Analog Clock
Why do analogue clock don't work on recharge battery. And if I run it on main power supply still it don't work but it works with old AA battery...
Ramani Aswath
Rechargeables have voltage below what is needed for analogs. If you have a stabilized 1.5 V DC adapter, it should work on mains supply. Ripples may give trouble.jaspal gardeWhy do analogue clock don't work on recharge battery. And if I run it on main power supply still it don't work but it works with old AA battery... -
jaspal gardeAlready tried with stable adapter of 1.5v still not working and not that only this but any analogue clock is not working with rechargeable battery
Ramani Aswath
Rechargeable voltage is about 1.25, below working voltage of analogues.jaspal gardeany analogue clock is not working with rechargeable battery
It should have worked.jaspal gardewith stable adapter of 1.5v still not working -
jaspal gardeNo no its not working you can try it.
Ramani AswathI have to wire a 1.5 V stabilized supply. Shall try it sometime when I find the time and revert.
jaspal gardeThank you. It would be great also what can be reason for that
Project Abstract / Summary : Due to drought and depletion of underground water more bore wells are drilled on the surface of the earth. When the ground water gets dried...
Project Abstract / Summary : As we have a standard procedure to use a projector is, we connect an external device to our computer and then computer is connected to...
All the contestants selected for Round II of the 'Hunt for India's Best Academic Project' Contest have to create a video presentation and upload it on YouTube.
NOTE: You may...
Project Abstract / Summary : From the emerging domain Cloud computing, there are various applications. One among that is, Using the Cloud Computing concept and chemistry as an interoperability domain,...
WIRELESS CHARGING
Inductive charging (also known as "wireless charging") uses an electromagnetic field to transfer energy between two objects. This is usually done with a...
