  • 2048 - How to win? Tips & Tricks
    @thebigk
    Updated: Oct 27, 2024
    Views: 2.5K
    Stumbled upon this totally addictive game. Trust me, it does not look addictive but I bet a few moves into the game and you would have that 'never give up' attitude kick in. I've just spent last 15 minutes trying to get 2048; but couldn't go beyond 256 😔. I'm starting this discussion to get opinions, tips and tricks on how to win 2048 game.
    All you need is the arrow keys of your keyboard to move the tiles. When two tiles having similar number touch each other; they add-up.
    Link: <a href="https://gabrielecirulli.github.io/2048/" target="_blank" rel="noopener noreferrer">2048</a>
    Looks interesting. Rather tied up shall revert in time.
    I got maximum 512 !
  • durga ch
    MemberMar 16, 2014
    someone has already comeup with an AI to solve the game, neverthless when I ran it, the max tile formed is of value 1024. But ,a very very informative discussion about the algorithm is going over in stackoverflow ..
    AdministratorMar 16, 2014
    durga
    Read the logic and I had tried to play with the same strategy; but couldn't really go beyond 512 (max number on a tile).
  • durga ch
    MemberMar 16, 2014
    The max I reached was 512 too, but i felt that was only due to my inability to see through the steps in advance.. I followed a logic such as, when I have a tile valued x, I leave it there and start making tile valued x/2, and so on and add then as i proceed the game
    Awesome game.. 👍
    I am rusting on 256 😖
  • Nayan Goenka
    MemberMar 20, 2014
    I got to 1024. 😛 Very close to finishing the game. Almost done but i got a bit sloppy. I m sure i will crack it today.
    Screenshot_2
  • Pensu
    MemberMar 20, 2014
    Have been trying it out for past few days. Maximum I reached till 1024. This game is going to be end of me!
  • Rajni Jain
    MemberMar 22, 2014
    Next target is 2048...
    2048
  • Ambarish Ganesh
    MemberMar 25, 2014
    Total luck this -img2048
  • Pensu
    MemberMar 25, 2014
    Ambarish Ganesh
    Awesome....good work, man!
    AdministratorMar 25, 2014
    #-Link-Snipped-# : Respect, man! I'm stuck at 1024. Did you play with any specific strategy?
    I noticed that if I keep all the big numbers at the bottom (left or right), I can get to 1024 easily. But if you use 'UP' moves a lot; you'll end up at about 512 and the game will be over soon.
  • Ambarish Ganesh
    MemberMar 25, 2014
    Didn't employ any different strategy. The only one was - keeping the big numbers (128 and onwards) at any specific corner for as long as I can.
    I believe I simply got lucky in this game. 😀 Played it 10-15 times more since this, haven't been able to reach 2048 again. 1024 is the sweet spot I hit maximum.
    People have actually developed some algorithms for this game on their blogs. Referring them all now.
  • Ambarish Ganesh
    MemberMar 26, 2014
    Another addictive game - DOTS. Personal best so far is 330. 👍
    People have registered scores over 900! [HASHTAG]#ChallengeAccepted[/HASHTAG]
    AdministratorMar 26, 2014
    Ambarish Ganesh
    Dots got more challenging after the latest updates. I gave up playing dots about a month ago. It wastes too much of time. 😔
  • Nayan Goenka
    MemberMar 27, 2014
    This is it. Finally there. 😁
    Screenshot_2014-03-27-21-41-51
  • Nayan Goenka
    MemberMar 27, 2014
    Challenge Accomplished AAAANNND Game uninstalled 😁 😁 😁
  • Nayan Goenka
    MemberMar 27, 2014
    #-Link-Snipped-# :
    It doesn't actually matter if you use or don't UP moves. However if you are stacking them in corner array fashion, you will have to lose one move. Depending on the corner you choose, you avoid one movement. Here I avoided UP moves and stacked numbers in descending order in snake fashion.
    AdministratorMar 27, 2014
    With 6 attempts I reached 1024 last night and then it was 'game over' 😔
    The only trick I used was putting all the blocks at the bottom of the square. If you never let the biggest addition block leave the last row, you'll reach 1024 very easily.
