A 100kW Generator Connected With A Load Of 50kW
what if we load a generator of capacity 100kw with 50kw load??? i mean will it supply 100kw or 50 kw??...if it supply 100kw then where is the rest 50 kw go because the load is only 50kw??
naveeepower dissipation in form of heat....(joules law of heating)
Naman Agarwal
if it is so..then wont it be too unefficient ??..its not like that...if we only use 10kw of 100kw then u acc to u 90% is dissipated in the form of heat...naveeepower dissipation in form of heat....(joules law of heating) -
Naman Agarwalnow i got it...
it will only produce only 50kW... -
Jeffrey Arulrajno generator is loaded more than 70% of its maximum capacity at all
so there is no losses in any form
based on load only a generator will generate power if it is 50kW load power generated is 50kW only plus some little value to compensate the line losses and other losses -
naveee
obviously.... remaining voltage will not be used .... hence a large number of load is conneted while usin generator.....naman2511now i got it...
Jeffrey Arulraj
the large used is also never larger than 70 - 80 % of the maximum load supplied by the generatornaveeeobviously.... remaining voltage will not be used .... hence a large number of load is conneted while usin generator.....
this precaution is always taken to prevent low voltage scenarios from occuring -
Jeffrey Arulraj
No such losses occurnaveeepower dissipation in form of heat....(joules law of heating)
As the watt reading is always dependant on current produced and current produced depends on the load attached to the generator
what's the main difference b/w four stroke & two stroke engine?
Name: J.Elvis Prabhakaran
*Engineering Trade:Aeronautical
*Occupation: Student
Work Experience: nil
*Hobbies & Interests: Like to read books,novels(mostly fiction).Listening to music and most importantly Day-dreaming. Interested in research about Extra...
how the power will pass to our homes and all other fields from the power stations? and the role played by the transfomers?
now, try this one ...
there are 5 guys , 4 of which are toggler and 1 is truth-teller .
(toggler r those who say truth at one time and...
What is the difference between GSM and CDMA SIM card?
