Breathing Belnt Nose Technique for Drag Reduction
Project Abstract / Summary : In supersonic and hypersonic flows,wave drag,skin friction drag and base drag are the three main components of the total drag force.A new concept termed Breathing Blunt Nose was used to reduce the drag and heat dissipation at hypersonic flow regimes was found to be effective.In this technique,high pressure flow ahead of the body was sent into the low pressure zone behind the body.This leads to the decrease in delta P and pressure drag is decreased.
Why did you choose to work on this project topic : Drag is the major obstacle in aeroplane designing.Less drag leads to increase in aerodynamic efficiency of the body.Less drag also leads to low thrust required and leads to less power plant size.It reduces the cost of the aeroplane.
Institute/College Name: Lakireddy Bali Reddy College of Engineering
City: Mylavaram
State: Andhra Pradesh
City: Mylavaram
Dchavan
Do you have a ppt for itA.L.Nagendra BabuProject Abstract / Summary : In supersonic and hypersonic flows,wave drag,skin friction drag and base drag are the three main components of the total drag force.A new concept termed Breathing Blunt Nose was used to reduce the drag and heat dissipation at hypersonic flow regimes was found to be effective.In this technique,high pressure flow ahead of the body was sent into the low pressure zone behind the body.This leads to the decrease in delta P and pressure drag is decreased.
City: Mylavaram
Project Abstract / Summary : This paper presents with the development of a system for the neutralization and disposal of the Computer To Plate (CTP) printing wastes which at present...
Project Abstract / Summary : Its a Machine for splitting the wooden logs into two pieces at a time, the logs are required to split so it can be burn...
What is the basic difference between production engineering and manufacturing engineering ?
Project Abstract / Summary : We visited the many submersible pump manufacturers and we found the problem that while disassembling the body more labour work required, more time consuming and...
Project Abstract / Summary : Today, many modern applications call for novel forms of queries that aim to find objects satisfying both a spatial predicate, and a predicate on their...