  • Anoop Mathew
    MemberMar 30, 2014
    Stuck at 256 ! 😳😴
    Update: Got 512!
    AdministratorMar 30, 2014
    I am stuck at 1024 + 512. Never go beyond that.
    Must. Crack. It. Soon. 😎
    Success!
    2048-win
    AdministratorApr 1, 2014
    And though I am a late latif, here's mine! 😁 😁😁
    Screen Shot 2014-04-02 at 10.29.07 AM
    Most of us seem to have used the left-bottom corner trick. 😁
  • Basil John
    MemberApr 3, 2014
    upload_2014-4-4_12-37-3
    Finally 2048 !!!
  • Anoop Mathew
    MemberApr 5, 2014
    [​IMG]
    Was stuck at 1024 for last 2 days. Now finally!
    P.S.: New passtime at office for everyone 😛
  • Anoop Mathew
    MemberApr 6, 2014
    Anoop Mathew
    [​IMG]
    And again! Buhahahahahaaaa!
    [​IMG]
    P.S: Non-corner win 😛😁
  • Anoop Mathew
    MemberApr 6, 2014
    Next Challenge: To win a 2048 in any of the center 4 tiles ONLY! 👀👍😯😭
  • Tuan Do
    MemberApr 14, 2014
    TIP 1 - Do not use the up arrow key unless you have no moves left except that.
    TIP 2 - Always try to keep the high valued blocks in the bottom row and try to arrange the scores on the block in the descending order from to Left to right (last row) and then right to left in the second last row in the pattern
    TIP 3 - After achieving the above pattern it will be just too easy to get the 2048 tile by merging the 8 and 8 tiles to get 16, 16 and 16 tiles to get 32 and go on until you get the 2048 tile by merging the 1024 and 1024 tile.
    P/S: I usually play games at #-Link-Snipped-# 2048, this site has the 2048 version of the game as: flappy 2048, tetris 2048, 2048 hard, 1 game....
  • Ambarish Ganesh
    MemberApr 23, 2014
    Flappy Bird + 2048 = Whole new level of crazy!
    Here: <a href="https://broxxar.itch.io/flappy48" target="_blank" rel="nofollow noopener noreferrer">Flappy48 by Broxxar</a>
  • Pensu
    MemberApr 23, 2014
    Did anyone try this:
    <a href="https://techcrunch.com/2014/04/23/meet-flappy48-the-clone-game-to-end-clone-games/?utm_campaign=fb&ncid=fb" target="_blank" rel="nofollow noopener noreferrer">Meet Flappy48, The Clone Game To End Clone Games • TechCrunch</a>
  • HermioneGranger
    MemberNov 4, 2014
    well.....that took me a month to do, but eventually cracked it. I don't think anyone has got that far 😁
    Screenshot_2014-11-05-09-37-09
  • ANU SEKAR
    MemberNov 4, 2014
    I reached 1876...
  • Mahesh Dahale
    MemberNov 5, 2014
    Reached 1024
    upload_2014-11-6_10-38-29
    AdministratorNov 5, 2014
    #-Link-Snipped-# That does put all my previous records to shame!
    What spell/charm did you use? 😛😁
  • Anoop Mathew
    MemberNov 5, 2014
    Do notice the number of squares in her game and the one we played. Its different.
    #-Link-Snipped-#: show us the record with 4*4 squares
  • HermioneGranger
    MemberNov 7, 2014
    Anoop Mathew
    #-Link-Snipped-# - thankfully I didn't require any spell. 😀 all thanks to my boring college lectures. I would play this game for 3 continues lectures daily just to pass the time, and eventually I managed to crack it.😉
  • HermioneGranger
    MemberNov 7, 2014
    #-Link-Snipped-# - here it is....I didn't reach as far as 8192, coz its a bit of a challenge in a 4×4 matrix
  • HermioneGranger
    MemberNov 7, 2014
    My trick was to keep all the heavy numbers at one side. Be it left right top or bottom....Just avoid the centre.
  • micheal john
    MemberNov 10, 2014
    reached 2048 and continuing...
  • micheal john
    MemberNov 10, 2014
    2048
    Reached 2048 and continuing...
