undergrad and I'm looking for a nice topic for my thesis. We have 3 months to finish it doing simulations...
Please , if anyone could suggest anytopic for the final year project in automobile stream. I request to suggest something new and wiyhin a low budget.
Thanks
wat r the softwares used by electronics and communication students
1. Coca-Cola was originally green.
2. The most common name in the world is Mohammed.
3.The name of all the continents end with the same letter that they...
Again I come up with Crazy Boy's Quiz season I - 2
Q) What do bullet proof vests, fire escapes, windshield wipers and laser printers all have in common?
-CB
