an idea about processing polychloroprene?
Hey CEans,
do you have any idea about how we are obtaining polychloroprene sheets for wet suits (or neoprene) after having made the polymer?
I have found a website that describe a little how to do it, #-Link-Snipped-#
They said : "[FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular] Neoprene is often referred to as 'rubber' but it is actually a plastic. It begins as a powder called polychloroprene. To this base are added other ingredients that provide elasticity, foaming agents, cell size, colour (usually black), adhesion, bulk, plus other properties. This mixture is made into a dough which is plopped into a heated press. Under pressure and heat the mixture squishes out to make a sheet about 90" by 53"."
but I would like to know a little bit more: not what is added, it's a secret, I understand, but which pressure, temperature, how lob does it take...
It's for a project I have to do in my engineering school. I still have to do a part on a process.
Can you help me?
Thanks
[/FONT]
Can you help me?
Thanks
[/FONT]
kernel32I would like to add: it's not spying, I just want to know what kind of reactions occurs in the heated press: is it a vulcanization? I want to be sure.
Moreover, I want to be sure it's really an emulsion polymerization that we do in industry.
Because I'm student it will be fine if I can add the name of somebody and the name of a company that helped me during my rapport, you probably know how teachers or professors like when you give some names, or greatings at the end of a rapport.
A lot of wait and finally an interview
The questions were many and answers were few
When intro and all were skipped
I knew I was gonna be ripped
when...
Hello !!
I need some help for a project which is a mix between chemistry and processes.
I described my problem in the "technical discussion->chemical engineering" but I don't know...
hi all,
i feel glad to post my first thread.can anyone explain me what is meant by "SCRIPTING LANGUAGE" .
i have learnt that java script is an "interpreted language"....
Hey CEans.. I guess I'll just post this in the Chillax area, since its pretty off-topic and perhaps unimportant. Me taking an "extended" break from Crazy Engineers, so that means...
hi guys im new here.. only a beginner in creating programs using assembly language.
theres something wrong with my program on how to shift instructions turning ON one led from...
